Old 11-17-2003, 04:37 AM   #1
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
Default Brighter headlights? (my new driving lights w/ pics)
Help a newbie out here...
I've never replaced my headlight bulbs with anything other than factory stock dim-as-all-hell bulbs.
How far can I go on a 1998 Impreza with just a $20 bulb replacement? Halogen? Xenon? Do I need new wiring for these or will a comparable wattage Halogen be brighter without too much hassle in replacing the whole assembly and/or wiring??
Help is much appreciated.
I just installed some driving lights in favor of looking for a pair of factory fog lights. Cost me $30+ about 3 hours of dremeling, drilling and fiddling. :-) They're quite a bit brighter than my headlights. :-)
Thanks,
Eric
StewedSquirrel is offline   Reply With Quote
Old 11-17-2003, 08:58 AM   #2
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Certainly bright
Hank3 is offline   Reply With Quote
Old 11-17-2003, 03:54 PM   #3
I_smoke_hondas
Member#: 47755
Thumbs up I like...
I run silverstars in my impreza- I'm assuming you have H4 bulbs in which they are a direct replacement. Hardest part about changing the bulbs is taking out the battery (to access behind drivers side lamp) About $50 for a pair at any local Checker or whatever. Very much brighter and almost pure white. Some say it is a "poser" look for a cheap HID imitation but the difference is worth it from drivers perspective alone (just changed to some Xenons, very disappointed will put Sstars back ASAP!)
Where'd you get those lights?? I think them's HOT!
Let me know where to pick up a set since my bumper still has the blanks screaming for something to go there..and I think we have a winner.
-AT
I_smoke_hondas is offline   Reply With Quote
Old 11-17-2003, 06:25 PM   #4
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
Can I assume the H4 is the factory bulb? If so, what do I need to look for (say, something printed on a box) to know that the bulbs are compatable with my headlights.
Thanks for the help.
Eric
Old 11-17-2003, 07:17 PM   #5
I_smoke_hondas
Member#: 47755
Hey don't leave me hangin....Where'd you find those lights?? I'm tryin to help ya out man, the least you can do is return the favor-
Yes, that is what size the FACTORY bulbs are- H4, AKA 9003 (sometimes 9003/s) is what is printed on the Silverstar packaging and most others, usually 9003 but some will say both they are the exact same thing...
-AT
Old 11-17-2003, 07:57 PM   #6
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
Heh, sorry. I replied from work. Just got home to check the box and get you the make...
They're "CyberWhite" Navigator NV-538W
They were (I think) $34.99 at Pep Boys. Includes wiring harness, relay, two way switch, lights and mounting hardware.
They're 60W halogen w/ 5W blue acccent rings, 3 1/2" round. It was a tight fit inside the factory foglamp recess cover, but I squeezed them in (with some persuasion from the dremel). They look good in daylight but look GREAT in the dark. :-)
And thanks for the info on the lights.
Eric
Old 11-17-2003, 08:00 PM   #7
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
Is 9004 different from 9003? I found some SilverStar lamps labelled 9004....
Don't want to get the wrong deal. :-)
Eric
Old 11-17-2003, 09:01 PM   #8
I_smoke_hondas
Member#: 47755
Exclamation DIFFERENT
All 9000 series numbers are different- 9001-9007 are all different types of mounts/bulbs. We need 9003s but check any local parts store and they can look all that stuff up too. I would just want you to make sure b/c, even though I believe you have the same bulbs as my Impreza, Subaru changed a lot of things over the years but I'm pretty sure that they remained the same. Good luck, and thanks for showin me the light cause I like 'em a lot...
BTW- is the blue ring always on or switched?? Have fun
-AT
Old 11-17-2003, 09:04 PM   #9
I_smoke_hondas
Member#: 47755
Originally posted by StewedSquirrel
....Includes wiring harness, relay, two way switch, lights and mounting hardware.....
-Nevermind, guess with the two way switch you can turn both on and off....
Old 11-18-2003, 01:52 AM   #10
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
The two way switch has 3 positions... "blue", "off" and "halogen"
I don't know for sure if the blue stays on while the halogens are lit... they're too bright to tell. :-) I think they do stay lit... but it's not apparent.
I have to remind myself to turn them off... I keep forgetting and see the blue lights out my window an hour after i've come inside. :-P
My new driving lights and catch can. RallyeXpress Member's Car Gallery 9 04-02-2007 02:31 AM
New driving lights.. (pics) StewedSquirrel Rocky Mountains Impreza Club Forum -- RMIC 3 11-18-2003 01:46 AM
Night pics of my Cibie driving lights and silverstar headlight bulbs rhdude Member's Car Gallery 9 07-15-2003 12:25 PM
New driving lights on my MCS BuddyChrist Southern California Impreza Club Forum -- SCIC 15 04-17-2003 02:32 AM
Weasel 555 - I'm selling my HID driving light kit !! alfriedesq Tri-State Area Forum 2 03-19-2002 10:09 PM
Message Board Statistics All times are GMT -4. The time now is 01:00 AM.
