Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 11-19-2003, 06:07 PM   #1
turbocolin
Member#: 43539
95L 97L 03hedgehog
02 wag 180mph monster
Default best part for ej22
what is the best way to go for a nice power ej22 without turbo or nitrous
turbocolin is offline   Reply With Quote
Old 11-19-2003, 06:40 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
what year ej22? how much you want to spend?
how much more power you looking for?
Without severely getting into the internals of the motor and or reworking cams, heads, stroker kit......you're really not going to be able to get much more.
In all honesty.....if you can get 30 more hp with bolt ons, you're doing very very good IMO.
Legacy777 is offline   Reply With Quote
Old 11-19-2003, 06:58 PM   #3
Blindeye_03
Member#: 4418
2016 Focus ST
possibly the heads... there is nothing good about single exhaust ports .
-justin
Blindeye_03 is offline   Reply With Quote
Old 11-19-2003, 07:27 PM   #4
turbocolin
Member#: 43539
95L 97L 03hedgehog
how much are they and where can i get them
also who makes a good ecu for that engine
Old 11-19-2003, 09:17 PM   #5
linsavy
Member#: 11620
1997 GF4-STiV3 clone
You are better off swapping the engine. Depending on year a 2.5l will slide in nicely. Do some bolt-ons to it plus cams and you are up to 200hp. It would take a fortune to get 200 hp out of a 2.2l while staying n/a.
Head work, stoking, cams and pistons would all have to be custom.
An intake, borla header, high flow cat, catback with torque chip would get you 20 extra hp or about up to a stock 2.5l. A lighter flywheel and that's about as good as it gets.
Nobody has really done a build up on a 2.2l to my knowledge. I would love to see someone do one though.
linsavy is offline   Reply With Quote
Old 11-27-2003, 02:17 AM   #6
HomeSlice
Member#: 6081
MY93 Legacy
Sonora Sand ej22t
a cat josh mould built a n/a 2.2 he is on i-club.com
im still bolting on parts to my n/a till i have the dough to build the ej22t i have
HomeSlice is offline   Reply With Quote
Old 11-27-2003, 12:54 PM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
If you are starting with a non-turbo 2.2L, it is tough to find ANY performance parts.
Better would be a 2.5L swap as they have some more parts available.
But not knowing your year or model makes it tough to give advice.
Old 11-27-2003, 01:12 PM   #8
Snagtastic
Member#: 43809
-justin
They have 4-valve heads... its not an 8 valve motor.
I would contact Cobb and see what parts from the EJ25 match up. Im guessing the intake would at least, the exhaust system possibly, and the headers are a tossup but im guessing no.
If you wanted some serious flow you could always get some EJ25 Phase II heads and put some cams in them. I hear the worst problem with the EJ22 is the intake manifold which is more choked up than the EJ25 even.
The engine swap idea is always tempting but expensive.
If it was me I would figure out an intake, free up the exhaust system and look for an equal length header system (Borla= ). Then I would figure out a way to get the shortest gearing possibly through wheels/tires. Then I would get some underdrive pullies or a lighter crank pulley. Drop the air conditioning, strip the car of excess weight.
Basically your starting with a hampered powertrain, so you have to figure out a way to increase your power/weight ratio but cant really concentrate on the "power" section as much.
The Impreza L models with the 2.2 had longer gearing which hurt their performance also, you should really look to remedying this by staying away from 19" chrome wheels.
Gluck.
Snagtastic is offline   Reply With Quote
Old 11-28-2003, 12:55 AM   #9
HomeSlice
Member#: 6081
MY93 Legacy
Sonora Sand ej22t
fyi most parts interchange--- its like legos m8
Old 11-28-2003, 05:35 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
How many valves per cylinder has nothing to do with how many exhaust ports come off the head...The EJ22's found in the Imprezas have only 2 ports for all four cylinders. That's why you need these headers:
But since we still don't know which car he has, we can't be sure. I just learned the other day that older Legacies with a 2.2l engine have four ports...
Old 11-28-2003, 08:05 PM   #11
Legacy777
Member#: 4800
Not necessarily true.....the older imprezas 93 & 94 have pretty much the same engine as the older legacies.
!!ADVISE!!! Best parts for my ej20 build.. Boxer4h Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-17-2010 12:45 PM
Best plugs and wires for ej22? Zac86 Normally Aspirated Powertrain 4 12-12-2009 11:41 AM
best parts for 06 sti??? burtonrider3889 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 11-06-2007 12:51 PM
98 EJ22 used parts for sale mybluesubi Private 'For Sale' Classifieds 0 05-04-2004 07:31 PM
Best parts for NA build up Stroke Normally Aspirated Powertrain 7 04-09-2003 04:47 PM
