Old 11-11-2003, 10:38 PM   #1
aerobahn
Member#: 48296
Question 02 WRX stalling with low fuel
Does anyone know if it's common for an un-modified wrx to stall when taking corners semi-fast (just above speed limit) with a quarter tank of gas or less???
I've taken the car in a couple times to the dealer and they said they could not duplicate. They say there is a fuel cut-off sensor that will kick in under high G-loads but i'm not even pushing that hard when this happens. It happens both left and right and after braking semi-hard in a slight curve and also when flooring it into a corner from a stop. The car will slowly die with the clutch in.
Any help would be GREATLY appreciated.
Bry
aerobahn is offline   Reply With Quote
Old 11-11-2003, 11:10 PM   #2
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Haven't noticed that in the 2.5 years I've owned mine, but then I don't let the tank get too low either. Wouldn't say what you're experiencing is common.
Paul
Snowphun is offline   Reply With Quote
Old 11-11-2003, 11:22 PM   #3
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
There isn't a G-related fuel cut off. Your fuel is sloshing away from the pickups in the tank- it's a known issue, and why outfits like STi offer fuel pumps with built in surge tanks and why places like MRT offer surge tanks seperately. It's less of an issue with the GD body style than the GC because of the dual pickups in the GD's.
Brian
Old 11-12-2003, 12:43 AM   #4
aerobahn
Member#: 48296
[quote]Originally posted by North Ursalia
[b]There isn't a G-related fuel cut off. Your fuel is sloshing away from the pickups in the tank- it's a known issue, and why outfits like STi offer fuel pumps with built in surge tanks and why places like MRT offer surge tanks seperately. It's less of an issue with the GD body style than the GC because of the dual pickups in the GD's.
Brian
Damn. Then why is my dealer so inept?
To tell the whole story, i ran the tank dry once (ie ran outta gas) and it was lurching all the way to station (picking up fuel in spurts i guess) but then i had problems just accelerating straight ahead for a few tanks. It'd lurch violently and cut out and stall. Thought it was fuel contamination so i ran injector cleaner thru it hoping it'd "clean" out. Improved moderately. Still didn't run like it did before. This is when i took it to dealer. They said run some heet thru it to get the water thru, so i did with no improvement. Had the ol' 30k service at 30k and hoped it might solve it by replacing the fuel filter and getting the injectors cleaned. Still a problem. I can't remember the car having this problem when new.
Thanks for any help.
Bry
Old 11-12-2003, 02:51 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The strainer sock on the fuel pump may be dislodged somehow...?
Some people have had similar problems after fuel pump installs.
It may be worth a look.
02 WRX Stalling Iansstud Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-02-2009 12:49 AM
Does the 02 Impreza have a low fuel light? squirelieRS Service & Maintenance 13 05-13-2007 07:40 PM
02 WRX aspen white low miles low price ImprezaSTIVI Private Vehicle 'For Sale' Classifieds 29 03-04-2005 06:22 PM
Check Engine with low fuel? SLIG Normally Aspirated Powertrain 0 08-05-2002 04:07 PM
02 WRX running very low 12's! LowNotezAudio General Community 4 11-05-2001 06:22 PM
