Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 11-14-2003, 05:13 PM   #1
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
Default Possible Problem
Ok heres the story. Im at college and my car is at home so my dad drives it on occasion. He was driving it this week and after about a mile of driving he said there was some white smoke comming from the engine. The main problem is he is there and I am at college so trying to narrow down what the problem is, is fairly difficult. Two possible causes of this white smoke would be a result of the OEM subaru oil cooler installed over a year ago, or the header wrap also installed over a year ago. When I first installed the header wrap, the way it cures is by baking onto the header and it gives off a very nice smell and white smoke was prevalent for the first hour or so. I recently cut some of the header wrap off because the oil cooler made the oil filter come down further in direct contact with the header wrap, because it was making oil changes very difficult. My father said he can see a minor leak just from looking at the engine?? (not sure what he meant). Either way, after he saw the smoke he turned around and parked it back in the garage. He called me and asked if I knew the problem which I obviously don't. Any body have any ideas or should I just tell him to take it to subaru and tell them to fix whatever the problem is?
AustinSTi is offline   Reply With Quote
Old 11-14-2003, 10:44 PM   #2
That Guy
Member#: 23212
2002 Impreza RS
Default Re: Possible Problem
Well that doesn't sound good. Liquid leak? Smokey leak?
Did you maybe just goop some oil on the header wrap last oil change? idunno.
That Guy is offline   Reply With Quote
Old 11-15-2003, 12:07 AM   #3
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I once had the PCV valve hose loose and it did that as the crank case blew oil onto the right exhaust header.
ImprezaRS dot com is offline   Reply With Quote
Old 11-15-2003, 03:08 AM   #4
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
thanks for the input.....any other possibilities?
Old 11-15-2003, 01:18 PM   #5
ImprezaRS dot com
over boosted again
Member#: 1458
leaking oil pump at the front of the motor, dripping down and getting on the headers is my number one guess - just remembered my 1992 legacy did that one.
Old 11-15-2003, 08:45 PM   #6
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
you think it would it be safe to drive it 15 miles to the subaru dealership?
Old 11-16-2003, 02:14 AM   #7
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
bump
Old 11-16-2003, 07:29 PM   #8
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
ttt
Old 11-16-2003, 11:20 PM   #9
ImprezaRS dot com
over boosted again
Member#: 1458
hmmm - it depends - I would hate to see you lose oil pressure in that 15 mile drive and toast the motor. Is the oil level low? Howe much of a drip on the driveway is it leaving? Did it run okay while it smoked, or make scary noises?
Dad should look under the car and in the engine bay for the source of oil to get smoked. Was it overheating and actually water/steam?
Your dad will need to investigate these things to decide if it is safe to drive to the shop.
Old 11-16-2003, 11:55 PM   #10
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
alright thanks man
TurboXS stage 2 installed. Initial impressions and possible problems BOP Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 05-18-2002 12:19 AM
Hybrid turbo and possible problems tmarcel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 03-25-2002 12:09 PM
possible problems w/ engine Russell Rose Bay Area Impreza Club Forum -- BAIC 4 03-07-2002 05:19 PM
Car starts then stalls, possible problems? ProjectNeon122 Legacy Forum 8 08-23-2001 10:56 AM
Possible problem with St Helen meet jeffg North West Impreza Club Forum -- NWIC 0 01-18-2001 05:49 PM
