Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 11-16-2003, 10:13 PM   #1
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
Default I killed it! help!
I was just replacing the spark plugs...
now when I start it, it sounds ok for about 10 seconds and then boggs and quickly dies...
ack!! what did I do?
I checked all the rubber boots to make sure they were firmly pressed into the hole and I'm sure all 4 plugs are firmly screwed in...
ack, it took a very long time to replace those, mostly because I don't have a flexible neck on my socket... my back hurts and I just want to take a drive....
*sighs*
help...
Eric
StewedSquirrel is offline   Reply With Quote
Old 11-16-2003, 10:46 PM   #2
SubeTek
Member#: 1714
1999 RS-T COUPE
Check the large hose going to the air intake next to the filter-it probably got knocked off. Let me know if there's anything else i can do.
Bret Carter
Mike Shaw Subaru/Flat4Engineering
SubeTek is offline   Reply With Quote
Old 11-16-2003, 11:07 PM   #3
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
Do you mean in the main intake hose? Or something smaller than that?
I did lift the intake over the filter to reach #3, but I put it back. There is just one electrical wire coming out of the box just above the filter.
Thanks for trying to help. If that's not it, would there be anything else?
Eric
Old 11-16-2003, 11:16 PM   #4
SubeTek
Member#: 1714
1999 RS-T COUPE
I PM'd you. Let me know if there's more i can do.
Bret Carter
Old 11-16-2003, 11:46 PM   #5
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
It is your idle control valve vacuum hose (about 7/8" rubber hose), which should run from the throttle body to the intake just behind the MAF. When you lifted the intake you unplugged it I bet.
ImprezaRS dot com is offline   Reply With Quote
Old 11-16-2003, 11:52 PM   #6
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
The most excellent and gracious "SubeTek" solved the problem. Props to Impreza RS for having the solution also.
Idle control vacuum hose it is!! :-)
Lo and behold, it had come loose and I hadn't seen it, being under the main intake hose.
Many thanks to Bret AKA SubeTek and the rest.
My new halogen driving lights (with fancy blue LED trim) also work quite nice and the dash-mounted switch looks almost factory. :-)
I was going to go out and adjust the lights earlier (don't want to blind anyone), but now I'm all tired out. :-D
I think I'll go take it for a spin. Thanks again.
Eric
Old 11-17-2003, 12:35 AM   #7
hoodwho
Member#: 1986
1998 WRX Coupe
Black Diamond Pearl
thats what i was gonna say too...
haha I did that once.... scared the sh...poo outta me...
hoodwho is offline   Reply With Quote
Old 11-17-2003, 02:40 AM   #8
ImprezaRS dot com
over boosted again
Member#: 1458
Yeah, except Bret said it was next to your air filtter, and I had to tell you it was running from the TB to behind the MAF
Old 11-17-2003, 03:16 AM   #9
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
Well, Bret told me that in a PM. But you were only a few minutes behind him. :-)
heh
Not to uhhh steal your thunder or anything. :-)
Thanks,
Eric
Old 11-17-2003, 11:29 AM   #10
hoodwho
Member#: 1986
1998 WRX Coupe
Black Diamond Pearl
way to go bret. you were a few inches off... pssshh.
Old 11-18-2003, 12:41 AM   #11
ImprezaRS dot com
over boosted again
Member#: 1458
That's what she said the other night
Old 11-18-2003, 12:46 AM   #12
bbbwrx
Member#: 32734
Yeah me to
BEN
bbbwrx is offline   Reply With Quote
Old 11-18-2003, 12:29 PM   #13
hoodwho
Member#: 1986
1998 WRX Coupe
Black Diamond Pearl
Originally posted by bbbwrx
Yeah me to
BEN
haha
worst part is you cant even see it... unless you pick up the plenum.. sucked.
nice one larry... haha
OMG kill it kill it!!!! rage557 Off-Topic 16 07-15-2009 12:18 AM
Chad killed it... and it wasn't my fault MK19_ South East Region Forum 10 04-03-2006 09:56 PM
I will kill the next application that steals my focus. Kill it DEAD. gongzero Off-Topic 24 09-10-2003 03:43 PM
Washed my car and thought I killed it YeeHa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-09-2001 10:48 AM
