#1 |
Member#: 12176
Vehicle:2002 Geo Metro Teal |
i was taking a peek under my car today (which always turns out to be a bummer) and I noticed some carbon build up on my midpipe-to-axle back flange (Stromung on both). I started up the car and sure enough, some water droplets started lightly "spritzing" out of the bottom. This is not the first time this has happened. I unbolted the connection to find the bottom of the gasket was burnt through. Again. I replaced a gasket about 6 months ago. I also decided to replace the cat-tomidpipe "donut" gasket because I never did that when I put on the new midpipe. There too, I get the same "leak".
is there a solution to this? They appear to be minor leaks, but I'd much prefer a tight seal! I am to the point where I want to just weld the entire exhaust sytem into one piece. Any realistic suggestions?
#2 |
Member#: 2278
NESIC
Vehicle:8Sti | 07 allez White | Comp |
I've had the same problem... a bolt on system just flexes too much, imho.
Maybe an exhaust shop and get under and make sure the flanges are bolted up right, but most likely you'll be replacing the same gaskets again, later on. AO |
#3 |
Street Racing Instructor
Moderator Member#: 110
Vehicle:1989 1989 XT6 |
Is there a recommended torque for those exhaust bolts? Perhaps like cylinder head bolts, they need to be retightened after installation and driving it around for a bit. Maybe your particular setup flex (like mentioned above) more than some others for some reason and a retightening to a certain torque is needed after a couple hundred miles for extra measure.
Just a guess! |
#4 | |
Member#: 12176
I check the tightness on those bolts constantly. |
#5 |
Member#: 4418
South East
Vehicle:2008 S2000 Black |
Just get the flanges cut and make it so they are welded together (axle back and midpipe). This is how my 'custom' n1 exhaust is
.-justin |
#6 |
Member#: 3148
TXIC
Vehicle:2012 Mazdaspeed 3 Crystal White Pearl Mica |
The problem with most, if not all, aftermarket exhausts is that the donut flange cannot be reused (this is at least true with the Apexi N1 cat-back I have).... so this leaves no flexible section in the pipe. No matter how tight you get those bolts, you will almost always develope a leak some where because the engine rotates as you accelerate putting an enormous ammount of torque on those parts.... the only way to fix this is to put a flexible section back in SOME WHERE so when the engine torques, the exhaust flexs instead of pulling at those parts.
The tree huggers will hate me, but I plan on subbing ou the stock cats for a 2.25" straight through with a flexible section (the new Random Tech does not have a flex section in it). |
#7 | |
Member#: 2278
NESIC
AO |
| Thread Tools | |
| Display Modes | |
| i think my exhaust and my car hate me (constant exhaust leak help!) | Supaboom | Mid Atlantic Impreza Club -- MAIC | 0 | 06-19-2004 06:41 PM |
| Why does my car hate me? | Matt | South East Region Forum | 5 | 04-04-2003 10:30 AM |
| my car hates me tonight | YaZahX | Tri-State Area Forum | 3 | 07-20-2002 06:52 AM |
| my car hates me, I swear | slin02 | Factory 2.0L Turbo Powertrain | 7 | 04-05-2002 10:37 AM |
| Why my tires hate me... | BugBomb | Mid Atlantic Impreza Club -- MAIC | 6 | 10-03-2000 04:54 AM |
