12-06-2004, 06:35 PM | #51 | |
Member#: 60794
Vehicle:2007 Solstice GXP |
12-06-2004, 10:26 PM | #52 |
Member#: 53623
Vehicle:WRX 318 WHP PE1820 |
Here's a stupid question - since the BOV mod is more efficient than the standard BOV and doesn't leak (as much) wouldn't you need to be retuned, especially when the car switches to OLF? Or is it just as easy as switching between my GFB and the modded stocker?
12-11-2004, 01:55 AM | #53 |
Member#: 53623
bump for my question ^^^
12-11-2004, 11:49 AM | #54 |
Member#: 4001
Vehicle:2006 Legacy GT Obsidian black |
Yes, you would need to be retuned if your max boost goes up and was not tuned for in the past.
04-25-2005, 09:14 PM | #55 |
Member#: 55525
Vehicle:02 wrx wgn 2.5 Keep Right |
TheMadScientist
Can you update your pics. I just built a 2.5 with an FPgreen. The after market BOV's [turboxs and (Blitz a little better)] are loud and hard to dial in. I cannot stand the extra sound. The turbo intake is sweetness to my ears. the bleet of a bov is just apita, on top of irritating. Thx David |
04-25-2005, 09:21 PM | #56 |
Member#: 9889
NESIC
TMS we can use mine as the model.
04-25-2005, 10:14 PM | #57 |
Member#: 4568
Vehicle:10.7 @ 136, '02 WRX 12.8 @ 112, '09 spec.B |
Any boost that is used to close the valve will be counteracted by the boost pushing against the valve, so in effect, still only the spring is holding it closed. More boost won't cause it to clamp tighter.
It would appear that you've only added more volume by added the second line to help equal the boost on the valve side, allowing the spring to 100% do its job. def |
04-25-2005, 10:22 PM | #58 | |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
04-25-2005, 11:47 PM | #59 |
Member#: 64466
Vehicle:05, STI on green |
Thats awesome....Hopefully when I start running higher boost I'll do this too.
04-26-2005, 12:18 AM | #60 | |
Member#: 85020
Vehicle:02 wrx blue/orange a must c |
04-26-2005, 12:36 AM | #61 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
...mine too.....no problems...one good whack... |
04-26-2005, 01:27 AM | #62 | |||
Member#: 39235
04-26-2005, 05:27 AM | #63 | |
Member#: 23717
NESIC
Vehicle:2005 Big red |
Someone is paying atention. TMS |
04-26-2005, 09:59 AM | #64 |
Member#: 46135
Vehicle:19 GLA45 AMG C63 AMG |
I don't mean to hijack, but Thought that BOV could cure or improve BPV rpm surge. It seems that all of you guys are aware in this tread of changes in this surge from one type of vale to another. My question si: could you please compare the RPM surge between any BOV with stock BPV and modded BPV?
Thanks you, sorry again Vlad |
04-26-2005, 11:01 AM | #65 |
Member#: 55525
Some pictures for us impaired spatialy perception wise.
How do you get the big Hinky diamond shaped stock bo-pv on a FM pipe?? I do better with a few pictures. |
04-26-2005, 07:48 PM | #66 |
Member#: 73648
So, you just block the hole on the pressurized side, and drill the other out? How much do you drill on the second hole?
04-26-2005, 08:21 PM | #67 | |
Member#: 4568
inactuality, the spings force then becomes EVERYTHING. this is why crushing a BOV keeps in shut under higher boost. crushung the BOV is effectively raising the spring pressure, which in turn DOES hold the valve closed tighter. def |
04-26-2005, 08:22 PM | #68 | |
Member#: 4568
def |
04-26-2005, 08:42 PM | #69 | |
Member#: 23717
NESIC
TMS |
04-27-2005, 01:25 AM | #70 |
Member#: 55525
Will this work on an FPGreen and a 2.5 Axis motor?? I am sick of hearing the BoV sound??
A couple of G-damn, pictures would help unkad........ |
04-27-2005, 08:12 AM | #71 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
davenow has a picture of the one on my car, with the drilled out port clearly visible.
bug him for it! |
04-27-2005, 09:40 AM | #72 |
Member#: 23717
NESIC
The pics on the first page still work.
TMS |
04-27-2005, 10:34 AM | #73 | |
Member#: 21980
NESIC
04-27-2005, 10:58 PM | #74 |
Member#: 73648
so, anyone have a better picture of the drilled hole? how deep?etc.
04-28-2005, 02:32 PM | #75 | |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
