#676 | |
Vendor
Member#: 66143
The headers no longer have slip joints. they are fully welded in those areas in a jig. If you would like to send your headers in to them I am sure we can make arraingments to get that done for you. Thet will solve your problem with the leak and eliminate the need for brackets Mike Licht
#677 | |
Member#: 33249
South East
Vehicle:2003 WRX (white) aka Little John |
Ok please explain this revesion, I am unfamiliar with the term. And if its so bad why hasnt anyone complained about that particular solution. And seems to offer the best gains. ![]() |
#678 | |
Member#: 67608
Here's a quote from page 119 of Corky Bell's "Maximum Boost" on reversion: "Reversal of the exhaust gas flow back into the combustion chamber during valve overlap is called reversion. Creating and aerodynamic barrier that reduces the reverse flow, yet does not impede outward-flowing gases can pay dividends in performance." Page 120 shows a diagram explaining what they mean by that. The small difference in internal diameter between the exhaust port and exhaust manifold creates a one-directional obstruction to prevent reversion. It can be found on almost all factory setups. Leave it be unless you really really know what you're doing. Adrian~ |
#679 | |
Member#: 43986
NESIC
Vehicle:2002 WRX wagon RIP 2003 330ci black/tan |
#680 | |
Member#: 23630
NWIC
Vehicle:97 v4 STi RA Feather White, 02 WRX MBP |
What do you think about this idea? I know I won't see alot if any gains from it, but if it will help smoothout the exhuast flow and lower egt's even a smidge I'll do the work. |
#681 | |
Member#: 67608
As long as the header/manifold diameter is at least a millimeter or two larger than the exhaust port the anti-reversion trick should still work. As for smoothing the exhaust parts I think it's a great idea as long as you don't go over-board. Remember that it all has to funnel down to an opening the size of the turbine inlet. Making the transitions smoother is a great thing to do though, gains or no gains. Make sure not to make the walls of the header/manifold too thin. Also as a side note, to those considering polishing any of their interior piping either to or from the engine, a slightly abbrasive surface actually lends itself to flow by giving the boundary layer something to "hold on" to. A mirror shine on your intake ports can actually hurt flow. Just a side note thought. Good luck and sorry for the OT. Adrian~ |
#682 |
Member#: 23630
NWIC
Thanks for the help Adrian.
#683 | |
Member#: 18960
South East
Vehicle:02 WRX MBP It lives! ; ) |
BTW, the scenario described in CB's book is an exaggeration of turbulent flow; matching the intake/exhaust sealing area precisely and accurately is a good thing. ![]() |
#684 | |
Member#: 36333
NESIC
Vehicle:DIY project: life I need more TIME! |
wow thats good to know. This is strange...if this is true than why would one want to polish your piping ? are some places better left relativly "rough" compared to other places where you would want it smooth as glass? I am verry curious to this entire porting and polishing bussiness. If you see websites like http://www.deadboltspeed.com/ they actuly polish the crap out of your turbo. Can anyone refer me to some info on P&Ping...or anyone know would know the best ways to P&P my Impreza?My budy just bought a die grinder and I am anxious to try that thing out. what parts should I thoroughly port out and smooth...and what parts should I stay away from? I am sure there are many others out there just a curious! Not only does a little P&P work give you some killer improvments to your car, but its fun as hell being able to customize your car for free! |
#685 |
Member#: 67608
Porting and "smoothing" is great and good for flow. But if you can part your hair in the reflection off your intake ports you might have gone a bit too far. Smooth is good, slick can be bad.
The part in CB's book about reversion can be found on 80's turbo grand prix cars. Some headers even have built into them anti-reversion chambers. Generally a small lip in the exhaust system near the port someplace is desirable. The bit about turbulent flow is mentioned in Hugh MacInnes book and can be applied to turbine discharges. This is because the gasses exit the turbine in a helix or spiral. The path for those exhaust gasses is longer if they remain in the helix, so a sudden diameter increase at the discharge converts the helix to turbulent flow. The pipe can then be smoothly reduced in diameter a foot or two later. This alos muffles the exhaust note considerably. Now to your regularly scheduled header debate. ![]() Adrian~ |
#686 | |
Member#: 7321
NESIC
Vehicle:.... 122 IggPoints Work... ahhh... so tired. |
There was a thread about porting your turbos a while back... it had some good links. There is also a few threads that talk about porting your exhaust manifold. I would realy do your research before you start playing with the die grinder. |
#687 |
Member#: 3496
NESIC
Vehicle:1995 Roadmaster Beige |
so, after all that, the charts don't link anymore... and the website is dead and there's nothing about it on the new website...
#688 |
Member#: 15607
Vehicle:I'm not the type to make angry |
I still have all the info. What questions do you have?
#689 |
Member#: 3496
NESIC
well, I was hoping to read the article and look at the charts.
#690 |
Member#: 15607
the way the shop printed the charts was asinine. I was very unhappy with the article when it was finished.
I'll give you the short version. All the headers with the exception of the GT Spec Ver.2 made power. The average increase in spool time was about 200rpm on the first cold pulls, then non-existant on the second pull. (all headers were wrapped w/ DEI wrap) The Cusco Header made the most power by 1hp (I consider that Dyno error margin) The GP Moto header was second making about 17hp more across the pull. The Fujitsubo came in 3rd with about 12hp across the pull. The Borla, Gruppe-S, and the rest came in about the same with 5-10hp Please keep in mind that all headers that did not come with an up-pipe were tested with the Helix up-pipe to be fair against the one piece units. I'm not mentioning the GT Spec Gen.3 as it has been discontinued and had a catastrophic failure shortly after this test (on RiftsWRX's car). As for fitment, the Cusco, Borla, Gruppe-s, and Fujitsubo fit the best and were the easiest to install. The GT Spec, GP Moto were the hardest. If you have any further questions feel free to pm me. ![]() btw- I have since tested a set of extrude honed/ cnc port matched, jet hotted stock manifolds. The results were interesting. No loss of spool (cast iron holds heat better), and a gain of about 5hp across the band. For the money spent ($700) to do the port job right (by hand is impossible to remove as much material as extrude hone) and the cross over pipe and the jet hot coating, I would rather spend the $699 on the GP Moto header, $60 on header wrap and make about 10 more whp. For all those who complain about losing the "boxer rumble", remember it's the sound of inefficiency. ![]() Dylan DS1 Inc. Last edited by downshift1; 09-29-2007 at 02:10 PM. |
#691 |
Member#: 3496
NESIC
so, you'd pick the GPmoto one?
what problems did you have with fitment What about ones without the integrated up pipe? I have a Perrin up pipe already and that's the biggest problem to install |
#692 |
Member#: 36063
Vehicle:2005 Saab 9-2x Aero Red |
I'm all ears on this too. I tried reading through all these pages a few weeks ago only to discover the same sad truth: the links were dead.
#693 |
Member#: 23216
Vehicle:2006 949-457-1234 949-457-1234 |
Keep in mind these are 2.0 dyno results. Generally the FJT, Cusco, etc. headers employ smaller runners for better performance results on mildly modified 2.0 cars. On 2.5 cars or more heavily modified cars, you will see more power gains going with bigger runners. The same Gruppe-S 4-1 header made 10whp and 18ft/lbs on a 2.5 car, with NO LOSS throughout the entire power band. For 2.0 cars on stock turbos running the 4-1 headers I would definitely coat or wrap and employ a 2.0" uppipe. For modified 2.0 cars with bigger turbos, a 2.25" uppipe and coated wrapped headers work best.
Cheers, Gary Gruppe-S |
#694 |
Member#: 41149
SCIC
Vehicle:04 09 FXT SSM |
#695 |
Member#: 101090
SCIC
Vehicle:2002 WRX w/ VF39 Midnight Black |
Did you guys happen to test the DC header?
#696 | |
Member#: 36333
NESIC
how much did GP moto pay you for that one? how can u justify spending SEVEN HUNDRED dollars on a mass produced piece of metal? when you can basicly replicate the exact same results...AND keep your awesome BOXER RUMBLE ! ...all of this WHILE being able to say... "Yeah I Ported and Polished that all myself"... FOR FREE ![]() |
#697 |
Member#: 15607
Gary@ Gruppe-S- Actually the Cusco has the biggest runners of any header in the test. The FJT was a close second in size. The rest were about the same. And in my opinion (having installed 100+ up-pipes, the large diameter Helix up-pipe is still the best bang for the buck.
btw- I never did get to say thanks for your help with this. TheblackRex- The DC wasn't made at the point the test was done. IllNastyImpreza- I wasn't paid anything by anyone, I did this out of a desire to find out which was better. Sure you can waste your time porting and polishing a stock manifold set, but you'll never make the power you could. Hope the "rumble" helps you feel fast ![]() -Dylan DS1 Inc. |
#698 |
Member#: 36333
NESIC
#699 |
Member#: 126603
Vehicle:2008 135i Alpine white |
So, between the gt spec gen2 or a borla ceramic coated, which one would be the best? I'm looking to purchase one now and so far I'm down to these two. Since the borla is ceramic coated, would this in turn produce better results throughout the band? Also, are they both unequal or equal? And what are the diameters of each? Thanks for the help.
#700 |
Member#: 15607
I would definatly do the Borla, the GT spec were the only header that lost power in the test.
Ceramic coating does help. both are unequal, primary and collector diameter are almost identical. The Borla fits a lot better too. |
| Thread Tools | |
| Display Modes | |
| looking for an auto shop to do header installation | wolfwayne | Vancouver Impreza Club Forum -- VIC | 16 | 12-12-2009 08:56 PM |
| software to do road dyno? | rapturem3 | Open Source Reflashes | 13 | 08-05-2008 06:02 PM |
| Header Dyno Comparison | not12listen | Normally Aspirated Powertrain | 8 | 08-22-2007 12:40 PM |
| looking to buy headers and flex joint uppipe | wrxsti143 | Mid Atlantic Impreza Club -- MAIC | 0 | 05-24-2004 01:22 AM |
| Looking to do a custom trunk install. Need suggestions on where to go? | my02wrx | Southern California Impreza Club Forum -- SCIC | 25 | 12-05-2003 12:58 PM |
