Old 11-19-2003, 12:08 AM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Question E-Manage tuning tips and maps
Ok I need some help tuning my E-Manage. Right now, I'm still using the RRFPR to keep the car running, but I plan on taking that out soon and replacing it with 440cc injectors. How do you guys suggest I tune for this? Just use the air flow adjustment map to take out fuel and leave everything else alone? Take out some timing that will be added due to the lower air flow the ECU is going to see? Is there any reason I should use the additional injection map? If anyone has a map with a similar setup, I wouldn't mind taking a look at it.
Here's my setup on a 2000 RS:
VF30 running 5 psi at the wastegate
3" turbo back, no cats
440cc RC injectors with WRX fuel pump
JC Sports TMIC
I have all the E-Manage harnesses and the pressure sensor
lotusTT is offline   Reply With Quote
Old 11-19-2003, 12:40 AM   #2
OKRS25
Member#: 36533
2005 STi
If you have the pressure sensor just adjust your AF map based on pressure. The additional injector map is if you have added some injectors to your system. And probably wouldn't hurt to pull a little bit of timing. I have a map you can look at to see some good areas to pull the timing from, but no maps that use a pressure sensor since I have yet to get one.
Kyle
OKRS25 is offline   Reply With Quote
Old 11-19-2003, 01:26 AM   #3
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
How can you adjust the air flow map based on pressure? I thought it could only do RPM vs throttle position. And the additional injection map is for adding fuel by changing the duty cycle with your normal injectors, the sub-injector map is for extra injectors.
Old 11-19-2003, 01:43 AM   #4
Unsung Boxer
Member#: 37196
I think it is an option that only becomes unlocked once you switch to the "Greddy Pressure Sensor" then you can adjust the map that way...
I could be wrong, im still not good w/ my emanage
-Jake
Unsung Boxer is offline   Reply With Quote
Old 11-19-2003, 02:20 AM   #5
OKRS25
Member#: 36533
2005 STi
AR on your tool bar is the Air fuel ratio that adjusts fuel delivery by editing the voltage reading your ECU receives from your Air sensor your actual injectors.
Inj on your tool bar is where you can adjust the aditional duty cycle by pressure. When you click the little blue car and select the greddy pressure sensor you can adjust the aditional duty cycles based on Pressure.
As I said I haven't gotten my pressure sensor yet, trying to get my hands on one right now because I want all my fuel delivery to be based on pressure and not airflow adjustments and the TPS sensor.
Kyle
Old 11-19-2003, 02:21 AM   #6
OKRS25
Member#: 36533
2005 STi
PS, as far as we have been able to find, the AR setting is the only place to actually remove fuel.
EJ22T on E85: Tuning tips and tricks. HamFist Pre-2002 Factory Turbo Powertrain 25 05-16-2009 09:29 AM
DeltaDash user tuning and map switching (02-03) $150 wrxtool SCIC Private Classifieds 3 04-13-2008 10:56 AM
Knock Control and Tuning Tips Jason-STI Open Source Reflashes 86 04-07-2008 04:55 PM
FS: PA utec with 4 tuned maps and map selector switch whitesti04 Engine/Power/Exhaust 5 04-27-2007 08:53 AM
WRX Cobb AP Users New Maps and Map Management Software!!! Sports Wagon South East Region Forum 34 06-15-2005 01:26 PM
