Old 11-17-2003, 07:51 PM   #1
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Axis 2.35L,6-speed,ect
Default Need Some Advice on Just bought a BLOCK and need some advice ....2.0,or 2.2???
Ok i need some advice from some of you knowledable subaru guys...
Ok i just bought a stock wrx block and want to build off of it.. I dont know what to do as far as displacement... i dont know if i should build a 2.0,or 2.2..
My goal is 11.5's and i will be using an APS SR-50 to get me there.. I do not want to spray on it but will probably be using water injection most likely....
Do you think i should stay with the 2.0 and build that or go with the 2.2.. I most likely will be running JUN cams, ported out heads,valves,springs,retainers, ect....
I am going to have it sleeved for sure but dont know which one to go with.. Also i dont know if i should stroke it or stay with stock stroke...
I want it to be able to handle really high boost, with no proublems..
Let me know some opinions on this subject i would really appreciate any info you can give me.... thanks, ERIC
BLUETURBOWRX is offline   Reply With Quote
Old 11-18-2003, 05:37 AM   #2
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Subaru Stars
Any opinions??
Old 11-18-2003, 09:11 AM   #3
cjm04WRX
Member#: 37101
2008 WRX
Default Re: Need Some Advice on Just bought a BLOCK and need some advice ....2.0,or 2.2???
SR/50 is a good turbo that will make power. On stock displacement and stock compression i think this turbo is the wrong selection. I would look to do at least a 2.2 and up the compression. That should decrease the lag on the SR50.
Talk to Darton Sleeves. They make a very nice sleeve for the EJ series engine. But I think the minimum bore size they offer is 97 mm, But you can bore up to 105 mm with those sleeves. I'm pretty sure those are the correct #s. I just checked a few weeks ago.
Look for using a Cometic head gasket and ARPs or some other head stud. Although the Subaru Head bolts appear to pretty strong, I would hesitate to use them in high boost situations.
I would look to use Ross Pistons from Magnus or CP Pistons from Ron at Axis. Those seem to have netted nice results. As far as rods are considered. Go Big. Pauter or Carillo are both very good choices and are very strong.
Chris
cjm04WRX is offline   Reply With Quote
Old 11-18-2003, 05:19 PM   #4
rex65
Member#: 34280
2003 WRX-Cobb II
I would get a 2.5 shortblock.
Search the forum. I was reading that you can get a new one for $1500.
Stroking and/or boring the 2.0 will cost some $$.
The cheapest reliable way to power is more displacement.
rex65 is offline   Reply With Quote
Old 11-18-2003, 05:52 PM   #5
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
MJU1983 is offline   Reply With Quote
Old 11-18-2003, 06:01 PM   #6
M32WRXin3seconds
Member#: 36797
word, go to 2.5L its just easier and cheaper. more power from the displacement and i'd believe less lag and larger turbo possibilities. xs engineering 500 or whatever you can get your hands on...i guess sr50 is the same basically, its all relative. when i have the funds 2.5 is hat will be in my piece of junk
M32WRXin3seconds is offline   Reply With Quote
Old 11-18-2003, 06:14 PM   #7
STEALTH-WRX
Member#: 7822
Multi layer snot green
Theres no replacement for displacement.
STEALTH-WRX is offline   Reply With Quote
Old 11-18-2003, 06:51 PM   #8
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
I have heard that a million times...LOL
Old 11-18-2003, 06:54 PM   #9
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
I already bought the block so im gonna stick with that.. I just wanted to have some opinions on what path to go with it..
I will probably go with the 2.2 but would love to hear some more opinions on this subject..
Thanx again for the feedback guys, keep em commin
Old 11-18-2003, 06:56 PM   #10
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
buying a 2.5 is almost definitely cheaper and better than making a 2.5. Also the only thing you do is buy it and bolt it up...dont have to worry about all the fabrication and problems/gremlins that will pop up.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 11-19-2003, 12:58 AM   #11
doogie1
Member#: 46149
2002 wrx STI HYBRID
wr blue
If you get the 2.2L block then you would probably need to replace the pistons to up the comp ratio,( if i remember right the combo with the wrx heads gives a low ratio of about 7.4:1 maybe lower) and while you're there change the rods too..... the block can handle about 20psi in stock form and definately more with upgraded internals. Where as the 2.5L bolts to the wrx heads with a slightly higher comp ratio (maybe 8.7:1) which would be good even without a lot of boost, but if you're planning on lots of boost you'd definatley need to change the pistons on that to lower the comp ratio but the actual block is not as strong as the 2.2L block coz its semi closed and the 2.2 has a closed deck, So it all depends on what you're trying to accomplish. Hope this helps
doogie1 is offline   Reply With Quote
Old 11-19-2003, 10:18 AM   #12
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Assume you wanted a high rev'ing monster.
Don't stroke it, if anything have the rods/pistons designed to offset the wrist pin so that you slow the piston DOWN.
I'd honestly take that shortblock to magnus, spend the 3k for their stage 3 sleeved block, and enjoy.
It'll be assembled professionally and it be ready to go.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 11-19-2003, 03:07 PM   #13
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
I would still like to hear some more opinions on this.. thanks,eric
Old 11-19-2003, 03:37 PM   #14
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
IMO, I am a sucker for torque... so >I< say stroke it..
But if you still want something that you can beat to snot, Marco and co has shown some pretty compelling work.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 11-19-2003, 05:24 PM   #15
oldmansan
Member#: 17877
Midnight Pearl
Default Please tell me what the
stage 3 includes. I see the prices, but no details of what it is. Thanks.
San
oldmansan is offline   Reply With Quote
Old 11-20-2003, 03:25 PM   #16
oldmansan
Member#: 17877
Midnight Pearl
Default BUMP
San
Old 11-20-2003, 03:38 PM   #17
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
I like the 2.2L block it has thoes oil squrters, and drop in a ver8 crank. Good tq and will still rev.
Old 11-20-2003, 03:51 PM   #18
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
No motor No Trans :-(
Or how about i-speed they do some pretty sick build ups
http://www.i-speed.us/home/
marios03wrx is offline   Reply With Quote
Old 11-20-2003, 03:58 PM   #19
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
stage 3 magnus = rods, pistons, liners, etc.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 11-21-2003, 01:02 AM   #20
oldmansan
Member#: 17877
Midnight Pearl
Default Do I supply the block for
the Magnus Stage 3?
San
Old 11-21-2003, 09:52 AM   #21
Depeche
Member#: 33650
3005 Ford
Thundercougarfalconbird
nice to see some more work in the works for the car eric!
--Josh
ps don't forget, i get your sr-40
Depeche is offline   Reply With Quote
Old 11-22-2003, 02:38 PM   #22
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
hey wuz up josh, man dude i got like 20 people that want my sr-40 its gonna be hard to just sell it to one of you... --eric--
Old 11-22-2003, 03:22 PM   #23
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
For everyone out there thinking he's buliding a 2.2 - it looks like he actually has a stock EJ205, and he wants to build it out. I know that lots of you will have spotted this, but he's not talking an EJ22. If you want to build this and run 11's sans spray, I'd definitely send it off to someone who knows what they're doing to build up the block. It seems Magnus is a great choice.
Of course, for that price ($3K), you can also just about buy an EJ207 type RA longblock, sell the 205 shortblock, sell the 207 long-block components you don't want (up, turbo, injectors, TMIC, etc.), buy a JDM ECU and you'll have much better cams, AVCS, forged internals, a good port job that handles lots of air and a redline of at least 8500. You'll spend a bunch less than you would on a magnus/self build out and be able to make serious power with at least some low-end torque for getting to and from the track. Let's see:
Buy (I'll use expensive prices):
Sti type RA longblock: $4000
Type RA ECU: $600
Sell (I'll use cheap prices, and not count your current parts):
WRX shortblock: $500
Sti injectors: $200
Sti TMIC: $300
Sti RA turbo: $300
So, not counting selling your current parts, you'd be out $3300 using the highest and lowest estimates, respectively, I could figure. You'd have the block, heads, cams, AVCS, forged internals, etc.
Or, you could spend $3000 for a Magnus workup, $1000+ for cams, lifters, etc, big money on head work, and still not have as much core to sell off. I'm not saying option two wouldn't be better in many aspects, but option 1 looks pretty darn attractive.
-Sean
big_adventure is offline   Reply With Quote
Old 11-22-2003, 04:20 PM   #24
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
I'm not sure how much axis would charge for a short block, but they are worth calling for the head work.
IA Performance is offline   Reply With Quote
Old 12-21-2003, 12:49 AM   #25
MJU1983
Member#: 14364
blocks are priced for everyone...
from 1325-5000 $ just depends what you want to do and how much money you want to spend.
-mike
Just bought an '84 gl turbo and need some advice. PrivateIdaho 'Old School' Subaru Forum 6 04-07-2010 11:08 PM
Just bought a porter 7424... need some help jdubya301 Car Care & Detailing 52 05-20-2008 07:26 PM
*WTB: STI short block, JDM 2.0 or USDM 2.5 Lam Private 'Wanted' Classifieds 5 02-14-2008 06:42 PM
*WTB: STI short block, JDM 2.0 or USDM 2.5 Lam VIC Private Classifieds 0 02-11-2008 11:38 PM
Just got a 2003 WRX, need some advice (not upgrades, just tips) faceplate Newbies & FAQs 6 08-22-2002 08:52 AM
