Old 11-11-2003, 10:07 PM   #1
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
Default a carb on a ej25
ok, let say i pulled my engine, mounted it on a stand... would i be able to put a carb on the block? i know that i would need a L shape tube to make it so the carb sits upright and not on its side unless i used a carb from a bike? hmm..
but what would i do about ignition? u cant use a dist... ?
YaZahX is offline   Reply With Quote
Old 11-12-2003, 12:02 AM   #2
xfrickx
Member#: 7267
1994 Honda VFR RC-36
2002 Subaru 2.5RS
What you up to yaz? finally gonna start modding?
Personally I have no clue about the carb idea you got. but sounds interesting. WHY?
see ya round.
David
xfrickx is offline   Reply With Quote
Old 11-12-2003, 12:38 AM   #3
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
the only reason i ask is because i want to donate my engine to the school i graduated from, and i know it would be alot easier for them to work with if it had a carb on it.
but if i build the engine and just tec3 it ill just use the harness i take out and give that to them and hopefully donate a working engine
Old 11-12-2003, 11:51 AM   #4
xfrickx
Member#: 7267
2002 Subaru 2.5RS
What you putting in the RS?
Old 11-12-2003, 12:02 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Subaru used carbs in the past on some of their engines. Giving the "legos" nature of Subaru's you might be able to source the manifold and carbs off of one of those engines and have them mate right up. Worth looking into...
Carbs on a ej? berge06 Normally Aspirated Powertrain 9 06-01-2008 06:47 AM
Will the WRX intake manifold fit on the ej25 heads? Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 25 01-20-2002 12:33 AM
2002 WRX Intercooler possible to fit on a EJ25? blaster88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-19-2001 09:22 AM
question on subaru EJ25 crank... wop Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-15-2001 03:12 AM
How To: Setting Valve Lash on SOHC EJ25 stimpy Normally Aspirated Powertrain 3 06-06-2001 03:58 PM
