Old 11-19-2003, 08:56 PM   #1
Narso
Member#: 1442
1999 2.5 RS
Default Spark Plug Wire Problem
Okay, So my car has been idling rough for the last month or so. I finally opened the hood and took a look at the spark plug wires. 3 of the 4 seemed pretty good, but the wire for #4 had an ash-like stuff inside it and the conductivity was pretty far off from the other three. This will be the second time I've replaced the wires and I have about 97k miles on the car. What could be causing my wires to foul like that? I do have an underdrive pulley on the car, but that's really the only modification I've done to the electrical system.
Akso, I noticed that there was a bit of oil around a couple of the plugs. Is this something that should cause me to panic?
Thanks, Folks
Narso is offline   Reply With Quote
Old 11-19-2003, 10:48 PM   #2
m750
Member#: 2278
8Sti | 07 allez
White | Comp
If you haven't done wires it's just corrosion, just use can cause that. Wires are a wear item, I just replaced mine, they aren't that expensive, check out www.subaruwrxparts.com
As for the oil, it might just be anti seize put on them to make sure they don't weld to the heads...
good luck.
AO
m750 is offline   Reply With Quote
spark plug wires/ plugs reality1011 Normally Aspirated Powertrain 30 02-27-2010 10:09 AM
FS: STi spark plug wires for non-coil-on-plug turbo engines Necromancer VIC Private Classifieds 6 09-20-2009 12:35 PM
Problem with the spark plug wires colorfull Normally Aspirated Powertrain 7 05-02-2008 02:22 PM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
('93-'01) Are the spark plug wires the same for the Impreza 1999 to 2001 2.5rsMI Impreza Forum 0 06-11-2001 06:15 PM
