Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 11-20-2003, 12:43 AM   #1
roffle
Member#: 42251
uh oh
trumpet butt
Default MY97 EJ22 + CAI = Death?
I slapped a CAI on MY97 Impreza L and about 2 months after experienced lurching problems and twice it has stalled if I didn't warm it up properly.
I've been told by many sources that the 97 EJ22 isn't CAI friendly, but also that there are other options than removing it?
Help?
roffle is offline   Reply With Quote
Old 11-20-2003, 02:07 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
What kind of CAI?
Old 11-20-2003, 11:27 AM   #3
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
Did you rig up the MAF to the system? I've heard closed-system CAI setups that "ram" air into them can fool the MAF into thinking it's running lean and they tend to lean toward running very rich.
If you removed the MAF entirely, the ECU goes into a sort of "limp home" mode, just guessing at the A/F mix and usually guessing very poorly, running rich and killing power and fuel economy.
I've been thinking of trying to design a CAI for my MY98 EJ22, but I'm wary of all of the issues with the MAF. You have to be careful to give it a very smooth airflow and that you don't "ram" too much air into it or it will choke the engine.
Eric
StewedSquirrel is offline   Reply With Quote
Old 11-20-2003, 12:18 PM   #4
mattjb
Member#: 10762
1992 Mazda Miata
2005 WRX Crystal Grey
Eric
Very true. If you try to stomp it from a dead stop it'll choke every time.
mattjb is offline   Reply With Quote
Old 11-20-2003, 12:39 PM   #5
m750
Member#: 2278
8Sti | 07 allez
White | Comp
malarky... This happens becaust the air box is removed, and there isn't enough air in the tube to provide it. Hence why people say there is a loss of low end torque.
My theory on your problem, is most likely your maf, you prolly over oiled your cone filter, and are expierencing a flaky maf. Go to www.scoobymods.com and check out the maf cleaning / replacement procedure and see if it helps.
AO
m750 is offline   Reply With Quote
Old 11-20-2003, 04:20 PM   #6
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
Yeah...I have the same exact problem with my EJ22 and my K&N CAI...MAF blew out...I'm gonna try replacing the MAF sensor, and if that doesn't work, I'm gonna bite the bullet and put my stock airbox back on...
marcus12 is offline   Reply With Quote
Old 11-20-2003, 06:02 PM   #7
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
The CAI I had dreamt up for my EJ22 kept the airbox, branched off the airbox into a small pipe running upward, and angled toward the hood scoop. The MAF would be dropped in somewhere on this tube, then up to a high-flow filter, which is immediately underneath (slightly in front of) hood scoop. It would have an "airguide" to scoop cold air foward under the hood to the filter, which would have a few drains tubes in the bottom so that any water that needed to drain woudln't drip directly on the hot block.
I haven't measured it and I'm just running on memory of having about 6 inches of clearance between the top of the block and the underside of the scoop. I have a feeling the airbox or throttle body may get in the way of this installation... I'll measure it tonight.
Eric
Old 11-20-2003, 06:36 PM   #8
roffle
Member#: 42251
uh oh
trumpet butt
well I've never oiled my cone filter, Its only been on for 3-4mos, so.. I'll just put the airbox back on with the CAI I guess
I lose some grumble, but if it un-breaks my car then hooray
Old 11-20-2003, 07:03 PM   #9
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
In addition to being a new soob owner, I also am fairly ignorant of many of the nuances surrounding all the sensors on newer cars. In general, if the intake is going to be modded, is a MAP or a MAF more forgiving of the alterations? If one is better to have for modding, can that type be upgraded instaed of the 'bad' type?
just wondering
Carl
1 Lucky Texan
1 Lucky Texan is offline   Reply With Quote
FS: (HR) Subaru STi and WRX parts - exhaust, dp, uppipe, FMIC, UTEC, CAI, etc. azrakain MAIC Private Classifieds 71 06-02-2011 08:21 PM
MY99 EJ25 into MY97 EJ22..idle control help Murray Subaru Conversions 8 11-09-2010 07:47 PM
will a 96 EJ22 fit in a 97 EJ22 impreza?? mybluesubi Subaru Conversions 20 02-20-2004 03:47 AM
Why does older EJ22 have less power than new ej22? d4d4d4d4 Legacy Forum 16 12-25-2003 09:18 PM
Why does newer ej22 have more power than older ej22? d4d4d4d4 Engine Management & Tuning 7 10-09-2003 11:21 PM
