Old 06-17-2011, 09:40 PM   #276
Ruvim555
Member#: 247724
2002 WRX WRB Stage 2
2007 CBR 600RR
great mod
Ruvim555 is offline   Reply With Quote
Old 06-17-2011, 10:10 PM   #277
Hanks
Member#: 251660
2004 WRX Wagon
did this as well, great mod.
Hanks is offline   Reply With Quote
Old 07-10-2011, 01:53 PM   #278
SubieMonte
Member#: 264803
2005 WRX Wagon
I'm a noob. Why is this a popular mod and would this negatively affect my daily driver? I've been thinking about doing it but just want to know more about why people our doing this. Thank you!
SubieMonte is offline   Reply With Quote
Old 07-10-2011, 03:15 PM   #279
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Did u read the thread?
Old 07-10-2011, 04:02 PM   #280
SubieMonte
Member#: 264803
2005 WRX Wagon
Yes sir/ma'am. The entire thread. NTL. Is it possible to have the mod explained in lame *$$ terms?
Old 07-10-2011, 04:05 PM   #281
Phatron
Member#: 36033
CEO PhatBottiTuning
The stock bpv isn't good at holding boost at higher pressures.
This mod is supposed to help the bpv control boost better at 20+ psi
Are your sure u read the thread? It says that in the first post....first sentence....
Old 07-10-2011, 05:35 PM   #282
SubieMonte
Member#: 264803
2005 WRX Wagon
Atmospheric pressure or when when I have the throttle pegged? Is this a good mod for a stock wrx? Thank you for the help!
Old 07-10-2011, 05:50 PM   #283
Phatron
Member#: 36033
CEO PhatBottiTuning
not at all necessary for a stock wrx. save ur 0.16
Old 07-10-2011, 08:58 PM   #284
SubieMonte
Member#: 264803
2005 WRX Wagon
Ok? Why?
Old 07-10-2011, 08:59 PM   #285
Phatron
Member#: 36033
CEO PhatBottiTuning
Lol seriously dude?
Read the thread. The answers are in it.
A stock wrx only boosts up to 12-14 psi so u are well below the threshold where leaking becomes an issue for the bpv.
Old 07-10-2011, 09:19 PM   #286
SubieMonte
Member#: 264803
2005 WRX Wagon
Lol seriously dude?
Thanks for setting The Noob straight.
Old 08-02-2011, 11:57 AM   #287
SeeeeeYa
Member#: 129681
2016 WRX EyeSight
LBP
Default Once More The Answer
Yesterday after getting gas I left the station with some oncoming traffic approaching, so I accelerated moderately away. It felt uncommonly good somehow, stronger and rewarding first thru third. I wondered...
During the weekend I'd worked on my tune some, but I didn't really do anything that would account for my new-found zip. I'd flashed the tune, so the ECU was reset... maybe. It was only 75F, cool by recent standards... maybe.
Then I remembered what I'd done Saturday. After a thousand miles, most Stg2, I'd reflected on the way the car had acted during Friday's couple hours on the interstate, where at 75mph a slight throttle movement to account for a minor grade would be followed by a throttle retraction to keep speed under 80mph. This slight reduction in throttle was accompanied by the sound of the BPV venting, and a tiny "lurch" as the engine adjusted. I'd seen it before, and knew the solution... the $0.16 Mod.
On my LGT I did it because I ran 22+psi with an AVO380, and needed it for that. I did it on my 11 WRX because I liked what it did to the drive-ability of car... even throwing my own twist into the mod for reasons I've explained. This time on the 11 STi, although I recorded 20.5psi (in 100F) during a 4th gear boost, I did it for the reason above, I had no issues with the load flow as I haven't flogged the car hard yet, so I didn't even think about it. I just wanted that ridiculous instaventing to stop.
Modifying the STi's metal BPV was a pleasure. The same filtered 1/16" vent hole was used for the same reasons I've explained before. This, IMHO, is how this thing should work. No waiting for the valve to close, no spastic touch-me-not reaction to microscopic throttle inputs... more power instantly and smooth power during higher speed or in-corner throttle feathering. Couple that with far better load flow during shifting all the time. This is not a subtle improvement, to me, but a necessity.
There are a bunch of mods scattered across the years, this may be the best of all.
SeeeeeYa is online now   Reply With Quote
Old 08-08-2011, 06:36 PM   #288
SpotTheDogg
Member#: 235340
I used M6x1 tap no drilling and made a set screw out of something in my junk drawer by cutting the head off to the length I needed and put a slot/screwdriver interface in it with my Dremel. $0
SpotTheDogg is offline   Reply With Quote
Old 08-08-2011, 06:59 PM   #289
Gil
Member#: 20872
t3h rubber-neckers
must die!
bet yours doesn't look as sexy as mine.
Gil is offline   Reply With Quote
Old 08-09-2011, 09:19 AM   #290
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
Very Interesting thread! Subscribed for future reference
Jackie leggs is offline   Reply With Quote
Old 08-09-2011, 12:52 PM   #291
Timmy_M2000
Member#: 289514
2003 WRX Sedan
Ralley Blue
Hello All. I'm running a stock TD-04 and HAD a TurboXs BOV (venting at 21, I removed it because even after changing to Iridium Plugs and newer coilpacks, it rough idled, stalled, and ran crappier than before, plus the fuel system is filthy, cleaning of IACV and MAF in progress) on an '06 TMIC. The thing is, the car is an '03. So I found an original intercooler and put it back on and I have 2 stock BPV's coming. Running 21psi, should I Mod my BPV? (i'm thinking so,) I don't have a tap set, so I'm wondering what i could do besides crushing. Are the self tapping screws safe for use? will they perform as well as the others? Thanks - PM if you'd like or reply, whatever works. (note- the car came set to 21 by the previous owner. I'm trying to figure out how to turn it down with the AEM TRU-BOOST. Any help would be great.)
Timmy_M2000 is offline   Reply With Quote
Old 08-12-2011, 11:17 PM   #292
Timmy_M2000
Member#: 289514
2003 WRX Sedan
Ralley Blue
Bump for previous...need info
Old 08-13-2011, 07:01 PM   #293
SVT_WRX
Member#: 164830
G61 III OVE 58e
If you don't care about reversing the mod, Locite 2 part epoxy works great.
Don't crush it...
SVT_WRX is offline   Reply With Quote
Old 08-17-2011, 07:33 PM   #294
Frank_Zuccarini
Member#: 88939
2011 WRX STi Hatch
World Rally Blue
I just performed this mod on my Stage II 2011 USDM STi (2.5 l motor). I did not need to hold any more than the 19.5-ish psi I run now, but I was intrigued by the drivability enhacments detailed by SeeeeeYa, several posts up.
All I can say is Wow! I followed the instructions of Mr. SeeeeeYa (1/16" filtered hole) and the improvement in drivability was instant and marked. Upshifts are easier and smoother, and the motor comes onto significant boost noticable quicker. I am not aware of any 'surge', so even if it exists, it cannot be very severe.
Thank-you, one and all (and especially the thread starter) for giving me the knowledge I needed to make this newest, very enjoyable mod to my car.
Frank
EDIT: I meant to mention that if you intend to perform this mod, and I certainly recommend that you do so, it is very straightforward. However, the springy clamp that holds the bypass hose to the bypass valve is of a variety that I had not previously encountered. For others unfamiliar with this variety of clamp, I want to point out that you need to pinch the two terminal ends of the clamp forcefully together and they will 'catch'. The clamp will then remain in the 'open' position, allowing you to easily slide it up and down the hose. When reassembling everything, you position the clamp where you want it and then 'release' the clamp by using a screwdriver to twist and to allow the two terminal ends to unlock. The clamp will then instantly grab the hose forcefully.
I had to remove the TMIC in order to have sufficient access to this particular clamp and hose. If you are more dexterous than I, you may not need to do this.
I am sorry, but I did not think to take photos of this clamp while I had it accessible.
Frank
Frank_Zuccarini is offline   Reply With Quote
Old 09-22-2011, 11:20 AM   #295
blue_wrx_chic03
Member#: 34519
03 WRX
WRX blue
my brother did the same mod and then logged it and on his stage 2 LGT spec b it made 1 pound of boost more averaged and a little more then 1 psi on the spike.
Frank
Frank
blue_wrx_chic03 is offline   Reply With Quote
Old 09-24-2011, 07:36 PM   #296
Krazematik
Member#: 279076
what will happen if we do the screw and dont drill the side of the body? and what is the purpose of drilling the side of the body for?
Krazematik is offline   Reply With Quote
Old 09-25-2011, 07:42 AM   #297
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
to provide atmospheric reference instead of pre-tb reference.
you need the hole.
Old 09-25-2011, 12:34 PM   #298
Krazematik
Member#: 279076
im about to do this mod and when i drill the side of the body do i drill enough where i can see the through the hole where i block the bottom end and not anything pass that?
Old 09-25-2011, 09:37 PM   #299
Krazematik
Member#: 279076
i dont know what i did wrong but im boosting only 15ish? i cover the hole and drilled the body but doesnt go no where 22 psi ;(
Old 09-26-2011, 01:15 AM   #300
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
You didn't think this would up your boost to 22psi, did you?
XanRules is offline   Reply With Quote
