Old 12-12-2003, 09:56 PM   #26
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Commmon problems:
Side seat belt has no holder, falls into door seam
Clip for lap belt rubs on center console
Seat height is different enough to cause uncomfortable driving (especially if you get non height adjust seats)
Anyways, I swapped 97 Legacy GT seats into my 90 Legacy LS keeping the 97 rails. The rails bolted fine. I had some seat belt issues so I decided to use the 90 rails with 97 seats. The 90 rails where a little shorter so I dremmeled the front and was able to bolt them to the 97 seats. I then dremmeled out two holes on the outside of each seat to connect the lap belt holder to the side. If you need specifics please ask.
I plan to take the 97 Legacy GT seats out and use 91 Legacy Turbo seats instead. The second generation Legacy seats aren't designed as well as the first generation units. Comfort is far higher with the older seats. I ESPECIALLY like that some first gens have Vertical AND Horizontal adjustable head rests
cybin: Your overly worried. You dont mind driving a vehicle with 15 gallons of extremely flamable liquid but you want to take out the HEAVILY regulated air bags that have never just deployed for no reason?
Old 12-14-2003, 04:51 AM   #27
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Angry
I'm still kicking myself for picking the V8 over the V7 to install on my MY00 - I should have been driving in the STi seats starting late September...
kgb is offline   Reply With Quote
Old 12-28-2003, 09:51 PM   #28
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
I'm looking for info on swapping height adjusters on JDM seats from my drivers seat to the JDM passenger seat so I can keep my adjustments.
I looked for Imprezer info on it but that too long ago and i couldn't find anything.
byron
byroll01 is offline   Reply With Quote
Old 12-30-2003, 02:54 PM   #29
cybin
Member#: 48667
Not true. People have been hurt badly by airbags going off. The warning label even states that they can go off accidentally. Emergency workers have been hurt when they try to cut though the car and hit a side impact airbag. I drive with the gas becouse I have too, No sense driving around with airbags that are not hooked up.
Anyway heres one website with more info.
http://www.airbaginstitute.com/page573219.htm
cybin is offline   Reply With Quote
Old 04-14-2004, 04:54 PM   #30
Timdog82001
Member#: 21581
2004 WRX Wagon
What about the Spec C Sti seats....I would love to put a set of those in my 2000 RS Coupe. Will those fit? I think those are '03...not sure though
Timdog82001 is offline   Reply With Quote
Old 08-18-2009, 01:30 AM   #31
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Hey lookie here.
A thread. Anyone know what seats can fit in a GC?
Can STi seats fit in the stock L brackets?
Smoke is offline   Reply With Quote
Old 01-21-2010, 02:54 PM   #32
95preza
Member#: 233965
2011 WRB WRX
2000 Impreza L
Default Outback rear seat into Impreza Sedan???
Would it be possible to swap a 98 Outback rear seat into my 95 Impreza sedan? Ive never seen the inside of an Outback so I have no idea, if they wont fit, would the seat cover swap?
Thanks for any help!
95preza is offline   Reply With Quote
Old 02-05-2010, 08:39 PM   #33
junkyardgabe
Member#: 130968
09 Forester XT
Red
has anyone put 08-09 wrx seats in a 07 and older wrx?
junkyardgabe is offline   Reply With Quote
Old 10-26-2010, 03:21 PM   #34
sha_zapple
Member#: 41012
1998 Legacy L
Bump from the dead. Might be common knowledge but...
2002/2003 WRX Sedan Front and Back seats will fit in a 95-99 Legacy Sedan.
A couple of notes though: You have to use your Legacy seat belt clip and a spare nut/bolt. The lowest position of the WRX seat is only slightly lower than the highest position of the Legacy seat. Only 4 of 5 front seat bolts line up. The rear seats fit well although there is a slight gap so you can see the top of the strut from the rear triangle window. Despite this, it's worth it, the stock Legacy seats are crap!
Now, which year WRX Wagon seats will fit a 2004 Impreza wagon? I assume: 2002-2007 Front will fit, 2002-2005 Rear will fit? Anything else?
sha_zapple is offline   Reply With Quote
Old 09-08-2011, 02:42 PM   #35
Type2
Member#: 200436
2004 Forester XT
Another bump from the dead.
I am looking to see what needs to be done to swap a 2003 WRX wagon REAR seat into my 1995 L Wagon.
Does anyone have any experience with this?
Type2 is offline   Reply With Quote
Old 03-03-2012, 12:22 PM   #36
yogie02rex
Member#: 299654
What year sti seats will fit in a 2002 wrx?
yogie02rex is offline   Reply With Quote
Old 03-09-2012, 07:26 PM   #37
SplatWRX
Member#: 85932
2005 STi / 2013 STi
2005 Forester XTi
02 to 07 STi seats will fit a WRX
SplatWRX is offline   Reply With Quote
Old 03-16-2012, 05:54 PM   #38
79letour
Member#: 302570
2013 XV
DGM!
So- my 2012 Impreza has seats that I just dont find comfortable. Plus I keep hearing a sqeaky spring sound from the backrest shoulder area. SOA is supposed to be fixing it but the noise is intermittent so its hard to replicate on command.
I really like this car other than the seats. I've driven Legacy's and find their seats to be much firmer and more supportive.
Would Legacy seats fit/work in an Impreza? And also what to do about the side airbag?? Any help or suggestions would be great. Thanks.
79letour is offline   Reply With Quote
Old 04-22-2012, 09:08 AM   #39
warhamster
Member#: 317671
can anyone advise is 2001 impreza rs seats will bolt in to my 1992 subaru loyale? Thanks
warhamster is offline   Reply With Quote
Old 05-01-2012, 02:13 PM   #40
subieguy87
Member#: 153412
1998 Impreza wrxRS
I beat all the 'it sits higher' complaints
02/03 seats
Ver6 bottom foam
Stock 98 rails
And my harnesses remedy any seatbelt issue I have
subieguy87 is offline   Reply With Quote
Old 10-23-2012, 12:39 AM   #41
sub_sifu
Member#: 301690
2002 Wrx
bump from the dead yet again. I've been told 02 and 03 wrx seat belts may be different...although I'm having a hard time believing it. can anyone substantiate this claim? Can I use 02 buckles with 03 wrx belts?
sub_sifu is offline   Reply With Quote
Old 03-25-2013, 11:05 PM   #42
thomasubi
Member#: 338934
1998 Impreza L Wagon
Red
Will 2000 2.5rs coupe seats fit a 98 impreza wagon L?
thomasubi is offline   Reply With Quote
Old 03-28-2013, 10:47 AM   #43
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Impreza GC8
The back seat will have to be modified a bit, but yes.
4wdrift is offline   Reply With Quote
Old 04-16-2014, 11:21 AM   #44
R_matt_6
Member#: 336149
2002 Impreza OBS
Will 2011 WRX seats fit into my 2002 Impreza Outback Sport?
R_matt_6 is offline   Reply With Quote
Old 10-04-2014, 07:11 PM   #45
Bassmaster1
Member#: 403148
Default Seat swap
Does anyone know if 2008 Subaru STI front seats will fit on a 2004 Forester XT with no modifications? Are the bolt patterns exactly the same?
Bassmaster1 is offline   Reply With Quote
Old 01-31-2015, 05:19 PM   #46
KitchenerWRX
Member#: 79934
02 WRX
MBP
Will 2013 STi front and rear seats bolt into an 02 wrx??
KitchenerWRX is offline   Reply With Quote
Old 02-01-2015, 12:46 PM   #47
FlippyMar
Member#: 291626
2007 WRX
Pearl White
Question
I've been searching and haven't found a for sure answer yet.
Does the 07 WRX Wagon seats fit into the 07 WRX Sedan? I would really like to have some fold down seats instead of the silly pass through.
FlippyMar is offline   Reply With Quote
Old 02-12-2015, 02:52 AM   #48
Redsun.Ronin
Member#: 371840
2006 Forester
I see wrx's, legacy's, etc...but no forester's.
So, will a 2011 WRX seat fit in a 2006 Forester?
Redsun.Ronin is offline   Reply With Quote
Old 02-16-2015, 04:17 PM   #49
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
Lots of unanswered questions in this thread. I'll try to help with a few.
Originally Posted by Smoke View Post
Hey lookie here.
GD STi seats will fit in GCs using the GD rails. They will sit higher. The L rails do not fit on the STi seats. Conceivable you could use the bottom portion of the L sliders with the top portion of the STi sliders, but there is a big lump of metal that has to be drilled out to make this work. I may try this sometime as I have STi seats in my 94 Impreza Base (L predecessor) and I am tall so my head hits the ceiling with my helmet on. Also, I used the buckles from my 94 seats in place of the STi buckles as they are different.
I have also read that you can use 2001 Legacy brackets on the STi seats to make them fit lower in the GCs. I will try this when I can find a Legacy at the junkyard with these brackets. Went yesterday but they didn't have any.
02/03 seats
Ver6 bottom foam
Stock 98 rails
GC rails work on the bugeye seats, which I believe are the same as the SAAB seats.
For what it's worth, the bugeye seats are incredibly more comfortable and equally as bolstered as the GD STi seats, IMO. They just don't look as nifty as the STi seats.
No.
Front belts are the same. Rear buckles are different for 04+ if I recall correctly.
No. The sedan and wagon rear seats mount very differently on both the GCs and GDs. GD sedan seats will fit in a GC with a little persuasion (I have 04 STi rears in my 94 impreza). I don't know if GD wagon seats will fit in GC wagons. But swapping between wagon and sedan is not a bolt-in affair.
Edit: This is from my build thread on another forum to show the difference in the 94 buckle vs. the 04 STi buckle:
Originally Posted by Seahawk View Post
Yesterday I got the car back together and ready for inspection.
When swapping in the front seats I had to swap over the buckles from the 94 seats.
Here's the STi buckle and the 94 buckle (top). Just swap over the bolt and hardware from the STi buckle and they work just fine.
Seahawk is offline   Reply With Quote
Old 02-16-2015, 11:02 PM   #50
snowmanwithahat
Member#: 328283
2004 STi
Resurrecting a thread for us GD STI owners. Will the newer 2008+ STI seats fit into our STIs? I'm looking for something a little more mature for the interior (i'm really tired of blue in my silver STI).
Since the 2008+ have a nice black finish I really want to swap those in and WRX carpet (black) along with a black WRX back seat (or 2008+ STI). Has anyone performed a swap like this?
snowmanwithahat is offline   Reply With Quote
Axle swap, what will fit? tooocool49723 Transmission (AT/MT) & Driveline 0 07-19-2009 09:27 AM
What seat belts will fit in an 01 wagon? imprzya Interior & Exterior Modification 1 05-12-2008 03:36 PM
what turbo is this? and what will fit in its place? kaneda3 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 02-06-2007 12:23 AM
What will fit in a 92' Legacy? CjHermsen Subaru Conversions 12 06-13-2003 04:16 PM
What speakers will fit in stock locations in WRX? boo Car Audio, Video & Security 0 04-17-2001 08:59 PM
