Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 11-14-2003, 08:06 PM   #1
i want an ubru
Member#: 45045
Question EJ20TT Into a 98' Rx Liberty/Leagcy
Hi Guys love the stuff u do here,
I have a 98' Liberty Rx (In Aust. so its RHD) and i want to buy a jap half-cut of a b4, with the ej20tt donk.
I ve found some info on 99'-02' B4's and it said that it has a much taller gearbox and a final drive (diff) of 3.333:1, i think the RX's is 3.2:1. Does this mean i will have to change my rear diff to a 3.333 ratio one? And where would i find such a diff?
Also with the Rx would it be easiest to install a front mound intercooler, or try and make a dodgy bonnet air scoup myself or try and find a genuine aluminium B4 bonnet?
Any help would be great thanks
-Jimmy
i want an ubru is offline   Reply With Quote
Old 11-15-2003, 11:43 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Jimmy,
B4 bonnets can be found if you shop around. I am in kind of a hurry or I would go get you some links. But come over to http://bbs.legacycentral.org/ and do some searching and you will likely find what you need.
As for the final drive you can do one of two things. You can leave the stock tranny, which is strong enough for that engine or you switch the final drive. There are a ton of tuners down under that you could source that tranny from, or the importer who gets you the front clip will likely be able to source one for you with the rest.
I am sure others will chime in and give you some more specific guidance... And welcome to our sandbox
p.s. in America the term "jap" is considered a racial slur by many...some people around here might get offended, so you might want to edit that to JDM...
Old 11-15-2003, 10:55 PM   #3
i want an ubru
Member#: 45045
Thanks for your help matt,
ill check out those links
ej20tt into 93 legacy?? 92b4man Subaru Conversions 4 06-28-2008 03:12 AM
EJ20TT into a MY01 2.5RS ex25rs Subaru Conversions 9 07-17-2007 12:29 PM
SRT seats into my 05 RX mdz05wrx Interior & Exterior Modification 8 08-28-2005 07:52 PM
ej20TT into svx conversion 5spd Alcyone Subaru Conversions 18 11-20-2004 12:29 AM
JDM 97 legacy EJ20TT into 03 USDM WRX marksWRX03 Subaru Conversions 9 09-01-2004 05:34 PM
