Old 11-12-2003, 04:06 PM   #1
DriftnWRX
Member#: 44653
2002 WRX sedan MBP
2004 FXT JBP 5 speed
Default Omori gauge install ??
alright, i am about to install my Omori gauges and I am trying to visuallize how I am going to run three guages off of the Clock harness. Help me
DriftnWRX is offline   Reply With Quote
Old 11-12-2003, 04:30 PM   #2
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I tapped the stereo harness.
Brown = NC
Red = Red on stereo harness.
Black = Ground for stereo.
White = purple or purple/white, I'm not certain but its the one next to orange white. I know someone else who used orange/white.
I did not tap the Subaru harness but the harness between the Subaru harness and my Alpine.
StiDreams is offline   Reply With Quote
Old 11-12-2003, 04:58 PM   #3
StiDreams
Member#: 26315
07 Outback
Silver/Silver
BTW mine do not dim. It may be because of the funky STi dimmer setup or it may not. You may want to try the orange/white.
Old 11-12-2003, 11:17 PM   #4
Charged Performance
Vendor
Member#: 40645
Subaru runs off a ground controlled dimmer. Omori's light and gauge ground on electronic gauges are connected - don't use the dimmer on the ground. Do a search like 8 months ago and someone developed a DIY circuit to change the ground based dimmer to work with Omori.
As far as power - there is a plug somewhere near the radio harness that the performance pack gauge pod harness uses. If you can't locate that one use the radio harness as others have suggested.
Charged Performance is offline   Reply With Quote
Old 11-13-2003, 06:12 PM   #5
DriftnWRX
Member#: 44653
2002 WRX sedan MBP
hey Charged, Is the plug near the radio harness different from the one that is used for the clock?? If so is it just hanging there unconnected??
Old 11-13-2003, 06:17 PM   #6
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Honestly other than in the directions for the OEM pod I have never seen it since every car I have been in had the OEM pod and the harness alread I never went down there - but it may well be. I can tell you that if you have the OEM pod the harness for the clock is still there but can't tell you if it is still connected.
Having the OEM pod harness there makes installation of gauges such a snap shame the harness isn't there whether the pod is or not.
Sorry response from personal account.
turboICE is offline   Reply With Quote
Old 11-14-2003, 04:11 PM   #7
DriftnWRX
Member#: 44653
2002 WRX sedan MBP
oh well, i guess ill just have to dig back there and see if the harness is there other wise ill just use the clock harness.. thanks for the help
Omori gauge install inpuressa Newbies & FAQs 4 12-13-2006 07:06 PM
Omori Gauge Install SouthSideTT Electrical & Lighting 0 02-28-2005 06:02 PM
Omori Gauge Installation Question Galore CobraKLR Electrical & Lighting 23 10-09-2003 01:30 PM
Omori Gauge Install T33 Interior & Exterior Modification 1 03-28-2003 09:28 PM
Omori Gauge Install Questions gooey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-30-2001 12:42 PM
