Old 11-14-2003, 11:09 PM   #1
kitbar
Member#: 41411
2004 WRX Sedan
Java Black No Spoiler!
Default 04 WRX UTEC: getting closer! thanks for all the help!!
So I followed this advice from Chi:
Originally posted by Chi
Kitbar,
Take the lowest timing values from 5000-9000rpms and copy them to the 0% column starting at 5000rpm. Do the same for the fuel map; copy the highest fuel values from the 5000-9000rpm boxes to the 0% column.
Hope that helps...
Cheers!
Now I do not get any Knock when I accelerate from 1st to 3rd.
but if I start accelerating in 2nd I do.
any advice for me?
kitbar is offline   Reply With Quote
Old 11-14-2003, 11:09 PM   #2
kitbar
Member#: 41411
2004 WRX Sedan
2nd through part of 4th
(knocking at usual ECU to UTEC switch)
Code:
3418  -5.7 2.8  26  00    00   14.2 +32.2  ---.- ECU.   +0.0 ECU.   3.0
 3523  -3.8 3.1  46  00    00   rich +23.9   27.0 ECU.   +0.0 ECU.   3.2
 3732  -0.8 3.4  83  20    00   13.3 +15.9   11.0 ECU.   +0.0 ECU.   3.5
 3849  +3.5 3.6 100  50    00   13.5 +13.8   45.0 ECU.   +0.0 ECU.   3.7
 4084  +7.8 3.7 100  70    00   14.1 +14.5   47.0 ECU.   +0.3 ECU.   3.7
 4219 +10.2 3.8 100  70    00   13.5 +14.7   49.0 ECU.   +1.3 ECU.   3.7
 4426 +11.9 3.8 100  60    00   13.3 +13.3   54.0 +17.0  +1.3 ECU.   3.9
 4591 +12.1 4.0  99  70    00   13.5 +14.1   59.0 +17.8  +1.3 ECU.   4.0
 4909 +12.5 4.0 100  70    00   13.5 +15.6   63.0 +18.3  +0.9 ECU.   4.1
 5027 +13.5 4.0  98  80    00   13.8 +16.6   67.0 +19.6  +0.6 ECU.   4.1
 5184 +14.1 4.1  99  80    00   13.2 +18.4   70.0 +19.9  +0.6 ECU.   4.1
 5393 +14.3 4.2  99  70    03   rich +18.9   99.0 +13.0  +0.3  80.00 4.2
 5555 +14.5 4.2  99  80    00   rich +20.3   99.0 +12.0  +0.5  80.00 4.2
 5817 +14.1 4.2 100  80    00   rich +20.7   99.0 +12.0  +0.6  80.00 4.2
 5984 +14.3 4.2  99  80    00   rich +20.8   99.0 +20.9  +0.7  80.00 4.3
 6184 +13.7 4.2  99  70    00   rich +21.9   99.0 +22.7  +0.9  80.00 4.2
 6325 +12.9 4.3  99  60    00   rich +24.2   99.0 +23.0  +0.7  80.00 4.2
 6361 +12.1 4.2  99  60    00   rich +25.1   99.0 +23.0  +0.7  80.00 4.2
 6535 +11.5 4.2  98  60    00   rich +25.9   99.0 +23.0  +0.7  80.00 4.3
 6680 +10.4 4.2   1  00    00   rich +10.2   37.0 +22.0  +1.1 ECU.   3.8
 7262  +7.8 4.0 100  30    00   rich +31.8   83.0 +24.0  +0.0  80.00 4.0
 5274  +7.4 4.2 100  30    00   21.1 +19.1   93.0 +19.5  +0.6 ECU.   4.2
 5027  +7.0 4.0  99  60    00   rich +17.7   93.0 +21.0  +0.2  80.00 4.0
 5012  +8.4 4.1  99  70    00   rich +16.6   95.0 +21.0  +0.3  80.00 4.1
 5081 +11.9 4.1  99  80    00   rich +16.7  100.0 +20.0  +0.4  80.00 4.1
 5216 +13.5 4.2  99  80    00   rich +18.5  100.0 +20.0  +0.4  80.00 4.2
 5350 +14.5 4.2  98  80    00   rich +18.3  100.0 +20.0  +0.4  80.00 4.2
 5500 +15.5 4.2  99  80    00   rich +19.0  100.0 +20.0  +0.4  80.00 4.2
 5455 +15.1 4.2  99  80    00   rich +19.0   99.0 +20.0  +0.5  80.00 4.2
 5555 +15.3 4.2  99  80    00   rich +19.0   99.0 +20.0  +0.5  80.00 4.2
 5640 +15.3 4.2  99  80    00   rich +20.2   99.0 +20.0  +0.5  80.00 4.2
 5737 +14.5 4.2  99  80    00   rich +20.4   99.0 +20.0  +0.8  80.00 4.2
 5747 +14.5 4.2  99  70    00   rich +20.4   99.0 +21.5  +0.6  80.00 4.2
 5931 +13.5 4.2 100  70    00   rich +20.9   99.0 +21.4  +0.8  80.00 4.2
 6060 +13.1 4.2  99  70    00   rich +20.7   99.0 +21.9  +0.9  80.00 4.3
 6027 +12.7 4.2  99  70    00   rich +21.3   99.0 +22.1  +0.9  80.00 4.3
 6105 +12.5 4.2  99  70    00   rich +21.4   99.0 +22.5  +0.9  80.00 4.3
 6127 +12.5 4.2  99  70    00   rich +21.7   99.0 +22.8  +0.9  80.00 4.2
 6289 +11.9 4.3  99  60    00   rich +22.2   99.0 +23.0  +0.7  80.00 4.3
 6277 +12.3 4.2  98  70    00   rich +24.3   99.0 +23.0  +0.8  80.00 4.2
 6373 +12.5 4.2  98  80    00   rich +24.6   99.0 +22.0  +0.9  80.00 4.3
 6397 +12.7 4.3  99  70    00   rich +25.0   99.0 +23.0  +0.8  80.00 4.3
 6472 +12.7 4.2  99  60    00   rich +25.5   99.0 +23.0  +0.7  80.00 4.2
 6600 +12.3 4.2  99  60    00   rich +25.7  ---.- +23.0  +0.7  80.00 4.2
 6587 +12.1 4.2  99  70    00   rich +25.6  100.0 +23.0  +0.8  80.00 4.3
 6613 +12.5 4.3  99  70    00   rich +26.0  100.0 +23.0  +0.8  80.00 4.3
 6693 +12.7 4.3  99  70    00   rich +26.5   99.0 +23.0  +0.8  80.00 4.3
 7032 +10.2 3.8   1  00    00   rich +10.3   97.0 +22.0  +0.8 ECU.   3.7
 7107  +8.4 4.0 100  30    00   14.6 +33.5   76.0 +22.0  +1.2 ECU.   4.0
 5020  +7.0 4.1 100  40    11   12.8 +15.5   91.0 +10.1  +1.3 ECU.   4.1
 4748  +7.8 4.0  99  60    00   rich +13.2   90.0 +10.3  +1.1  80.00 4.0
 4873 +11.0 4.0  99  80    00   rich +14.2   96.0 +10.8  +0.8  80.00 4.0
 4909 +13.9 4.1  99  90    00   rich +13.7   99.0 +18.7  +0.5  80.00 4.2
 5621 +15.5 4.1  75  80    00   rich +17.1   93.0 +20.4  +0.8  80.00 4.2
 6587 +11.5 3.1   1  00    00   rich +10.3    4.0 +22.0  +1.1 ECU.   2.9
 6172  +4.9 3.4   1  00    00   rich  +8.4   29.0 +21.6  +0.9 ECU.   3.3
 5678  -2.0 3.2   1  00    00   lean  +8.7   29.0 +20.0  +0.7 ECU.   3.1
 5333  -8.5 3.0   1  00    00   24.2  +8.6   29.0 +20.0  +0.6 ECU.   3.0
 5005 -11.2 2.9   1  00    00   24.0  +8.8   29.0 +18.8  +0.9 ECU.   2.9
 4629 -11.6 2.8   1  00    00   24.5  +8.7   29.0 +18.0  +1.3 ECU.   2.8
 4278 -11.6 2.7   1  00    00   24.0  +8.6   29.0 +17.0  +1.3 ECU.   2.7
 3977 -11.8 2.6   1  00    00   24.0  +8.8   29.0 ECU.   +0.0 ECU.   2.6
 3711 -11.8 2.6   1  00    00   24.2  +8.8   29.0 ECU.   +0.0 ECU.   2.5
 3422 -12.0 2.4   1  00    00   24.0  +9.1   29.0 ECU.   +0.0 ECU.   2.4
 3165 -12.2 2.3   1  00    00   24.2  +9.3   29.0 ECU.   +0.0 ECU.   2.3
Old 11-14-2003, 11:12 PM   #3
kitbar
Member#: 41411
2004 WRX Sedan
1st through 3rd
(No knocking)
Code:
 10    00   13.1 +22.7   24.0 ECU.   +0.0 ECU.   3.1
 2496  +0.6 3.0  75  20    00   13.0 +16.0   37.0 ECU.   +0.0 ECU.   2.9
 1975  +3.1 2.7  95  30    00   12.5 +15.5   17.0 ECU.   +0.0 ECU.   2.7
 2527  +4.9 2.8 100  40    00   14.0 +17.8   20.0 ECU.   +0.0 ECU.   3.0
 2701  +6.6 3.0 100  40    00   14.1 +16.2   25.0 ECU.   +0.0 ECU.   3.1
 3248  +7.6 3.4 100  50    00   14.1 +15.3   35.0 ECU.   +0.0 ECU.   3.4
 3736  +9.0 3.6 100  60    00   12.6 +12.9   42.0 ECU.   +0.0 ECU.   3.7
 4208 +10.4 3.7  99  70    00   13.3 +13.9   50.0 +17.0  +1.3 ECU.   3.9
 4768 +12.1 3.9  98  70    00   13.2 +14.8   60.0 +18.1  +1.1 ECU.   4.0
 5282 +13.5 4.1 100  80    00   13.8 +18.5   68.0 +20.0  +0.6 ECU.   4.1
 5878 +13.3 4.2  99  70    00   rich +20.4   99.0 +21.4  +0.7  80.00 4.2
 6397 +12.7 4.2  99  60    00   rich +24.2   99.0 +23.0  +0.7  80.00 4.3
 6706 +12.1 4.2  98  60    00   rich +25.9   99.0 +23.0  +0.7  80.00 4.2
 6626  +8.4 3.7  27  00    00   12.2 +37.9   70.0 +22.0  +1.1 ECU.   4.1
 6720  +8.0 4.0 100  30    00   17.8 +32.2   73.0 +21.4  +1.1 ECU.   4.0
 4016  +8.0 4.0  99  60    00   rich +14.2   80.0 +17.9  +1.6  80.00 3.8
 4374  +9.0 3.9  99  70    00   rich +13.2   81.0 +17.0  +1.1  80.00 4.0
 4649 +12.5 4.0  99  80    00   rich +14.7   91.0 +17.8  +1.1  80.00 4.1
 4960 +14.3 4.1  99  80    00   rich +16.3   98.0 +19.6  +0.8  80.00 4.1
 5167 +16.1 4.1  98  90    00   rich +16.9   99.0 +19.2  +0.5  80.00 4.2
 5307 +17.0 4.2  99 100    00   rich +18.5   99.0 +20.0  +0.6  80.00 4.2
 5446 +16.8 4.2 100  90    00   rich +19.0   99.0 +20.0  +0.6  80.00 4.2
 5688 +16.4 4.2  99  80    00   rich +19.0   99.0 +20.0  +0.5  80.00 4.2
 5777 +15.3 4.2  99  80    00   rich +19.7   99.0 +20.2  +0.6  80.00 4.2
 5941 +14.3 4.2  99  70    00   rich +20.7   99.0 +21.8  +0.9  80.00 4.2
 6116 +13.5 4.2 100  70    00   rich +21.5   99.0 +22.5  +0.9  80.00 4.3
 6253 +12.5 4.2  98  60    00   rich +24.4   99.0 +23.0  +0.7  80.00 4.3
 6422 +11.7 4.2  99  60    00   rich +25.0   99.0 +23.0  +0.7  80.00 4.2
 6587 +10.8 4.2  99  60    00   rich +25.5  100.0 +23.0  +0.7  80.00 4.2
 6720 +11.3 4.2  99  60    00   rich +26.2  100.0 +23.0  +0.7  80.00 4.2
 6788 +11.3 4.2  99  70    00   rich +26.9  100.0 +23.0  +0.9  80.00 4.2
 7215  +9.2 4.1 100  40    00   rich +31.6   79.0 +24.0  +0.0 ECU.   4.0
 5307  +9.0 4.1 100  40    00   lean +20.6   88.0 +19.3  +0.6 ECU.   4.1
 5096  +9.0 4.0  99  60    00   rich +17.0   88.0 +21.0  +0.2  80.00 4.0
 4997  +9.6 4.1 100  70    00   rich +16.6   93.0 +20.7  +0.3  80.00 4.1
 5096 +12.9 4.1 100  80    00   rich +17.6   98.0 +20.0  +0.4  80.00 4.1
 5200 +14.5 4.2  99  80    00   rich +18.3   98.0 +20.0  +0.4  80.00 4.2
 5341 +15.5 4.1  98  90    00   rich +18.5  100.0 +20.0  +0.5  80.00 4.2
 5411 +16.1 4.2 100  90    00   rich +19.0  100.0 +20.0  +0.5  80.00 4.2
 5455 +15.9 4.2  99  80    00   rich +19.0  100.0 +20.0  +0.5  80.00 4.2
 5537 +16.1 4.2  99  80    00   rich +19.0  100.0 +20.0  +0.5  80.00 4.2
 5649 +15.1 4.2  98  80    00   rich +19.0  100.0 +20.0  +0.5  80.00 4.2
 5678 +15.1 4.2 100  80    00   rich +20.5  100.0 +20.0  +0.8  80.00 4.2
 5757 +14.5 4.2  99  80    00   rich +20.5  100.0 +20.0  +0.6  80.00 4.3
 5963 +14.3 4.2  99  80    00   rich +20.5  100.0 +20.3  +0.6  80.00 4.2
 5910 +13.9 4.2  99  70    00   rich +20.7  100.0 +21.5  +0.8  80.00 4.2
 6060 +13.1 4.2 100  70    00   rich +21.5  100.0 +21.9  +0.9  80.00 4.2
 6127 +13.3 4.3  99  70    00   rich +21.5  100.0 +22.1  +0.9  80.00 4.2
 6150 +12.7 4.2  99  70    00   rich +21.4  100.0 +22.4  +0.9  80.00 4.3
 6138 +13.5 4.2  99  70    00   rich +22.1  100.0 +22.7  +0.9  80.00 4.2
 6218 +13.7 4.2  99  80    00   rich +22.3  100.0 +21.9  +0.9  80.00 4.3
 6325 +13.5 4.2  99  70    00   rich +25.0  100.0 +23.0  +0.8  80.00 4.2
 6313 +14.1 4.2  99  80    00   rich +24.9  100.0 +22.0  +0.9  80.00 4.3
 6410 +13.5 4.3 100  70    00   rich +25.0  100.0 +23.0  +0.8  80.00 4.2
 6485 +13.5 4.3  99  70    00   rich +25.2  100.0 +23.0  +0.8  80.00 4.3
 6472 +13.7 4.2  98  70    00   rich +25.9  100.0 +23.0  +0.8  80.00 4.3
 6693 +12.9 4.2  99  70    00   rich +26.0  100.0 +23.0  +0.8  80.00 4.3
 6653 +12.7 4.3  67  70    00   rich +26.3  100.0 +23.0  +0.8 ECU.   4.2
 6337  +8.0 3.0   1  00    00   rich +10.6   28.0 +22.0  +1.1 ECU.   2.8
 6150  +1.9 3.3   1  00    00   rich  +8.4   27.0 +21.1  +0.9 ECU.   3.3
 5659  -3.6 3.1   1  00    00   23.7  +8.6   27.0 +20.0  +0.7 ECU.   3.1
 5316  -9.4 3.0   1  00    00   24.2  +8.5   27.0 +20.0  +0.6 ECU.   3.0
 4916 -10.8 2.9   1  00    00   24.5  +8.6   27.0 +18.4  +0.9 ECU.   2.9
 4559 -11.2 2.8   1  00    00   24.5  +8.7   27.0 +17.1  +1.3 ECU.   2.8
 4268 -11.4 2.7   1  00    00   24.2  +8.7   27.0 +17.0  +1.3 ECU.   2.6
Old 11-14-2003, 11:13 PM   #4
kitbar
Member#: 41411
2004 WRX Sedan
1st through 3rd with high rev launch (5k rpm)
(knock while reving to launch)
Code:
 4810  -5.7 2.9  18  00    00   13.8 +35.6   14.0 +18.2  +0.9 ECU.   3.0
 4837  -4.7 3.5  33  00    00   13.1 +23.2   43.0 +18.0  +0.7 ECU.   3.7
 5012  -1.2 3.9  75  20    00   rich +19.6   58.0 +22.0  +0.2  70.00 4.0
 5482  +3.3 4.1  98  60    14   13.9 +17.7   99.0 +12.0  +0.7 ECU.   4.2
 5249  +8.4 4.2  98  70    00   rich +16.2   98.0 +13.0  +0.3  80.00 4.2
 4675 +11.9 4.1  99  70    00   rich +12.9   99.0  +9.1  +1.1  80.00 4.1
 4001 +14.5 4.0  99  80    00   rich +12.6   85.0 +15.4  +1.9  80.00 4.0
 4317 +15.9 3.9  99 100    00   rich +11.3   80.0 +17.0  +1.3  80.00 4.0
 4990 +15.9 4.0  99  90    00   rich +15.0   93.0 +19.2  +0.5  80.00 4.0
 5428 +16.4 4.1  99  80    00   rich +17.3  100.0 +20.0  +0.5  80.00 4.2
 6006 +15.7 4.2  99  80    00   rich +18.8  100.0 +20.8  +0.9  80.00 4.2
 6301 +14.1 4.2  99  70    00   rich +22.8   99.0 +23.0  +0.8  80.00 4.2
 6105 +11.3 2.3   1  00    00   rich  +8.6    6.0 +21.7  +0.9  70.00 3.6
 7278  +9.6 4.1 100  30    00   rich +29.2   94.0 +24.0  +0.0  80.00 4.1
 5984  +8.2 4.1  99  50    00   lean +21.7   99.0 +21.1  +1.0 ECU.   4.2
 5073  +8.6 4.2 100  60    00   rich +16.4   97.0 +18.9  +0.3  80.00 4.1
 4585 +12.1 3.9  99  80    00   rich +12.9   87.0 +17.3  +1.1  80.00 4.0
 4649 +14.5 4.0  99  90    00   rich +14.5   93.0 +17.7  +1.2  80.00 4.0
 4901 +15.7 4.0  99  90    00   rich +15.9   98.0 +18.4  +0.6  80.00 4.1
 5136 +17.4 4.1  99  90    00   rich +16.4   99.0 +19.6  +0.5  80.00 4.2
 5274 +17.2 4.2  99 100    00   rich +18.4   99.0 +20.0  +0.6  80.00 4.2
 5464 +16.6 4.2  99  80    00   rich +19.0  100.0 +20.0  +0.5  80.00 4.2
 5564 +15.7 4.2  99  70    00   rich +19.6  100.0 +21.0  +0.5  80.00 4.2
 5757 +14.9 4.2  99  80    00   rich +20.7  100.0 +20.1  +0.6  80.00 4.2
 6038 +13.9 4.2  99  80    00   rich +21.3  100.0 +21.2  +0.9  80.00 4.2
 6195 +13.3 4.2  99  70    00   rich +21.7  100.0 +22.6  +0.9  80.00 4.2
 6435 +13.3 4.2  99  70    00   rich +24.4  100.0 +23.0  +0.8  80.00 4.2
 6459 +12.5 4.2 100  70    00   rich +24.9   99.0 +23.0  +0.8  80.00 4.2
 6613 +12.3 4.3  99  70    00   rich +26.2  100.0 +23.0  +0.8  80.00 4.2
 6747 +12.1 4.3  99  70    00   rich +27.2  100.0 +23.0  +0.9  80.00 4.2
 6653 +10.8 4.2   5  00    00   rich +41.4   24.0 +22.0  +1.1  80.00 3.9
 7032  +9.8 4.1 100  50    00   12.3 +29.3   88.0 +23.0  +0.8 ECU.   4.0
 4768  +9.6 4.1  99  50    00   12.5 +15.2   90.0 +18.2  +1.0 ECU.   4.0
 5035 +10.0 4.0  99  70    00   rich +17.7   90.0 +21.0  +0.3  80.00 4.0
 5241 +11.5 4.1  99  70    00   rich +17.7   95.0 +21.0  +0.3  80.00 4.1
 5282 +12.7 4.1  98  70    00   rich +18.4   99.0 +21.0  +0.3  80.00 4.1
 5307 +13.5 4.2  99  70    00   rich +18.5   99.0 +21.0  +0.3  80.00 4.2
 5393 +13.9 4.2  99  80    00   rich +18.7  100.0 +20.0  +0.4  80.00 4.2
 5500 +14.3 4.1  98  80    00   rich +18.9  100.0 +20.0  +0.5  80.00 4.2
 5592 +14.7 4.2  99  80    00   rich +19.0  100.0 +20.0  +0.5  80.00 4.2
 5668 +15.1 4.2  98  80    00   rich +20.6  100.0 +20.0  +0.5  80.00 4.2
 5727 +15.5 4.2  99  90    00   rich +20.5  100.0 +20.0  +0.7  80.00 4.2
 5878 +15.5 4.2  99  90    00   rich +21.3  100.0 +20.6  +0.7  80.00 4.2
 5910 +15.9 4.2  99  80    00   rich +20.8   99.0 +20.4  +0.7  80.00 4.2
 6006 +15.1 4.2  99  80    00   rich +21.2   99.0 +21.0  +0.9  80.00 4.2
 6082 +14.9 4.2  99  80    00   rich +21.6   99.0 +21.2  +0.9  80.00 4.2
 6071 +15.1 4.3  99  90    00   rich +21.4   99.0 +21.5  +1.0  80.00 4.2
 6161 +14.1 4.2  99  80    00   rich +21.8   99.0 +21.5  +0.9  80.00 4.2
 6195 +14.7 4.2  99  70    00   rich +22.3   99.0 +23.0  +0.8  80.00 4.2
 6313 +14.1 4.2  99  80    00   rich +22.1   99.0 +21.9  +0.9  80.00 4.3
 6301 +13.1 4.3  99  70    00   rich +24.4   99.0 +23.0  +0.8  80.00 4.2
 6561 +13.3 4.2  60  70    00   rich +25.2  100.0 +23.0  +0.8 ECU.   4.2
 6574  +8.2 3.1   1  00    00   12.0 +10.3   30.0 +22.0  +1.1 ECU.   2.9
 6230  +2.1 3.4   1  00    00   12.3  +8.6   26.0 +21.9  +1.0 ECU.   3.3
Old 11-15-2003, 09:07 AM   #5
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Whoa, you got 17.4 psi of boost in 2nd gear on that last log!
Are you using launch control in the last log? Looks like it. Been thinkin' of trying it, just to see what it does.
Important note:
The 12.5 AFR constant keeps the UTEC from taking control before going rich. When you put values in the 0% column for timing, then you are 'overriding' the AFR constant for timing!!! The UTEC will be advancing timing to the 0% column value before you go open loop.
I got knock when I put 22's in my 0% column in the high rev areas, when the car was still in closed loop at WOT. Had to lower it to 18's. I don't know if avoiding shift knock is worth putting values in the 0% column for timing on 04's, until the permanent fix comes. I also filled in values in the 10% to 40% columns for timing for 4500-7500 rpms. It doesn't look like you did. I may need to go back to ECU control for those load points.
Zackbo is offline   Reply With Quote
Old 11-15-2003, 10:36 AM   #6
kitbar
Member#: 41411
2004 WRX Sedan
your right. I am overriding ECU control without going RICH. Is this a problem? It seemed to fix my knocking problem though...
I have the lowest timing values in the 0% column. I think it's in the range of 17 - 19.
oh that was no launch control. Just a good ole fashion 5500 rpm clutch slipping launch
Important note:
Old 11-16-2003, 08:42 PM   #7
kitbar
Member#: 41411
2004 WRX Sedan
ttt
Old 11-17-2003, 08:17 AM   #8
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
I've got my 0% column at 17-18 starting at 4250. And I filled 10-40% columns also, ramping the timing up to what was in the 50% column. I'm running the Stg 2 93 map, though, so it has higher timing than the Stg2new map. I have lowered my timing about half way between the stg2new and stg293 because of knock in certain areas. If you want a quick miracle fix, put in a gal. of toluene with your next fill-up. Worked wonders for me. I went from knock in every other gear pull, to zilcho. I'm gonna tune a map with 10% toluene, and have another map for pump gas alone. I'm still trying to find a gas station on my commute that sells dependable 93 octane on a regular basis.
Old 11-18-2003, 04:24 AM   #9
JDM 3SGTE
Member#: 35479
did you get the 3.2 filmware from nathan at TurboXS ?? it is a temp fix for the 04 knock.
JDM 3SGTE is offline   Reply With Quote
Thanks for all the help! Kc2iLq Newbies & FAQs 1 08-27-2009 11:10 AM
thanks for all the help! humperdinc Newbies & FAQs 1 08-04-2009 07:42 PM
Thanks for all the Help Scooby South South East Region Forum 4 09-14-2004 10:44 PM
Thanks to all the help..... RiftsWRXBIOTCH Mid West Subaru Owners Club Forum -- MWSOC 18 09-17-2003 05:53 PM
Thanks for all the help.... Philip Bay Area Impreza Club Forum -- BAIC 1 08-15-2001 03:55 PM
