Welcome to the North American Subaru Impreza Owners Club Tuesday July 29, 2014
Old 05-06-2004, 11:25 AM   #451
zombiedog
Member#: 25138
85 e30
PRIMERZ!
zombiedog is offline   Reply With Quote
Old 05-09-2004, 01:42 AM   #452
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
just put the gruppe-s v2 manifold on to my car that already has vf30, blitz fmic, hks racing intake, helix uppipe, catless turboback, turbo inlet, vishnu xede ecu. First off the sound is almost the same, louder at idle but smoother almost and at WOT its louder but still keeps the boxer engine sound. Feels like 10-15whp, REALLY noticable that it pulls harder. I wrapped the manifold also so that might help with the lag people say but i really dont feel much lag comapred to stock manifold down low.
On a side note, someone who bought a part off me came by my house today and has the GP MOTO manifold. Im not sure about the performance but it sounds like ****. Does not sound like a wrx at all and was just terrible. Stay away from this manifold if you want your car to keep the same sound.
dan avoN7 is offline   Reply With Quote
Old 05-09-2004, 02:22 PM   #453
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
oh and also im not sure if this is from the turbo or the header because the sound was made when i added the vf30 to my exhaust i already had. When the car isnt warmed up all the way at around 3k rpm the exhaust gets a little raspy sounding. Now with the header added that sound is made from like 3k-3500 rpm until the car is fully warmed up. Once warmed up it goes away and the exhaust sounds smooth.
ill try and get some sound clips later in the week of the sound when not warmed up and fully warm.
Old 05-10-2004, 06:24 PM   #454
casualsurfer
Member#: 60773
2004 WRX
So this article will show up on Speed Style Sound magazine? June/July issue, right?
casualsurfer is offline   Reply With Quote
Old 05-11-2004, 09:39 AM   #455
zaxrex
Member#: 9898
Water Injected Blue
Yup. Mine too...
zaxrex is offline   Reply With Quote
Old 05-11-2004, 03:31 PM   #456
SSTINGER77
Member#: 45635
02 WRX Wagon
yes the article/ magazine should have this header comparison in the june issue
SSTINGER77 is offline   Reply With Quote
Old 05-20-2004, 12:59 AM   #457
Silver_Fox
Member#: 3733
2009 Legacy GT
Red
19 pages of useless banter and not a single dyno.
im not using the search next time.
Silver_Fox is offline   Reply With Quote
Old 05-20-2004, 01:07 AM   #458
ButtDyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Actually only 10 pages... and the thread is titled "Looking to do Header Dyno Comparison" not "RESULTS FROM HEADER DYNO COMPARISON!".. what do you expect
john
ButtDyno is offline   Reply With Quote
Old 05-20-2004, 01:09 AM   #459
Silver_Fox
Member#: 3733
2009 Legacy GT
Red
i wasnt serious, although i was expecting one dyno, and yeah, its 19 pages.
Old 05-20-2004, 01:40 AM   #460
Mushashi
Member#: 40396
Mushashi is offline   Reply With Quote
Old 05-20-2004, 02:37 PM   #461
Drift Monkey
Member#: 41227
2005 Legacy 2.5GT
Garnet Red Pearl
n00b settings.
Drift Monkey is offline   Reply With Quote
Old 05-20-2004, 03:36 PM   #462
zombiedog
Member#: 25138
85 e30
PRIMERZ!
DOUBLE
It's ok everyone was a n00b a some point.
Old 05-20-2004, 04:17 PM   #463
Silver_Fox
Member#: 3733
2009 Legacy GT
Red
yeah n00b lets look at member numbers
secondly, 19 pages or 10 pages you read the same amount of useless posts, which we are contributing to now
Old 05-20-2004, 05:41 PM   #464
cubanlink
Member#: 21738
2002 WRX Sedan
TXS Stg 2 =P
Originally posted by AZScoobie
I still think if I took a set of stock headers, Extrude honed them and wrapped the pipe sections and upipe that I would be better off.
Clark
Do you think that thinning out the header walls would make them to sensitive for a daily driver? I remember when I drilled the tap for my EGT sensor that the iron seemed brittle.
Just a thought
cubanlink is offline   Reply With Quote
Old 05-20-2004, 05:49 PM   #465
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Just a thought
They would still be thicker then most aftermarket sets... And because they would be under the stock heat shields you dont have to worry about them cracking at the welds when you drive threw a puddle of cold water.
I can tell you this much:
The GT spec headers will add a solid 500 rpm worth of boost onset on a big turbo setup. If cold they will add around 800 rpm. I have owned/tested/tuned these headers. Forget the wrapping.. Its not going to help that much.. Better yes but not the solution.
Remove the GT's and sell them to someone with a smaller turbo. They work very well on stock turbo setups.
Port match your Stock iron manifolds. lay the gaskets down, Mark them, Grind the iron down with a Dremel. Wrap the Cross over pipe and put all heat shields back on. Order an upipe from Coastal Dyno or have him modify the one you have (I am doing this next time mine comes out). Bingo... 500+ rpm increase in boost onset, probably 20-40 ft lbs of trq on the bottom end and no more heat issues.
I just recently went through this on my car... Removed GT's and installed Stockers that I ported myself. Its somewhere around 500-700 rpm faster to get 14 psi with no apparent loss in top end. Off idle is even stronger.
Old 05-20-2004, 06:30 PM   #466
0260B4U
Member#: 33249
2003 WRX
white
post
0260B4U is offline   Reply With Quote
Old 05-20-2004, 06:37 PM   #467
totoherbs
Member#: 7321
.... 122 IggPoints
Originally posted by 0260B4U
post
Que? You know there is a subscribe to this thread button on the bottom of every thread...?
Old 05-26-2004, 07:48 AM   #468
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
pizost.
Diversion is offline   Reply With Quote
Old 05-26-2004, 06:55 PM   #469
0260B4U
Member#: 33249
2003 WRX
white
Originally posted by Diversion
pizost.
IM RICK JAMES BITCH!
Old 05-27-2004, 11:23 AM   #470
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Darkness is spreading!
Old 05-29-2004, 08:09 PM   #471
JalopySiR
Member#: 39378
2004 Carless
98' VFR800Fi/02' RC-51
where the hell are the results?
JalopySiR is offline   Reply With Quote
Old 05-29-2004, 09:03 PM   #472
WRenXhaven
Member#: 43905
02 WRXBastardchild
Few more days I'm sure, well unless something else delays it, dunno.
WRenXhaven is offline   Reply With Quote
Old 05-30-2004, 05:04 AM   #473
BrianH
Bing user
Member#: 44383
They cancelled posting of the results.
BrianH is offline   Reply With Quote
Old 05-30-2004, 12:30 PM   #474
casualsurfer
Member#: 60773
2004 WRX
ah, so that means we'd have to get the magazine.
when is the magazine due out?
Old 05-30-2004, 12:32 PM   #475
0260B4U
Member#: 33249
2003 WRX
white
Well thats kinda gay
looking for an auto shop to do header installation wolfwayne Vancouver Impreza Club Forum -- VIC 16 12-12-2009 08:56 PM
software to do road dyno? rapturem3 Open Source Reflashes 13 08-05-2008 06:02 PM
Header Dyno Comparison not12listen Normally Aspirated Powertrain 8 08-22-2007 12:40 PM
looking to buy headers and flex joint uppipe wrxsti143 Mid Atlantic Impreza Club -- MAIC 0 05-24-2004 01:22 AM
Looking to do a custom trunk install. Need suggestions on where to go? my02wrx Southern California Impreza Club Forum -- SCIC 25 12-05-2003 12:58 PM
