Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 11-14-2003, 11:19 PM   #1
Hojai
Member#: 2190
Default difference between 00RS and 99RS
i am currently parting out my 99 RS-T but i dun have some of the stock parts ie) sensors...etc........
however, the shop has a spare 00 RS engine (complete w/ ECU) here so i can use its parts..........
except the MAF and MAP are different between 00 and 99 RS. What else is different? (The bracket on the side of the intake filter which near the suspension, what sensors or plugs are these?)
Hojai is offline   Reply With Quote
Old 11-15-2003, 01:12 AM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I believe the injector and rails are also different - something about air injection via the 00+ injectors?
Also, the intake manifold for the 00 is different because of the MAP sensor location, while the 99 has the MAF so the intake piping and airbox is different, as you know. I am thinking the ECU is different too, although you'd think that the ECU could use an MAF or a MAP and know which one it was using, I don't think it does. Both are phase II motors, so other stuff should be okay.
"The bracket on the side of the intake filter which near the suspension, what sensors or plugs are these" - that would be the brakes proportioning valves for front to rear bias.
ImprezaRS dot com is offline   Reply With Quote
Old 11-15-2003, 10:06 AM   #3
Hojai
Member#: 2190
i have the stock 99 rail and injectors but the intake manifold is 00 and the ECU is 99. For the intake pipe i think i will put in an aftermarket intake pipe and put in the MAF.
do you think i will need a 99 manifold as well?
Old 11-15-2003, 02:11 PM   #4
ImprezaRS dot com
over boosted again
Member#: 1458
I am thinking that as long as you keep the hole where the MAP goes plugged you'd be okay.
What I don't know if how the air injection through the injector bungs works on a 2000 vs a 99 - if they are different, and need some kind of control, it may be an issue, but if it is all mechanical where when you let off the gas the air rushes in, it might be okay unless the 2000 ECU has to do something with AF ratios when it does that. Blah blah - I wish I knew how it worked, just know it is there...
Old 11-15-2003, 06:01 PM   #5
Hojai
Member#: 2190
i think the mechanic will figure out later.................
hope it's not a hard thing to do
thanks
Technical difference between "Bar and Plate", "Fin and Tube"? FromageTheDog General Community 14 11-10-2005 10:52 PM
Suspension differences between wagons and sedans and my03, and my04. jawbrkr Brakes, Steering & Suspension 16 08-03-2005 08:41 PM
Difference between AWD and 4WD? And other questions... AWD987 Newbies & FAQs 7 01-16-2003 12:00 AM
Caliper difference between sedan and station wagon??? Aspen Legacy Forum 2 11-13-2000 10:34 PM
Difference between 91 and 92 Turbo Legacys?? nd4spd Legacy Forum 3 09-15-2000 03:28 PM
