Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 11-14-2003, 04:37 PM   #1
TrizzyDizzy
Member Sales Rating: (3)
Member#: 45256
2002 Aspen WRX Wagon
04 STi Conversion
Default Too many downpipes!
Ok im aiming for around 400hp, thas it. Which one should i get? Invidia, TurboXS, HKS, etc. Ive heard alot of stuff such as the benefits of bellmouth and whatever, but what is the best. Also i dont want a CEL. Do all of the downpipes bolt to stock exhaust? Thanks
TrizzyDizzy is offline   Reply With Quote
Old 11-14-2003, 05:10 PM   #2
wrxruIes
Member#: 18381
2002 wrx
dirty
if your aiming for 400+hp i would get a bell mounth design, such as perins or cusco, also do you want to go cat-less. if your want the best and are not worried about money, id go with perin or cusco
wrxruIes is offline   Reply With Quote
Old 11-14-2003, 05:11 PM   #3
TrizzyDizzy
Member#: 45256
04 STi Conversion
Well i am worrying about cost. I dont want to spend more than 150-200 used for a good down pipe. Also i dont care about cats, because Montgomery doesnt haha.
Old 11-14-2003, 10:42 PM   #4
Unabomber
Big Ron
Member Sales Rating: (10)
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 11-16-2003, 05:17 PM   #5
CynicX
Member Sales Rating: (2)
Member#: 48199
06 WRX
Originally posted by Unabomber
Downpipe FAQ
Very helpful thanks
Slight subject change but I've seen a diagram of the WRX exhaust laid out (like cad or good drawing) somewhere on the forum but I'm unable to find it. If anyone knows where or can link me I'd appreciate it. Thanks
CynicX is offline   Reply With Quote
Old 11-17-2003, 02:10 PM   #6
Chris Morgan
Member#: 28219
2007 Speed3
True Red
I have the invidia 3 inch bellmouth dp. Its awesome! I love it! Way quick spool up!
-Chris
Chris Morgan is offline   Reply With Quote
Old 11-20-2003, 03:14 PM   #7
plunk10
Member#: 32342
2004 :derp:
Originally posted by CynicX
Very helpful thanks
Perhaps one of these.
http://www.mattrandolph.com/wrx/wrx-exhaust.gif
http://www.mattrandolph.com/wrx/wrx-...st-diagram.gif
edit: here's another
http://www.mattrandolph.com/wrx/turbo-piping.gif
plunk10 is offline   Reply With Quote
Old 11-21-2003, 03:40 PM   #8
mizar
Member#: 20293
03 wrx
1820 makes my area tingle
ummm.. perrin and cusco are not bellmouths..
the perrin is divorced.. and the cusco is just sort of welded and blocked off..
bellmouths would be: txs, helix, invidia.. anything that has 1 large open pipe.
divorced is where the wastegate stream is "divorced" from the normal exhaust and they mate together further down the stream
also.. be aware that JDM spec and USDM spec downpipes fit different with catbacks..
mizar is offline   Reply With Quote
Old 11-23-2003, 01:21 AM   #9
WRX-Mike110
Member#: 47831
Go with a wastegate dump side. It allows free flow and helps turbulence when turbo spools up, thus allowing a better spool and better flow of air.
WRX-Mike110 is offline   Reply With Quote
Old 11-25-2003, 11:00 PM   #10
Louie
Member Sales Rating: (47)
Member#: 43393
2014 Audi a6
Daytona Gray
I"m looking for a similar pipe, I've read all kinds of good things about bell mouths,
WRX-mike are you saying to go with the divorced?
Louie is offline   Reply With Quote
Old 11-28-2003, 10:35 PM   #11
SJwrx
Member Sales Rating: (6)
Member#: 14970
1997 GF8
multi
TXS is a bellmount (so is ScoobySport), but you have to chose the size. 3" or 2.5"... after riding in 2 completely different cars (one w/ 3.0" and the other with 2.5") I found I liked the 2.5" myself. They were totally different, they were not close to 400HP, but the low end torque of the 2.5" sold me.
Rich
SJwrx is offline   Reply With Quote
Old 12-02-2003, 01:53 PM   #12
STi City
Member#: 43327
You should get the bellmouth or divorced dp. They all should bolt up to the stock exhaust. You might want to consider getting a dp that will replace your mid pipe also. So you can get rid of both cats at the same time, better bang for your buck.
STi City is offline   Reply With Quote
Old 12-02-2003, 01:56 PM   #13
STi City
Member#: 43327
Rich
you should go with the larger 3" pipe. Turbos do not like back pressure. The more free flow, the better. For TBE, bigger is always better.
Old 12-02-2003, 03:01 PM   #14
SJwrx
Member#: 14970
1997 GF8
multi
I have to disagree with you... to prove my point go run straight downpipe and see if the power is there...
Yes you get good HP readings, but they are FAR up the RPM ladder and don't offer the toque that a smaller tubing will provide. Turbo's need backpressure too.
Rich
Old 05-24-2004, 06:40 AM   #15
wrxfactor
Member Sales Rating: (21)
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
If you go with a bellmouth, you have to make sure it will fit a USDM catback. For example, Invidia's downpipe is JDM and will only fit JDM catbacks(USDM catbacks will have to be shortened).
wrxfactor is offline   Reply With Quote
Old 08-11-2004, 10:26 PM   #16
wrxturbo20
Member#: 68055
2002 wrx stage 2
WorldOne on back window
I got the Perrin down pipe backed by a 3" Espilir cat backand and the dp has a seperated part for wastegate. very high quality. You will get a cel. Simple fix is splice in a cel fix diode between the sensor and plug. Thats what I did. No more cell.
wrxturbo20 is offline   Reply With Quote
Old 08-11-2004, 10:29 PM   #17
mrbigisbudgood
Member Sales Rating: (4)
Member#: 54378
2013 Mazdaspeed 3
Rich
You should let the guys as Cobb know this.
http://www.cobbtuning.com/tech/exhaustdesign/index.html
mrbigisbudgood is offline   Reply With Quote
Old 08-16-2004, 05:25 PM   #18
Jitenshakun
Member Sales Rating: (18)
Member#: 61586
2005 STi
WI and all the goodies
No cats, no CEL and a bellmouth...
I'm going to go with the Godspeed
-J
Jitenshakun is offline   Reply With Quote
Old 08-17-2004, 10:25 PM   #19
SINthetic
Member#: 53775
03 WRX
If yo want the most horsepower out of a down pipe look at the QTP Cutout Downpipe. Up up the exhaust with the flip of a switch. I have one and its awesome.
www.quicktimeperformance.com
SINthetic is offline   Reply With Quote
Old 09-25-2004, 11:27 PM   #20
runwrxrun
Member Sales Rating: (1)
Member#: 51488
wouldn't all aftermarket dp cause boost creep?
runwrxrun is offline   Reply With Quote
Old 09-26-2004, 09:33 AM   #21
Rallycarperson
Member Sales Rating: (28)
Member#: 53971
#35 SP Rally Car
MAP-RALLY.com
If your worried about cost, go with the Helix DP.
-Mark
www.MAPmotors.com
Rallycarperson is offline   Reply With Quote
Old 09-26-2004, 05:31 PM   #22
SJwrx
Member#: 14970
1997 GF8
multi
For a company that JUST started to make anything more than a cat-back for the WRX's., Ill stay with my flow benched ScoobySport.
Rich
Old 09-29-2004, 10:04 PM   #23
The_Black_WRX
Member#: 70964
99RS 04 wrx
07 wrx limited wagon
i have the heilx down pipe and i love it
i got the whole 3" helix cat-less system
www.subydude.com for 850$ shipped
with that alone i got 25hp gain dyno proven
steve
The_Black_WRX is offline   Reply With Quote
Old 11-09-2004, 07:24 AM   #24
Subaru_Impreza
Member#: 49353
2003 Impreza WRX
if you got the money id say go with perrin. i got their's and i love it.
Subaru_Impreza is offline   Reply With Quote
Old 11-17-2004, 09:21 PM   #25
adesso
Member Sales Rating: (26)
Member#: 59892
2004 Harman Tuned
GT30R .82 JBP STi
I also have the Helix DP. It's identical to the Invidia. The spool up is much better, and I'm definitely not disappointed. I have it mated up to a catless Invidia Ti-Tip 3" catback. Absolutely awesome.
adesso is online now   Reply With Quote
How many miles is too many for a used WRX? MitchGT General Community 25 12-10-2005 04:44 PM
Award shows on TV: How many is too many? Matt A Off-Topic 18 12-07-2005 02:25 PM
Too many stickies, too many members! Matt South East Region Forum 21 03-31-2004 09:59 AM
Too many downpipe options - my goals are: sonicblue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 10-29-2003 10:16 PM
How many PSI is too many PSI? virus67 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-03-2001 11:39 PM
