Vancouver Impreza Club
Old 11-18-2003, 02:55 AM   #1
bwco
Member#: 44137
Default I topped up my clutch fluid today and...
Yeah, I found out that my clutch slave cyclinder was almost empty a few days ago. And I was driving so cautiously just because of that empty clutch fluid slave bottle. But After adding 1/3 bottle of dot3/4 brake fluid in it. My clutch actually performed better. I'm not sure if there was a real effect or it's just something in my mind.
So, whats the use of the clutch slave cyclinder?
Anyone know how to use the speed bleeder? I wanna pick one up from PDM.
again, if my chingrish bothered you, please don't reply ! I knew my engrish sucks big time. All i learnt in Canada was graphs and numbers... etc... never took ESL before ! thats why !
bwco is offline   Reply With Quote
Old 11-18-2003, 10:25 AM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Default Re: I topped up my clutch fluid today and...
I think you've got your cylinders mixed up in your identification. Your slave cylinder is the cylinder on your transmission and you can't really tell how much fluid is in there. Your master cylinder is on your firewall and that's where you add more brake fluid.
As long as your master has fluid up to the required mark, you'll be fine. If you add fluid without bleeding your hydraulic clutch, it isn't going to do that much good. If your master cylinder is nearly empty, then that's a sign that something is truely wrong - there's a possible leak somewhere! Hydraulic fluid doesn't exactly "disappear" in a closed system. It has to go somewhere.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 11-18-2003, 02:00 PM   #3
tora
Member#: 5851
09 Forester XT
+ NA Miata
BwCo, your English is just dandy, don't worry about it.
The purpose of the slave cylinder is to depress the clutch pressure plate by using hydrolic pressure which comes via the clutch master cylinder. The ratio between the master cylinder and the slave cylinder determines whether you have a soft or hard clutch....or right in between!
tora is offline   Reply With Quote
Recommend a shop to change my clutch fluid streko Bay Area Impreza Club Forum -- BAIC 8 01-21-2007 06:42 PM
Can I flush my clutch fluid with a motive power bleeder? jet8300 Service & Maintenance 5 10-06-2006 05:04 PM
Gunk Or Silt In My Clutch Fluid Reservoir exhacker Service & Maintenance 16 03-01-2005 07:22 PM
So I changed my clutch fluid yesterday... Necromancer Vancouver Impreza Club Forum -- VIC 9 05-04-2004 08:16 AM
('93-'01) Help! I had my ACT Clutch installed today and... LongIsland RS Impreza Forum 13 05-20-2001 03:05 PM
