Old 04-28-2005, 07:27 PM   #76
OCrex
Member#: 78696
2005 Wingless STI
I just did this mod but i think i might have screwed it up.
When i drilled the whole in the side, i kept going all the way to the inner chamber, all the way through. I didn't even notice the little whole in the shaft that leads to the tapped screw below until i was done. Did i drill too far? How will this affect the performance? Am i leaking boost constantly now?
OCrex is offline   Reply With Quote
Old 04-28-2005, 07:36 PM   #77
CMJ
Member#: 39235
You don't really need to drill the hole. Just tap the hole on the bottom and then push the valve in about half way or more and then thread the set screw in. After the set screw is in release the valve and it will create a minor vacuum in the lower part of the diaphragm allowing it to blow off when needed.
CMJ is offline   Reply With Quote
Old 04-28-2005, 07:40 PM   #78
OCrex
Member#: 78696
2005 Wingless STI
Well, it's too late for that. I've already drilled the whole, i'm just trying to figure out if i went too far and screwed it up.
Old 04-29-2005, 05:39 AM   #79
TheMadScientist
Member#: 23717
2005 Big red
Sounds like you went too far. The depth of the hole on the side should only be ~1/4".
TMS
TheMadScientist is offline   Reply With Quote
Old 04-29-2005, 11:48 AM   #80
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Found the pics. doh!
Think this will hold an FPGreen at about 1.5 bar, tops. My Blitz external is loud (hate it) and It spits and jerks under light throttle accel and decel.
thx
unkadave is offline   Reply With Quote
Old 04-29-2005, 11:52 AM   #81
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it will hold 20 psi, i can tell you that! no reason to believe it won't hold more.
Old 04-29-2005, 11:54 AM   #82
TheMadScientist
Member#: 23717
2005 Big red
Mine held 23-24 on a 16G. Like stated earlier in this thread the more boost you make the tighter the valve will close.
TMS
Old 05-22-2005, 08:01 PM   #83
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
I noticed this thread was posted quite awhile back. Are you still using this bov? I am assuming, if you still are, that you have not had any issues between the small amount of surge and your turbo?
TyranosaurusWRX is offline   Reply With Quote
Old 05-22-2005, 09:35 PM   #84
EVOBOXR
Member#: 73648
I did the mod, painted it nice and purdy black....My car is so much smoother now...took the RFL off....this mod deleted the reason I took the stock one off...great and EASY mod
EVOBOXR is offline   Reply With Quote
Old 05-23-2005, 05:55 AM   #85
TheMadScientist
Member#: 23717
2005 Big red
I ran this mod on my WRX with a 16G for ~1 year and now I have been running it on my Sti with the VF39 for 1.5 years.
I have not had any problems at all. I will soon be running this with a 20G on the Sti.
TMS
Old 05-23-2005, 06:08 AM   #86
brenden3010
Member#: 79461
04 STi
Originally Posted by TheMadScientist
There is nothing that I can feel that is different. Except that the BOV now holds a rock solid 20psi. I am sure that it will hold more but my boost gauge only reads to 20psi.
So you could be holding 29389283 psi, but you have no clue, right? You only know its over 20... watch out.
brenden3010 is offline   Reply With Quote
Old 05-23-2005, 07:39 AM   #87
pezman04wrx
Member#: 66558
^^^ I'd venture a guess that he's running a better boost gauge now since the post you mentioned is from 03', and it was on a totally different car ...
pezman04wrx is offline   Reply With Quote
Old 05-23-2005, 08:11 AM   #88
TheMadScientist
Member#: 23717
2005 Big red
I set the WRX up using the Utec boost #'s from log1. Set to 22-23psi.
Well the same boost gauge is on the Sti now. But I have the boost set to stock right now.
TMS
Old 05-24-2005, 12:09 AM   #89
Athena
Member#: 86226
1987 Toyota truck
brown
Air Power Systems Pty Ltd has this to say about their blow off valve:
APS BOV development:
We are often asked why we developed our own blow off valve when there are so many on the market. Quite frankly APS had not found a blow off valve for the WRX/STI that offered the level of performance required.
With a large turbocharger, releasing pressure from the turbine compressor wheel when the throttle is snapped shut is critical not only for turbocharger response, but for turbocharger longevity. A huge volume of air must be passed through the blow off valve as soon as the throttle is closed.
Most blow off valves have limitations in their design that inhibit the level of performance we demand. Piston/bore diameter and venting ports are often too small and surprisingly, most will not fully expose the exhaust ports when fully opened.
Ultimately, the need for a truly high performance blow off valve specifically designed for the WRX/STI needed to be satisfied.
Athena is offline   Reply With Quote
Old 05-24-2005, 04:56 AM   #90
TheMadScientist
Member#: 23717
2005 Big red
In the words of Suicidal Tendencies
Send me your money
TMS
Old 05-24-2005, 12:09 PM   #91
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
Just crushed my BPV this weekend. ~3mm, works great. No driveability difference that I could discern.
Tom
SlideWRX is offline   Reply With Quote
Old 05-24-2005, 01:59 PM   #92
lowblow
Member#: 56902
2009 VW Jetta SE
Tom
This was more about the screw mod, no the crushing mod...but if it works, then good for you
lowblow is offline   Reply With Quote
Old 05-25-2005, 03:07 PM   #93
SlideWRX
Member#: 3803
07 Mustang GT
True, but the thread pretty much contain the info for both, so I figured it's more of an 'Improve the Stock BPV' thread.
Tom
Old 07-20-2005, 08:08 PM   #94
subeerex
Member#: 87430
02/5 BugEye-Peanut
Sedona Red Silver
Have a Nice Day? whatever works
Because I am a cheap SOB. This cost me 16 cents the Sti BOV is around
$100.
I already have a $200.00 BOV from GFB but can't adjust it without a turbo-boost gauge and I'm tired of test driving. I'll try anything at this point and the $0.16 valve sounds like a deal...not to mention, a fun project!! But, while in the subject...would a gauge help me set the BOV? Would my GFB BOV work as well as your project, but with a gauge added? I mean...I already have it...can I work with it?
subeerex is offline   Reply With Quote
Old 07-21-2005, 08:26 AM   #95
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you shouldn't need a boost gauge to set up a bov properly.
there are two extremes:
too little tension, leaking at idle, rough running/starting.
too much tension, compressor flutter at throttle lift, or in an extreme case, surge.
stay between those two and you're all set.
Old 07-21-2005, 09:15 AM   #96
subeerex
Member#: 87430
02/5 BugEye-Peanut
Sedona Red Silver
Question
What's the difference between drilling the hole on the side and just setting the screw after pushing the valve in? Which one is better...cause I'm about to do this mod and if there's no difference or it's better without the hole, then that'll save me a step or may-be give me better results...would it?!
Old 07-21-2005, 09:22 AM   #97
subeerex
Member#: 87430
02/5 BugEye-Peanut
Sedona Red Silver
Question
TMS
What about the diameter of the side hole? Should it be the same as the diameter of the hole in the inside that got tapped? Could it be smaller or should it be larger? Does it make any difference?!!
Old 07-21-2005, 09:31 AM   #98
subeerex
Member#: 87430
02/5 BugEye-Peanut
Sedona Red Silver
Question
Did you do the mod by drilling the outer-side hole or did you just tapped the inside hole while squezzing in the valve? Very important cause I wanna know which method is better and why? Obviously one is a step less than the other but which one is BETTER?!!!
Old 07-21-2005, 09:44 AM   #99
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
drill the hole.
Old 07-21-2005, 09:44 AM   #100
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
same diameter.
