Old 06-15-2000, 01:04 PM   #1
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Question Minnam Turbo Owners - What psi are you running?
I've got five questions for all Minnam turbo owners:
1) What stage (I, II) are you running?
2) What psi are you running at?
3) How many miles have you been running at that psi?
4) What year is your car?
5) Have you noticed any detrimental effects?
My stage II goes in Monday (in my MY00 RS) and I'm wondering if I should consider 10psi. Thanks!
Sean
Sean McElderry is offline
Old 06-15-2000, 01:16 PM   #2
MattC
Member#: 158
2011 STi
PBP 1999 2.5RS RBP
Cool
When I got the kit I couldn't run less than 7psi. As it broke in that went up to 8psi. You cannot run anymore than that safely, without raising fuel pressures. I will be installing a 20002 bel FPR along with a Paxton FPR next week. At that time I will raise the boost to 10psi. Oh, I have had the kit for 3 months, and have put 3k miles on it. No real problems with it yet. You won't believe the difference it makes! Night and Day, I'm telling you.
MattC
MattC is offline
Old 06-15-2000, 01:49 PM   #3
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Question
And what year is your car? Thanks!
Sean
Old 06-15-2000, 02:20 PM   #4
adam99rs
Member#: 20
Post
a tick under 17 psi (1.1 bar), but with substantial mods to fuel and also timing manipulations via the A'pex ITC.
Matt - why are you getting a Paxton AND a Bell FPR? I do run around with the car at this level for much of the time, but also turn it down to .75 bar when I am just not in the mood for speed. Mine is a 99 BTW, with 38k total, and about 29k of that turbo'd.
adam99rs is offline
Old 06-15-2000, 03:29 PM   #5
Wreckleford
Member#: 887
Post
Hey Adam, correct me if I am wrong, but I thought 1 bar = 14.7 psi.
Wreckleford is offline
Old 06-15-2000, 05:27 PM   #6
Molez93
Member#: 585
02 WRX
WR Blue
Angry
1) Stage 2
2) 3 psi [Not that I'm happy with that fact]
3) All 2k since March
4) 98
5) From the Kit? No. From the install? Yes- Too many issues to list.
6) Misc stuff- The exhaust piping required a reweld so it would fit in two different places. Asside from that, all the shop needed was a decent set of directions (which didn't come with the kit) to complete the job.
My best guess at this point is that the Turbonetics wastegate had a 3 psi spring in it from the 'factory.' I've produced as much as 10 psi by bypassing the wastegate. I'm still working through the remdies so maybe I'm wrong.
-Scott
Harrisburg Pro Solo bound in 14 hours...
Molez93 is offline
Old 06-15-2000, 08:34 PM   #7
MattC
Member#: 158
2011 STi
PBP 1999 2.5RS RBP
Post
The bell unit becomes active above 7psi, the paxton regulates normally. I want to run 10psi, and liked this configuration. BTW, my car is a 99.
MattC
MattC is offline
Old 06-16-2000, 05:01 AM   #8
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
1) Stage II
2) Have been running about 5.5psi, but working to up that to 8-10psi.
3) 16K miles (1 year this month)
4) MY98
5) No detrimental effects.
The Bell FPR (20005) was just installed last night. Accidently running my car at 12+psi while tuning caused no ill side effects (other than a huge grin on my face). I had to remove the Hallman MBC I recently installed because I could not get it to regulate my boost UNDER 12psi, and I'm not sure where it would have maxed out.
SteveS
http://www.lagging.com
SteveS is offline
HTML code is On
Whats psi are you running on stock turbo killichnakropf Newbies & FAQs 7 05-27-2010 01:13 PM
what psi are you running on stage 2 wrx the real suby dude AccessPort 14 05-21-2007 02:59 PM
RS owners, what speakers are you running in the rear deck.. munkis Tri-State Area Forum 17 05-30-2004 08:54 PM
Wagon Owners What Coilovers Are You Running? nathanellis Brakes, Steering & Suspension 12 05-17-2004 03:18 AM
What psi are you running in your RE92s? Enkidu Tire & Wheel 21 11-12-2003 05:59 AM
