Old 04-02-2001, 06:01 PM   #1
Ben
Member#: 423
2002 WRX wagon
Talking 0-60mph on 92 Legacy turbo!!
Hi People, I just tested my car for 0-60 timing, the different from factory boost setting and the Boost control setting has very big different! First I did it with 3000rpm but the car was sudden power loss and the needle drops, then I try 2000rpm and the car runs much smoother and fast!
I did 3 times on the factory boost setting and the first 2 times I think I don't have good control on the clutch engagement, so the time is pretty slow:
1) 9.32s
2) 9.27s
3) 8.63s
With the high boost setting, the time is much faster then the factory setting!!
1) 7.42s
2) 7.41s
3) 6.93s
Also 1/4 mile time , I just did once only :
15.68s @88.3 MPH
The car is 4dr,5spd and almost 3400lb!!
Ben is offline
Old 04-02-2001, 06:06 PM   #2
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Post
How many psi were you running on the 3rd run?
[This message has been edited by STiTkacik (edited April 02, 2001).]
Tkacik is offline
Old 04-02-2001, 06:10 PM   #3
Ben
Member#: 423
2002 WRX wagon
Post
It shows 0.88kg/cm and the conversion is 12.5Psi, the limit of the boost senser is 13psi!
Ben is offline
Old 04-02-2001, 07:16 PM   #4
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Post
60 MPH... Eeeh. Just don't like those 2 numbers right now =( Anywhoo Ben, what did you do to get the psi so high.. Do inform me.. Gratice
-Ells
ejicon is offline
Old 04-02-2001, 09:33 PM   #5
Ben
Member#: 423
2002 WRX wagon
Post
Hi Ejicon, I connected an Apex-i AVC-R boost controler and Ver.2 WRX intercooler to my car so I could boost it to the limit!!!
Ben is offline
HTML code is On
99-01 RS hood scoop on a 92 legacy turbo? 00boostedRS Interior & Exterior Modification 2 04-28-2010 05:50 PM
0-60MPH time on 92 Legacy turbo!! Ben Legacy Forum 1 04-02-2001 07:20 PM
0-60mph time on 92 Legacy turbo!!! Ben Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-02-2001 05:55 PM
G-tech Pro Result on 92 Legacy Turbo!! Ben Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-02-2001 09:31 AM
G-Tech Pro result on 92 Legacy turbo!! Ben General Forum Archive 1 04-02-2001 04:29 AM
