Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 11-17-2003, 11:36 AM   #1
SubaruStore.com
Member#: 18245
Default SOHC engine builders
SOHC motor builders.
In recent light people have found a problem with ARP head studs for Subaru's. On the box the headstud kits were marked as available for for EJ 2.2, 2.0 and 2.5 L motors and while they all fit those particular bottom ends, there was a misunderstanding in the deisgn of the Heads leaving the stud kits unusable for the SOHC motors.
Oringial discussion
We have been communicating with ARP about resolving the problem but we need to gauge interest to see how many sets they would need to have produced as this would be a complete custom run for the time being.
these bolts would still have all of the same features over the standard botls such as stronger more durable metal composition resulting is better torquing characteristics and being less likely to stretch as much.
if you have any question fell free to ask of if you would be interested in new Stud kits please let us know as we're trying to get this squared away as soon as possible.
thanks
Brad
www.subarustore.com
407-277-8423 x 226
SubaruStore.com is offline   Reply With Quote
Old 11-17-2003, 12:55 PM   #2
Aphex
Member#: 146
'16 WRX Limited
Count me in for a set.
Aphex is offline   Reply With Quote
Old 11-17-2003, 02:07 PM   #3
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
I'll take one too.
seven881 is offline   Reply With Quote
Old 11-17-2003, 02:49 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I changed your title so that it's a little more clear.
Old 11-17-2003, 03:10 PM   #5
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I'm definetely down.
Graham
Graham is offline   Reply With Quote
Old 11-17-2003, 06:13 PM   #6
FJP
Member#: 43852
GC8 2.5RST
can you pm me ARP's phone number so that they can take care of my stripped block?
Thanks,
Kevin
FJP is offline   Reply With Quote
Old 11-18-2003, 02:03 AM   #7
markus
Member#: 438
2004 STi
White on Gold
In the process of aquiring parts for custome build turbo block. I would count these as HIGH on my priority list, so mark me down for a set.
Cheers,
MB
markus is offline   Reply With Quote
Old 11-18-2003, 02:24 AM   #8
smacksube
Member#: 4067
01 2.5 rs
count my in for a set
smacksube is offline   Reply With Quote
Old 11-18-2003, 10:51 AM   #9
foolio
Member#: 9351
2006 trailblazer SS
black
Im Down 100%
foolio is offline   Reply With Quote
Old 11-19-2003, 10:40 AM   #10
Evan J. Kelly
Forever Scooby Newbie
Member#: 11172
2000 GC8 RS Coupe'
FlatBlack&BlueRidge Pearl
Thumbs up Bingo Bango
I'm down for a set too.
Evan J. Kelly is offline   Reply With Quote
Old 11-19-2003, 11:52 PM   #11
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Brad, I emailed you about a company that did ARP studs with steel inserts in the block for my 00 SOHC motor. They aren't taking new jobs right now, however they could let you know what model # ARP stud they used if you contact them.
Also, I have a new spare set of 99.5mm 8.5:1 JE forged pistons with offset wrist pins, ceramic topped, teflon coated, and Total Seal gapless ring conversion that I need to unload at well below my cost. I can't use them because I sold my RST, and my even if they fit my STi my wife sez NO.
ImprezaRS dot com is offline   Reply With Quote
Old 11-19-2003, 11:53 PM   #12
ImprezaRS dot com
over boosted again
Member#: 1458
PS: the studs were not for a subaru 2.5L, so it may be that the steel inserts in the block were required to make them work, but steel inserts are still a good idea to be able to torque them to spec without pulling out of the aluminum block.
The timesert steel sleeves machined into the block before installing the studs will be much better than trying to repair the block with a helicoil later, when the stud pulls out while torquing.
Old 11-20-2003, 01:31 AM   #13
FJP
Member#: 43852
GC8 2.5RST
yup, that's the plan
Old 11-20-2003, 01:31 AM   #14
FJP
Member#: 43852
GC8 2.5RST
Old 11-20-2003, 10:03 AM   #15
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
Im Down 100% too
ChAi is offline   Reply With Quote
Old 11-20-2003, 09:14 PM   #16
SubaruStore.com
Member#: 18245
An on going group by will begin on monday.
normally a custom run of these would take about 8-9 weeks for ARP to throw in however I've managed to talk them into gettings these done a bit quicker... approx 4 weeks. As I know a few of you are in a hurry to get these.
Larry, I recieved your e-mail I just haven't had a chance to look into it 100% although ARP and I have a good idea of how they got them to work. ARP and I both agree though that it would be best to get a set of studs that worked 100% though with no real modification necessary. I do appreciate the information though, and will investiage it further.
Full details will be available on monday
thanks
Brad
Old 11-20-2003, 09:39 PM   #17
ImprezaRS dot com
over boosted again
Member#: 1458
okey dokey
Old 11-21-2003, 01:28 PM   #18
techworkseng
Member#: 21604
We would like 3 sets to begin with please, and possible more. We need one set as soon as possible if you can.
Thanks.
Keith
www.techworkseng.com
techworkseng is offline   Reply With Quote
Old 11-24-2003, 10:52 AM   #19
Section 8
Member#: 821
Me too.
Section 8 is offline   Reply With Quote
Old 11-30-2003, 04:40 PM   #20
ChAi
Member#: 1277
1999 Minnam Stage 2
Did the group buy staeted yet? I very need to get one ASAP
Old 12-01-2003, 01:21 AM   #21
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
I'm interested in a set as well.
BAN SUVS is offline   Reply With Quote
Old 12-01-2003, 01:25 AM   #22
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Just to make sure, please link to the post regarding the sales of these, rather then post them FS in here. Approxomate pricing is ok, but selling directly from this thread isn't.
Old 12-01-2003, 07:08 PM   #23
SubaruStore.com
Member#: 18245
http://forums.nasioc.com/forums/show...hreadid=462182
details for the group buy have been posted.
thanks
Brad
Old 12-15-2003, 01:27 AM   #24
SubaruStore.com
Member#: 18245
bump
Old 12-15-2003, 12:53 PM   #25
FJP
Member#: 43852
GC8 2.5RST
Well, ARP is not taking responsability for thier mismarked head studs $700 block repair and worthless studs.
ARP 204-4204 Engine Head Studs Bolts Kit Nissan SR20DET RWD wrxej205 Engine/Power/Exhaust 13 04-28-2010 01:08 AM
Need to buy!!!-14mm head studs PIECEOFTHEPIE Private Vehicle 'For Sale' Classifieds 2 12-22-2008 09:45 PM
ebay intake? mbc? bov too? dyno sheets to make your head spin.... bren wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 02-06-2006 05:23 PM
SOHC Head Stud Kits SubaruStore.com Vendor 'Group Buy' Classifieds 23 04-12-2004 12:27 PM
Is it ok to reuse the head studs? LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-13-2004 08:22 AM
