Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 11-14-2003, 10:53 AM   #1
cloudbrk
Member#: 44557
05 Legacy OB Wagon
Willow Green Opal
Unhappy Clunking Noise sounds like axle binding.
Ok...technical question for all you Subaru experts.
I have a 98 Outback Wagon with an Automatic Transmission (why I got automatic I am still confused about).
When I make a tight turn either backing up or pulling forward I get a strange clunking noise. Like something is binding. It is not a clicking like a CV shaft, so I don't think that is the problem. Anyone have any ideas? Could it be the rear differential? HELP!
Thanks in advance.
cloudbrk is offline   Reply With Quote
Old 11-15-2003, 08:28 AM   #2
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Could be several things and I'm sure folks here will have suggestions. One thing to try to eliminate some possibility of it being the clutch pack in the tailshaft of the AT would be to install the FWD fuse under the hood and see if the problem persists. Check your manual under 'temporary spare' . How many miles and are your tires good/the same all around?
Could also be bad motor/tranny mounts, exhaust loose, ?
1 Lucky Texan is offline   Reply With Quote
Old 11-18-2003, 11:28 PM   #3
Slowhand
Member#: 46361
1997 Outback Wagon
Spruce Pearl Green
Wink Binding & Clunking
My automatic 97 OB was doing this until I changed the transmission fluid and the rear differential fluid. Do the tramission first. Undo the drain plug and replace the 4-5 quarts [it holds 10] Drive it for a couple of weeks and do it again. Mine was smooth witin a couple of blocks. Good Luck
Slowhand is offline   Reply With Quote
Old 12-02-2003, 08:58 AM   #4
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
Rally Medic is offline   Reply With Quote
Old 12-18-2003, 05:21 PM   #5
Vicville
Member#: 50874
98 Outback Ltd
I have a 98 OB with the AT and had that exact problem. Changing transmission fluid and filter (yes, it has one) and resetting the ECU fixed the problem nicely.
Vicville is offline   Reply With Quote
Old 01-15-2004, 06:56 AM   #6
Rally Medic
Member#: 28249
1998 Outback Sport
weird grinding noise sounds like/feels like brakes Qcanfixit Brakes, Steering & Suspension 6 10-26-2008 11:45 AM
strange noise? sounds like something is rattling from the Turbo? PEPPY Engine Management & Tuning 1 10-31-2005 04:38 PM
noise,sounds like jingling? redondosubaru Service & Maintenance 2 06-10-2004 07:53 PM
3.3 h6 SVX engine noise...sounds like a slap 5spd Alcyone Normally Aspirated Powertrain 7 06-18-2003 10:04 AM
What does timing belt noise sound like? 98legacy Service & Maintenance 6 01-13-2003 06:29 AM
