#1 |
Member#: 31070
Vehicle:2002 WRX Sedan W.R. Blue |
I have a boost spike, car will boost to 12 spike to 15 and drop back to 12. CEL has been on and off, any ideas?
#2 |
Member#: 23735
Vehicle:2002 Impreza WRX Platinum Silver Metallic |
Any mods? Such as a boost controller or intake?
-Dan |
#3 |
Member#: 31070
Stock.
#4 |
Member#: 23735
Well, since your car is stock I would assume that it is just the temperature change, your turbo will run at a higher boost pressure in the cold weather. If you reall want to get a positive answer then you should PM Pace and ask him, he always seems to have the answer.
-Dan |
#5 |
Member#: 31070
it is the 3/16"ths mod, i had forgotton about it, but thanks for the help
#6 |
Member#: 11544
RMIC
Vehicle:01 Silver RS 02 PSM WRX - SOLD |
So does that mean the 3/16 mod is a bad thing?
#7 |
Member#: 32734
RMIC
I would try to put the stock T back in and see what happens.
BEN Also if you cel goes on it should store a code so go to autozone and have them pull it. There is also something called a freezeframe but autozone won't eb able to look at that. What it does is record all of your sensors/inputs at the time that the cel goes off. Any respectable mechainic should have a scanner that can pull the freeze frame |
#8 | |
Member#: 874
RMIC
Vehicle:2003 Honda S2000 2004 Mazdaspeed MX-5 |
Try going back to stock. The 3/16" mod seems questionable. |
#9 |
Member#: 31070
i did the 3/16"ths when i first got my car. i didn't notice the boost spike then cause i had no boost gauge. i don't think it's really a bad thing. can't be any worse than just throwing a boost controler on the car.
#10 | |
Member#: 23735
-Dan EDIT: Except for a shorter then expected life span... ![]() Last edited by WRXturboAWD; 11-14-2003 at 06:08 PM. |
#11 | |
Member#: 18163
Vehicle:2002 2.5 WRX MBP |
| Thread Tools | |
| Display Modes | |
| No boost creep-no boost spiking!!-excellent boost response. | odin1 | Factory 2.5L Turbo Powertrain | 19 | 01-04-2004 07:21 AM |
| I get 1.1 bar boost spikes with stock boost control. Is this dangerous? | rex n effect | Factory 2.0L Turbo Powertrain | 20 | 11-19-2002 03:36 AM |
| Using the stock boost control with a larger turbo/eliminating boost spiking | Red Rocket | Factory 2.0L Turbo Powertrain | 0 | 10-18-2002 09:39 PM |
| Going catless on stock boost control = boost spike? | mrtrex | Factory 2.0L Turbo Powertrain | 7 | 09-15-2002 01:06 AM |
| Boost Controller And Boost Spike??? | slowracing | Factory 2.0L Turbo Powertrain | 6 | 01-19-2002 08:47 PM |
