Old 11-18-2003, 01:45 PM   #1
Blindeye_03
Member#: 4418
2008 S2000
Default P0136
I recently went catless (stock cat-back w/ gutted cats) and wired in a MIL eliminator w/ the second O2 sensor.
Why would I get this code? Could it be the solder came undone on the Mil Eliminator or that my 02 sensor went bad?
thanks,
-justin
Blindeye_03 is offline   Reply With Quote
Old 11-18-2003, 02:20 PM   #2
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
I had the same problem. The problem is that your wires have come apart, or you didn’t connect the wires correctly. That code you’re getting means that the rear 02 sensor is not getting a signal at all. The MIL is just for a 420 code (low-efficiency). Take off the 02 sensor and see what’s going on, I’m almost sure it’s not getting a signal.
AndyM is offline   Reply With Quote
Old 11-18-2003, 02:36 PM   #3
Blindeye_03
Member#: 4418
2008 S2000
How bad is it to keep driving around like this for say a week?
Im not in a great 'condition' to be working under my car right now (had surgery in my mouth)...its bad enuff to be changing the oil today lol.
-justin
Old 11-18-2003, 04:51 PM   #4
AndyM
Member#: 3219
WR Blue Pearl
honestly I dont know? If it was me I would still drive but if I noticed my car running funny I would not drive it any more till I fixed it.
I think the rear 02 is just to monitor the temp in the car and really dosent effect anything...thats just me
When my CE light came on I was driving on the highway it was the same code yo got, my car was running normal even the day after...I didnt fix it until 2 days later, everything was fine
Old 11-18-2003, 06:25 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
the rear 02 sensor is there to monitor cat efficiency.
You can drive it.
I have seen problems with the rear 02 sensor wires chafing on the heat shields.
like andy said inspect the sensor and the wires, Might be something very obvious.
Jay
Old 11-18-2003, 06:43 PM   #6
Blindeye_03
Member#: 4418
2008 S2000
What is weird is I wrapped that sucker TIGHT with electrical tape after soldering the MIL Eliminator w/ it.
As long as it isnt 'bad' I dont have to spend more money .
The guy at the autozone was saying it was under warranty...HAHAHA he was nice and everything, but warranty isnt going to cover jack w/ a hacked up wiring harness .
-justin
Old 11-18-2003, 09:52 PM   #7
Layman
Member#: 3717
MKV GTI - tite!
bikes with pedals
-justin
Can't be all THAT bad - my car doesn't seem any worse for the wear after about 2 years of that code.
Layman is offline   Reply With Quote
Old 11-18-2003, 11:10 PM   #8
AndyM
Member#: 3219
WR Blue Pearl
see thats what I did I took of all the type wiring loom and found one of my connectors that I used was loose, took my time installing the MIL and havent had a CE light yet (knock on wood)
Old 11-19-2003, 12:04 AM   #9
Blindeye_03
Member#: 4418
2008 S2000
the wires are just so short + the wires on the o2 sensor are like bend resistant .
Looks like the electrical tape will be used again to cover up the CEL till I have time to yank the sensor.
-justin
P0136 with mileliminator ???? Jerry Factory 2.0L Turbo Powertrain 0 03-18-2003 07:31 PM
P0136 after driving hard for an afternoon DeusExMachina Normally Aspirated Powertrain 0 03-18-2003 08:00 AM
P0136 fix rodzilla Factory 2.0L Turbo Powertrain 3 03-04-2003 06:27 PM
P0136 CEL after Clutch install 02GatorWRX Factory 2.0L Turbo Powertrain 0 11-09-2002 12:08 PM
mbc killing front o2 sensor, p0136 code? datdudedennis Texas Impreza Club Forum -- TXIC 4 09-13-2002 02:43 PM
Message Board Statistics All times are GMT -4. The time now is 01:55 PM.
