Old 03-20-2008, 10:36 PM   #1
White_Rice
Member#: 160049
Question Running way rich..HELP PLEASE!!
After installing a perrin inlet tube, perrin intercooler hoses, and a gm boost solenoid the system is running way too rich, attempted to lean out the fuel map via enginuity and still nothing........any ideas as of where to start?
==ROB==
White_Rice is offline   Reply With Quote
Old 03-20-2008, 10:40 PM   #2
WRXShawn
Member#: 35742
2002 PPG + FPGreen
how do you know its rich? Wideband? exhaust? Feel? Is it studdering and running bad? White smoke?
WRXShawn is offline   Reply With Quote
Old 03-20-2008, 10:45 PM   #3
White_Rice
Member#: 160049
I used enginuity software on a laptop.
but yeah studders, white smoke, idles like crap, runns like crap really hates being shut down than started again.
Old 03-20-2008, 10:47 PM   #4
White_Rice
Member#: 160049
Also I might add that I checked all hoses, connectors and vacuum lines after install.
Old 03-20-2008, 10:51 PM   #5
subaruGT35
Member#: 175120
check for all the install you did anythiing that is off and not put the right way could be causing you that problem
subaruGT35 is offline   Reply With Quote
Old 03-20-2008, 10:58 PM   #6
testes1010
Member#: 47145
2012 Gas Saver
white smoke = coolant.
Black smoke = gasoline
Blueish-black = oil
DO NOT adjust the AFR table w/o a WBO2, you are literally playing with fire.
testes1010 is offline   Reply With Quote
Old 03-20-2008, 11:09 PM   #7
subaruGT35
Member#: 175120
Dont get the guy scared check the intercooler to the throttle body it acts like that when the intercooler pipe is disconected from the throttle body
Old 03-20-2008, 11:11 PM   #8
White_Rice
Member#: 160049
I would imagine that it is white at this point because it is pretty cold and I'am running catless.
Old 03-20-2008, 11:53 PM   #9
selvar05WRX
Member#: 165524
2012 CTS-V Sedan
Black Diamond Tri-Coat
check to make sure your maf sensor is plugged in and make sure you put the pin BACK IN YOUR PCV that came off your old turbo inlet. If its none of those it sounds like a boost leak, double check all of your intercooler hoses and make sure you have the lines going to to your soleniod going to the right places
selvar05WRX is offline   Reply With Quote
Old 03-21-2008, 01:32 AM   #10
WRXShawn
Member#: 35742
2002 PPG + FPGreen
check to make sure none of the connectors on the coil packs got loose.
Old 03-21-2008, 01:52 AM   #11
White_Rice
Member#: 160049
Just ripped it all back appart cleaned the MAF and put a little bit of royal purple on all of the hoses for a bit of a seal, put it back together cranked everything down and its all good.
Thanks to all who tried to help.
==ROB==
Oil issues as well as running way rich? Subpar04 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-19-2009 12:02 AM
WOT running way rich. thorne Commercial ECU Reflashes 3 08-16-2007 08:51 AM
Dyno'ed Car Today/HELP-Running Way Rich Bigmike Bay Area Impreza Club Forum -- BAIC 11 08-04-2002 05:32 PM
Dyno'ed Car Today/HELP-Running Way Rich Bigmike Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-02-2002 10:48 PM
Boost Gauge Readings Suddenly Way Off: Help Please TV3WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-28-2001 02:05 PM
