Old 11-18-2003, 03:23 PM   #1
I_smoke_hondas
Member#: 47755
Question MRT header/high flow cat
I have my mind set on buying a set of MRTs tuned length headers and high flow cat combo but have one concern about emisions. Not worried about CEL since I am OBD 1. Will a high flow cat burn off enough CO to pass or will I have to be swapping exhausts like crazy just to be "legal"?? What a bummer it would be if these aftermarket companies made things that would keep a vehicle from being legal...
I_smoke_hondas is offline   Reply With Quote
Old 11-18-2003, 05:58 PM   #2
Snagtastic
Member#: 43809
It should, in fact, i believe that even most cars with high flow cats and if properly tuned motors will pass in even California.
Snagtastic is offline   Reply With Quote
Old 11-18-2003, 09:14 PM   #3
rbehny
Member#: 1908
It all depends on what type of cat is used. The stock system has two cats, each does a different job. I honestly don't know what type of cat is in the MRT but if i were to make an exhaust i'd put the one that matters the most to pass emissions. But thats me.
rbehny is offline   Reply With Quote
Old 11-18-2003, 10:32 PM   #4
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I've passed the MA emissions testing, I know people have passed the CT testing, how strict is CO's testing?
AO
m750 is offline   Reply With Quote
Old 11-18-2003, 10:40 PM   #5
Keith Cournoyer
Member#: 16764
Default MRT Header
I also passed in Massachusetts! So you should'nt have a problem. Is this for a 2.2 or 2.5? Good Luck, Keith
Keith Cournoyer is offline   Reply With Quote
Old 11-18-2003, 11:30 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
AFAIK, CT's standards are (or were, before they reorganized things a year or so ago) very close to if not the same as CA's standards. Since everyone knows CA is the Smog Nazi Capitol of the World, if the MRT setup passes there you should be good to go anywhere.
I have the header/cat combo on my car, but moved to HI before I ever had to get the car emissions inspected in CT again.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 11-19-2003, 12:26 PM   #7
I_smoke_hondas
Member#: 47755
Hey, thanks for all your input, guys...LOL Keith, I am putting these on my 1.8
It's a little monster already with short ram intake, pulley set, grounding mod and a few key suspension bits. I don't know what it is but it's got enough top end to keep up with nearly anything stock and suprise any of those ricers with 15 grand under the hood of their POS civics.. With a free flowing system all the way back, my mid-range will be devastating too so I don't care what happens to the bottom end cause it's pretty tourqey already
This perfectly describes the look on people's faces when I say: "It's only a 1.8, man"
Old 11-19-2003, 12:31 PM   #8
I_smoke_hondas
Member#: 47755
BTW- CO is not very strict w/ emisions. My car only has ONE cat and ONE O2 sensonr anyway, since it is OBD 1 and Subaru didn't change this until '97, I believe. Also the stock piping on these first few years is only 1.8" which is 1.5" inner diameter!!!!
Old 11-19-2003, 10:51 PM   #9
Keith Cournoyer
Member#: 16764
Default MRT/ emissions
Wow, 1.8, well there a lot lighter than most. I know what you mean by suprising a few cars. I have no problem suprising WRX's, RSX, Spec V and the like. The first two/three gears in the RS are real strong!! Good Luck, Keith
Old 11-20-2003, 01:24 PM   #10
Swano
Member#: 19114
2002 2.5TS
Blue Ridge
First, let me call the BS on that one.
Second, are you sure the 1.8 is dual port??
Phil =)
Swano is offline   Reply With Quote
FS-WI MRT header/high flow cat 2.5L N/A Benfolio Engine/Power/Exhaust 7 10-18-2008 12:37 PM
WTT: MRT 3" high-flow catted turboback exhaust phlegmon Engine/Power/Exhaust 0 04-17-2008 07:15 PM
WTT: MRT 3" high-flow catted turboback exhaust phlegmon MAIC Private Classifieds 0 04-17-2008 07:05 PM
N/A MRT Header, High Flow Cat Exhaust System FatCatTurbo Private 'For Sale' Classifieds 6 09-07-2004 03:27 PM
headers + high flow cat worth it? Kazushi Normally Aspirated Powertrain 3 01-02-2003 08:53 AM
