Old 11-12-2003, 11:20 PM   #1
kaossyphany
Member#: 47256
2004 Forester XT
Default igonorant about the imprezza.
I bought a 98 imprezza a few weeks ago and when its starts cold the enigine makes a weird ticking noise until the car warms up. It seems to get worse as the weather has been getting colder. I have owned 6 or so VW's over the last 11 years and never had one that made a noise like this unless a rocker started to go bad. But that never went away. I know nothing of the quirks of a Subaru, but everyone of my VW's had it's own weird quirk that wasn't detrimental and there was nothing I could do about it. Can anyone tell me if this is a quirk or something to be worried about. I no practiacaly nothing about the imprezza engine yet.
Thanks
kaossyphany is offline   Reply With Quote
Old 11-12-2003, 11:37 PM   #2
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
change your oil to 10-40, and it is a normal thing, its the piston slap. mine does it too... the oil will help, but it wont fully go away, if it stays bad then your pistons are worn a bit and a short block is your best bet.
u have a ej25 DOHC model, the 98 was the only year of this, 99 and on uses a sohc motor, they dont make as many noises, but they can under certain conditions.
known issues with the dohc model are blown head gaskets, and cracked cylinders.i havent had a prob with mine,but others have... i bought my car with 89k, it now has 107, still runs good
YaZahX is offline   Reply With Quote
Old 11-12-2003, 11:52 PM   #3
kaossyphany
Member#: 47256
2004 Forester XT
Thanks man i will give that a try.
Old 11-13-2003, 01:10 PM   #4
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
This is a normal characteristic of Subaru engines. My '97 Forester "ticked" when the engine was cold until it warmed up, especially in cold weather. My '02 2.5 RS does it too. It never caused any problems.
Switching to synthetic may help a bit, but it's pretty much an unfixable flaw as far as I know.
DrBoy01 is offline   Reply With Quote
Old 11-13-2003, 06:57 PM   #5
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
Is it piston slap, or noisy hydraulic lifters?
either way, a 10w-40 will help, and try a quart of Rislone next oil change in place of a quart of oil.
marcus12 is offline   Reply With Quote
Old 11-13-2003, 09:00 PM   #6
kaossyphany
Member#: 47256
2004 Forester XT
another question I have the L model not an RS is that's not an ej25 DOHC is it?
Old 11-13-2003, 10:52 PM   #7
m750
Member#: 2278
8Sti | 07 allez
White | Comp
nope, a 2.2 or a 1.8, not a 2.5
AO
m750 is offline   Reply With Quote
Old 11-14-2003, 12:26 AM   #8
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
you can look at the engine block right below the alternator and it will say EJ18 (1.8L) or EJ22 (2.2L)...
//marcus
Old 11-15-2003, 10:50 AM   #9
linsavy
Member#: 11620
1997 GF4-STiV3 clone
only one "Z" in Impreza. That should get you started.
Your 98L has a 2.2l.
The pistons in the EJ engines are skirtless or near-skirtless depending on the year. This reduces friction but makes them knock until the car warms up. This is no problem really, the car will run for a 100k like that. Sometimes the cam belt tensioner makes a knock too, but that usually keeps knocking when warm.
linsavy is offline   Reply With Quote
I've read about the 08 being loud in the back, how about the front? newportbleucheese Impreza Forum 4 04-17-2009 11:57 PM
CBS just talked about the reaction in Baghdad about the shuttle! Eric SS Off-Topic 40 02-03-2003 02:57 PM
Well.....change in plans with the imprezza andrewmva Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-17-2002 12:00 PM
What do you guys think of the Imprezza 2.5rs...Please look here..... QCK HNDA General Community 7 11-04-2001 01:12 PM
