Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 11-17-2003, 03:46 PM   #1
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
Default ABS (plastic) tubing for intake
Am I crazy to think I can use ABS piping for the intake? I know it's made for plumbing... but the intake is already plastic, so I don't think it should be a big deal. You can find inexpensive small-angle elbow joints, so I think it should work and ABS tends to be more flexible. Plus, it's good to almost 200 degrees, which should be fine as long as it's not too close to the block. I'd use PVC because it's a bit more rigid and I think melts at a higher temperature, but IF it does melt, the gasses are toxic...
Anyone ever used ABS before?
I think it would be fun to try to make some ABS intake piping. :-)
Eric
StewedSquirrel is offline   Reply With Quote
Old 11-17-2003, 11:11 PM   #2
kturner
Member#: 8225
My 01 Legacy sports a 3" ABS intake attached to the stock airbox. I like it.
kturner is offline   Reply With Quote
Old 11-17-2003, 11:23 PM   #3
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Same here except me have MY98
-paK +21
Pakin is offline   Reply With Quote
Old 11-17-2003, 11:42 PM   #4
WAFlowers
Member#: 23337
1997 Legacy GT Sedan
TTIWWOP
WAFlowers is offline   Reply With Quote
Old 11-18-2003, 12:39 AM   #5
spshultz
Member#: 1415
2005 OBS 3.0R
'12 SantaFe
Been using ABS on mine for about 20,000 miles. No problems at all.
spshultz is offline   Reply With Quote
Old 11-18-2003, 10:27 PM   #6
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
sorry
Old 11-18-2003, 10:30 PM   #7
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
The only thing used, rotary tool and one 90* male-female and a 45* male female
Old 11-18-2003, 10:31 PM   #8
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
"Bore'd" out airbox to fit pipes.
Old 11-18-2003, 10:35 PM   #9
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
I ended up hacking half of the connection of the first pipe on the female as the panel filter didnt not fit over it smoothly, just a little bit, and I connected the last pipe from under the fender.
Really it was one of those "I'm bored" works. It makes a somewhat cool induction sound at 2500K rpm, or maybe it was there the entire time?
Final product (before cleanup)
Old 11-18-2003, 10:41 PM   #10
That Guy
Member#: 23212
2002 Impreza RS
Dude! I am so doing that this weekend!
That Guy is offline   Reply With Quote
Old 11-18-2003, 11:24 PM   #11
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
And I should add it was a 3" diameter.
WTT: Zerosports Intake tube for Perrin or Silicone tube WRX_scott Private 'Wanted' Classifieds 0 04-28-2007 06:25 AM
WTT: Zerosports Intake tube for Perrin or Silicone tube WRX_scott MAIC Private Classifieds 0 04-28-2007 12:55 AM
wtb: Intake tube for RS ccroach Private 'Wanted' Classifieds 0 01-01-2005 06:07 PM
('93-'01) Need tubing for intake. dbrown Impreza Forum 4 05-16-2001 12:21 AM
2.5" tubing for intakes (solution possibly) impRSa01 Normally Aspirated Powertrain 4 02-23-2001 05:17 AM
