Old 11-12-2003, 12:15 PM   #1
pierceman
Member#: 44903
2002 NSXsupercharged
silverstone/black/black
Default will vf22 solve boost creep? HELPPPP
ok this is getting silly, creep, every time I drive. I'm catless, hks dp, 3" all out. I have read about the jimmy rig solution and don't like it. I know there is no utec or reflash out yet, and I don't want to prt the wastegate, but this has to stop. Do I go back to stock DP till the ecu is upgraded? Or will a vf22 solve all my issues????? Help me please, I'm still a NEWB. But did not like the search results.....
Thanks
MAtt
pierceman is offline   Reply With Quote
Old 11-12-2003, 12:31 PM   #2
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
by jimmy rig you mean wastegate porting?
DISCOPOPE is offline   Reply With Quote
Old 11-12-2003, 12:58 PM   #3
pierceman
Member#: 44903
no, I meant the electronic rig where you go in and clip here and splice there to fool the computer. I have looked at the wastegate port, but would prefer to just buy an upgraded turbo so I can switch back if need be.
Is it better to have the wastegate ported or better to get a vf22, or am I way off?
thanks
MAtt
Old 11-12-2003, 01:44 PM   #4
pierceman
Member#: 44903
Sorry, I'm just looking for a basic kind of answer, will a vf22 by its self solve the creep? or do I need more?
thanks again
MAtt
Old 11-12-2003, 01:52 PM   #5
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
I am guessing you might have boost creep with the VF22 since it still is a VF series turbo. Get yourself a good EBC and/or porting or go back to stock downpipe.
dsmperformance is offline   Reply With Quote
Old 11-12-2003, 02:36 PM   #6
DISCOPOPE
Member#: 43339
2oo4 STi
what about hks external wastegate? i see that ultimate put one on their stage 3 in addition to the e-manage.
ive thought about getting a turboback and a a ported turbo swap. but then i start thinking about all the other stuff that should be installed at the same time and i feel like screw it.. ill run stock untill spring.
Old 11-12-2003, 02:38 PM   #7
supermarkus
Member#: 6971
2008 WRX STi
SSM
Boost creep has been a continual problem on STi's for a long time, guys on scoobynet have been battling this issue for years. You might want to check out that site to see if they have any solutions.
supermarkus is offline   Reply With Quote
Old 11-12-2003, 02:45 PM   #8
supermarkus
Member#: 6971
2008 WRX STi
SSM
Old 11-12-2003, 03:33 PM   #9
TurboRex
Member#: 8635
04 STI, 07 FXT
When you guys say boost creep, do you mean boost is increasing as the rpms increase or are you saying boost is higher in higher gears?
On my car, I could never hold boost to redline with the stock turbo and boost in higher gears was higher but never really a problem. I am used to a mbc where this occurs naturally anyway.
Greg
TurboRex is offline   Reply With Quote
Old 11-12-2003, 03:51 PM   #10
pierceman
Member#: 44903
Thanks
Old 11-12-2003, 03:53 PM   #11
pierceman
Member#: 44903
turbo, my car, as it spools under WOT hits a point in 5th gear at about 6000 rps where the whole car shuts off, then comes back on, like some one pulled the plug on it, then the check engine light etc. it is super annoying.
MAtt
Old 11-12-2003, 04:03 PM   #12
TurboRex
Member#: 8635
04 STI, 07 FXT
Okay, thanks. I would think this problem is a boost controller problem rather than a wg size problem. I would think changing the restrictor size might be a cheap easy fix. You could make an adjustable one with a $1 fish valve.
At what boost level is it hitting boost cut?
Greg
Old 11-12-2003, 04:08 PM   #13
DISCOPOPE
Member#: 43339
2oo4 STi
ill bet its at 17.5 psi when you get the cut.
$2$
Old 11-12-2003, 04:48 PM   #14
pierceman
Member#: 44903
I have no guage, I have no idea what psi, the cut is
thanks guys.
Old 11-12-2003, 05:12 PM   #15
TurboRex
Member#: 8635
04 STI, 07 FXT
Man, I did not know they sold any sti's without a guage. My bad.
I recommend getting one. There is probably nothing more important than knowing what boost a turbo car is running at any point in time. The sti gauge is expensive but fits nice and look good. I used a vdo gauge with good luck on my wrx. I attached it directly to the steering column.
Good luck,
Greg
Old 11-12-2003, 06:20 PM   #16
supermarkus
Member#: 6971
2008 WRX STi
SSM
Greg
I wish it were that simple, but on the other side of the pond, they've taken to porting the wastegate area to smooth flow and lower resistance goint to the mouth of the wastegate. Some claim that an ECU reflash can help while other claim nothing short of porting works. Austin was seeing the same kinds of boost creep issues with his vf34 turbo on a highly modified WRX running aftermarket engine management. His "fix" was porting, though I'm not sure he ever really got rid of the boost creep. Exhaust gas was still going through the turbine despite the WG at full open, making the boost pressure creep higher and higher in the upper rev ranges.
Old 11-12-2003, 06:50 PM   #17
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Default Re: will vf22 solve boost creep? HELPPPP
Thanks
MAtt
The only way to truely solve the problem is to port the wastegate, period. The hole needs to be enlarged and the edge of the 90 degree turn to the hole needs to be rounded to about a 1/4" radius. Buy a VF22 for cheap and port it or have it ported, then swap it in. If you've already installed a turboback, pulling the turbo itself is a peice of cake.
Kevin
Red Rocket is offline   Reply With Quote
Old 11-13-2003, 10:01 AM   #18
TurboRex
Member#: 8635
04 STI, 07 FXT
The only drawback to porting the wg is that you may be hindering the hp potential of the turbo when you actually want to run more boost. By redesigning the turbo where waste gases are encouraged to go out of the wg, you will lessen your ability to hold boost redline. That is what forced performance has instructed me.
Greg
Old 11-13-2003, 10:39 AM   #19
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Greg
True, but I think that is more of a "crutch" that lets you force more exhaust gas through a housing that is a little too small. My XS500 with the huge AVO hot side housing has a very nicely rounded/ported wastegate hole - and it has proven to not have problems holding boost.
Kevin
Old 11-13-2003, 12:42 PM   #20
wgknestrick
Member#: 32576
04 STI
Where is everybody getting VF22s for $600?
wgknestrick is offline   Reply With Quote
Old 11-13-2003, 01:46 PM   #21
ryu12341
Member#: 44164
2004 wrx sti
blue
me too.
ryu12341 is offline   Reply With Quote
Old 11-13-2003, 01:50 PM   #22
ryu12341
Member#: 44164
2004 wrx sti
blue
also, do they make vf22's in ball bearing rather than roller bearing?
Old 11-13-2003, 04:05 PM   #23
Quantum-Racing.com
Vendor
Member#: 20483
Greg
Not true. When the wastegate is shut; it is shut. It doesn't matter if you have a black hole on the other side, it is all going through the turbine.
Quantum-Racing.com is offline   Reply With Quote
Old 11-13-2003, 04:17 PM   #24
TurboRex
Member#: 8635
04 STI, 07 FXT
It is possible to port the wg hole where more air is being directed into the wg rather than passing the wg and going through the turbine. The key here is how you port the inlet to the wg hole. Looking into the exhaust housing and the wg inlet you will see what I am talking about.
FP custom designs their turbos to run a certain level of boost. If you change the wg hole design, this can change airflow in and out of the turbo. Whether this applies to the vf39, I do not know. The point is to be careful when porting a wg hole. Be sure you are not porting inside the housing where it can change the flow dynamics of the turbo, regardless if the wg is open or not.
Greg
Old 11-13-2003, 04:53 PM   #25
supermarkus
Member#: 6971
2008 WRX STi
SSM
Greg
If you aren't porting inside the housing, what good are you doing? Are you saying to just enlarge the wastegate hole and that's it? Isn't the point to get more air to flow through the wastegate to prevent boost creep? You have to change the flow characteristics somewhat to do this.
will i get boost creep RedRex26 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-07-2009 09:52 AM
will i get boost creep dubkid26 Southern California Impreza Club Forum -- SCIC 5 03-11-2009 12:15 PM
Will i have Boost creep? jason6787 Newbies & FAQs 9 11-24-2006 03:26 PM
Factory intake seems restrictive. Solved boost creep 4EVO2NV Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 10-12-2004 02:32 PM
will I get boost creep STISTL Newbies & FAQs 2 10-11-2004 04:20 PM
