Old 11-15-2003, 10:07 AM   #1
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Have a Nice Day? Don't use 215/60/16's on your Legacy
My father liked the tread pattern on my stock Forester XT tires, so I decided just to throw them on his 99 Legacy GT sedan as a gift...
Well to sum things up, they rub on the strut in the rear. I'm going to try some 5/16" spacers to get them to stop rubbing.
Any other ideas on how to keep them from rubbing?
Bry.
BrysImpreza is offline   Reply With Quote
Old 11-15-2003, 12:29 PM   #2
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Ugh. It's silly to add spacers to cram in a tire that was never meant to fit the GT.
Those are 1.3" inches bigger in diameter than stock. That's pretty huge.
Even if you do manage to squeeze them in there, you'll be in a world of trouble if you have to run the spare tire for very long.
-Brian
KD7000 is offline   Reply With Quote
Old 11-15-2003, 01:09 PM   #3
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Also, with spacers that wide, you're going to have a whole lot of tire sitting right under the fender lip vertically; forget rubbing, the fender will bottom on the tire, and one good whack, especially in the rear, over a speed bump or something, and that fender will be toast......
It's really, really, really not a good idea.....
sybir is offline   Reply With Quote
Old 11-15-2003, 01:19 PM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
spacers = bad
damage to wheel bearings can happen
subiekid is offline   Reply With Quote
Old 11-16-2003, 01:44 AM   #5
AGscooby
Member#: 4242
1999 BD SUS GRN/GLD
gimme Legacy TPH wagon!
Wouldn't be so bad if the Legacy was a BD/BG Outback since that's very close to stock size. Alas, they're too large to ever fit well in GT wheel wells with GT struts. You could replace his suspension with OB pieces... the OB GR2s are available now.
ag
driven by guts inside!
AGscooby is offline   Reply With Quote
WTD: Used 215/60/16 tire in MA,RI,CT drew21180 Wheels/Tires 0 12-11-2008 02:45 PM
Is it ok to use 215/60/16 tires on WRX? gopsu Newbies & FAQs 19 08-21-2006 11:21 PM
235/60/16's on a Baja Turbo? fdg008 Tire & Wheel 2 09-10-2004 07:10 PM
Any one using STI engine mounts on your Legacy? sovereignmk1 Legacy Forum 14 11-28-2002 01:59 PM
anyone using 225.55.16's on a legacy GT cfwdfw Legacy Forum 5 05-19-2001 08:48 AM
