Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 11-19-2003, 01:15 PM   #1
bhkim126
Member#: 27142
Default Another UTEC map question
As some of you know, i've decided to take the VF-22 route. The 22 will be arriving this thursday and i'm planning on giving the install a try Friday. I've gotten a few base maps to start with, but the map i've chosen to use was tuned for 94 octane. Since we only have access to 92 octane, what changes should I make to the timing and fuel maps? Should I be lowering the values or
should I increase the values? Boost map will remain unchanged since im using the Blitz boost controller.
Brian
bhkim126 is offline   Reply With Quote
Old 11-19-2003, 10:54 PM   #2
bhkim126
Member#: 27142
I know someone knows the answer to this.
Old 11-20-2003, 10:23 AM   #3
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Are you using a base VF-30 map, or someone else's VF-22 map?
T-WRX is offline   Reply With Quote
Old 11-20-2003, 02:54 PM   #4
digitaltekniq
Member#: 18029
You're putting on a VF22 and you're not sure whether to reduce timing and fuel or advance it based on the fact that you are going from a HIGHER octane map to LOWER octane in your area.
You REALLY should read the manual and get comfortable with tuning the UTEC on the stock turbo before you start adding a big 'ole turbo....
In short you'll probably want to reduce timing a couple of degrees across the board not to mention some fuel trim adjustment. Do you have an EGT gauge, wideband? Or better yet, access to a dyno with a wideband?
digitaltekniq is offline   Reply With Quote
utec map questions blackrexxer03 UTEC 3 05-31-2007 03:59 PM
UTEC map question SubyDan05 UTEC 2 03-02-2006 07:44 PM
Quick UTEC map question. Pre-diddy Engine Management & Tuning 2 02-09-2005 06:19 PM
utec boost map question bstoehr83 Engine Management & Tuning 1 05-04-2004 11:41 PM
UTEC map question -regarding knocks and lean ndw1138 Engine Management & Tuning 4 02-25-2003 06:04 PM
