Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 11-16-2003, 06:10 PM   #1
Jayjjjj
Member#: 35834
2003 WRX Wagon
Default Car stalls in 1st, CEL, engine dies. Repeat.
The 03 WRX is bone stock and has never been modified. It has 5200 miles.
This problem just popped up today. I pulled out of the driveway, put it in first and let out the clutch for a start grandma would be proud of. The RPMs were up around 2k, car was just barely moving, and the CEL came on, then engine lost power so I pushed the clutch back in and the engine died. I reset the ECU and tried it again. Same thing. The car seems to run ok, I drove back down my street to my driveway with little troulbe, but I babied it to get it rolling. It sounds fine, no strange noises.
Any ideas? I was hoping for a quick and very easy fix instead of towing the damn thing to the dealer and having to go pick it up.
Several months ago, I noticed something vaguely similar, but it happend when I dropped down two gears and got on the throttle hard... a complete loss of power like the key had just been switched off. Just as suddenly, the engine came back to life and ran fine.
J
Jayjjjj is offline   Reply With Quote
Old 11-16-2003, 06:14 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Get the code scanned and post it here so we can help you better. The CEL can come on for literally hundreds of different reasons so you need to know what code was set. Next time this happens, do NOT do a reset as that will erase the code from memory so it can't be scanned, instead have it read ASAP. If there is an Autozone near you they should do it for free, otherwise post in your local forum and there is probably someone near you with a scanner.
Or, if it's convenient to get it to the dealer just go there and have them check it as you're still under warranty.
Old 11-16-2003, 06:15 PM   #3
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Take it back to the dealer while you still have a warranty and havent modded the car.
If the CEL is back on, pull the code and see what it is.
Need4Boost is offline   Reply With Quote
Old 11-16-2003, 06:17 PM   #4
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Maf sensor
Wombat North is offline   Reply With Quote
Old 11-16-2003, 06:18 PM   #5
Wombat North
Member#: 21267
STI, EWG 8cm Green
Maf sensor I believe would be a good starting point.
Old 11-16-2003, 09:25 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Check the top of your airbox and see if it is on properly.
Old 11-21-2003, 06:36 PM   #7
Jayjjjj
Member#: 35834
2003 WRX Wagon
FYI...
I didn't see the symptom described above again after posting this thread.
I took it to the dealer today regardless. They say it needs a new fuel pump controller module, which they put on order today.
There is another possible symptom of this problem that I didn't really see as a symptom until now. When I run the RPMs up hard and let of the throttle to come to a steady speed, there is a momentary loss of power. It only lasts about 1/4 second or so as I lift past about 2/3 throttle. I don't know if this is normal or another symptom. Just wanted to mention it.
Jason
car bucking in 1st and 3rd gears help??? lost03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-18-2009 09:58 PM
Car stalls in all gears except 1st -- Where to look? accelguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-12-2008 11:16 AM
Car stalls in idle, won't go over 4000RPM, can someone help? powerlabs Normally Aspirated Powertrain 13 04-14-2004 01:26 PM
Car stalls in the morning when cold (20F) il96 Normally Aspirated Powertrain 14 12-07-2002 10:30 PM
Anyone's car stalling and then dies after hard corner Andre Vandenberg Normally Aspirated Powertrain 10 02-09-2001 10:27 AM
