Old 11-13-2003, 12:22 PM   #1
Charlton
Member#: 43038
2002 Forester S
Default Oil pressure
Any of you guys with the oil pressure gauges know about how long you have after startup for the oil preesure and oil temp to be at a favorable level? I don't drive my car hard until I am at operating temp on the factory temp gauge. I have heard you do not want to drive it hard until the oil pressure is at a proper level. How long does it take to get there? 10 minutes? 20 minutes?
Charlton is offline   Reply With Quote
Old 11-13-2003, 02:20 PM   #2
Zen
Member#: 12656
That would depend on the outside temperature. Usually ~5 minutes if you let it idle. If you drive around a bit after it's started.. it may take a bit less.. maybe like 3 minutes?
Zen is offline   Reply With Quote
Drop in oil pressure / low oil pressure magicstop Newbies & FAQs 3 07-24-2015 11:13 PM
Prosport Premium Gauges 52mm Oil Pressure and Temp Remote Oil Pressure Sender Kit skribblez32 Interior/Dressup/Audio & Security 4 07-01-2009 03:50 PM
Oil Pressure/Oil Temp/Oil Gallery plug WRenXhaven Electrical & Lighting 28 05-28-2009 01:54 PM
Oil filter relief pressure / oil pressure spec mattwho Service & Maintenance 1 05-25-2009 11:11 PM
Fuel pressure, Oil pressure, and Oil temp gauges that fit in a single din? annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-23-2002 11:40 AM
