Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 07-21-2005, 11:01 AM   #101
TheMadScientist
Member#: 23717
2005 Big red
Originally Posted by subeerex
I already have a $200.00 BOV from GFB but can't adjust it without a turbo-boost gauge and I'm tired of test driving. I'll try anything at this point and the $0.16 valve sounds like a deal...not to mention, a fun project!! But, while in the subject...would a gauge help me set the BOV? Would my GFB BOV work as well as your project, but with a gauge added? I mean...I already have it...can I work with it?
If you are going to modding your car gauges are one of the things you should buget for. A set of gauges is not that much $ compared to a new motor.
TMS
TheMadScientist is offline   Reply With Quote
Old 08-04-2005, 02:39 PM   #102
dudical26
Member#: 37934
dudical26 is offline   Reply With Quote
Old 08-04-2005, 03:16 PM   #103
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
It was discussed on page 2.
TyranosaurusWRX is offline   Reply With Quote
Old 08-04-2005, 03:31 PM   #104
dudical26
Member#: 37934
It was mentioned but not discussed. I want to know if any one has tried it and what there results where.
Not to be a Nood but what exactly is surge?
Old 08-04-2005, 05:21 PM   #105
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Well, it was briefly discussed. But anyways, surge is when the airflow is stopped (ie throttle closes) and the compressed air left in the system has nowhere to go, and it almost instantly stops the turbos compressor wheel. It may not be the best description, but you get the idea. Surge puts stress on the turbo.
Old 08-04-2005, 10:49 PM   #106
Chuck H
Member#: 20442
KTR tuned 2003 WRX
VF34 equipped, 270 whp
Another quick question on this one, since I plan to do it when I get my VF34 installed. Would a reasonable alternative method be sealing that bottom hole with something like JB Weld rather than tapping it and using the set screw, or is the screw definitely the way to go? It just seems like the JB Weld weld might be quicker and easier.
Chuck H is offline   Reply With Quote
Old 08-04-2005, 10:55 PM   #107
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
a set screw is the way to go. jb weld could break loose and end up going in the ic. If you use a longer set screw even if it backs out some it can't come all the way out.
LiquidForce is offline   Reply With Quote
Old 10-27-2005, 02:56 PM   #108
mpower22
Member#: 58352
04 20G STI(SOLD)
08 z51C6 (growing mullet)
any updates...can this mod be done with a sti bov??
I need to hold 23ish psi on a larger turbo....
mpower22 is offline   Reply With Quote
Old 10-27-2005, 03:24 PM   #109
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
fwiw, i did not tap, i used a self tapping metal screw.
Old 10-27-2005, 04:56 PM   #110
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
You don't need to do this on an STi BOV. Its already "modded" this way IIRC.
cdvma is offline   Reply With Quote
Old 10-27-2005, 05:36 PM   #111
mpower22
Member#: 58352
04 20G STI(SOLD)
can anyone verify that a stock sti bov will hold that much boost without leaking?
Old 10-27-2005, 10:51 PM   #112
x99percent
Member#: 27108
2004 STi
2004 A4
Mine wasn't.
x99percent is offline   Reply With Quote
Old 10-27-2005, 11:01 PM   #113
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Originally Posted by x99percent
Mine wasn't.
Me too then...
Originally Posted by Greg Sharpe
Yeah, the STi recirc BOV has a softer spring and is lacking the boost signal port. The divit for the port is there, but it isn't drilled all the way through.
Old 10-28-2005, 06:07 AM   #114
TheMadScientist
Member#: 23717
2005 Big red
That is only on the JDM ones. The USDM BOVs are the same on the STi and WRX.
TMS
Old 10-28-2005, 12:24 PM   #115
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Ahh...I get it now. Thanks. Sorry for the confusion.
Old 12-18-2005, 08:22 PM   #116
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
All bow to the GREAT MAD SCIENTIST...........
Cheers.....this is fair dinkum stuff.
sixpack subaru is offline   Reply With Quote
Old 12-18-2005, 11:22 PM   #117
suberdave
Member#: 101865
88 GL-10 STi
awesome
suberdave is offline   Reply With Quote
Old 12-19-2005, 05:59 PM   #118
firebomb
Member#: 80872
ok just to add i have a dsm and this mod DOESN"T work on dsm's
i think our valves hold more pressure than wrx ones
but if you just block the hole doesn't that escentially do the same thing without drilling the hole? i mean airflow isn't getttin in there, so whats the need to vent the pressure to the atmosphere?
firebomb is offline   Reply With Quote
Old 12-19-2005, 06:18 PM   #119
firebomb
Member#: 80872
or try this
good bov mod also
Old 12-19-2005, 06:53 PM   #120
firebomb
Member#: 80872
heres my idea
so basically you have a homemade type-s
Old 12-19-2005, 07:17 PM   #121
TheMadScientist
Member#: 23717
2005 Big red
Originally Posted by firebomb
heres my idea
That was my first idea.
I didn't have the tools to do it though. I got the BOV apart but couldn't get back together to my satifaction.
TMS
Old 12-19-2005, 08:42 PM   #122
firebomb
Member#: 80872
just an idea
btw how did you get it apart? just uncrimped the top?
Old 12-20-2005, 05:05 AM   #123
TheMadScientist
Member#: 23717
2005 Big red
I had to put slices around the lip of the gold top and then bend the lip up.
TMS
Old 12-20-2005, 08:14 AM   #124
SaabTuner
Member#: 67608
Man, you know a thread is old when it talks about running 23+ psi on the stock EJ205 and not being worried about meltdown on #3.
SaabTuner is offline   Reply With Quote
Old 01-15-2006, 02:08 PM   #125
justboosted02
Member#: 78285
2003 EVO
red and black
i run 21psi on my stock ej205 and i have an egt probe on #3 and my egts never go above 820C. its all in the tune
justboosted02 is offline   Reply With Quote
