Old 11-20-2003, 03:05 AM   #1
m u f a s i s
Member#: 39817
2008 Evo X GSR
Rally Red
Unhappy Wierd clicking noise when...
I have a 2003 WRX, has bout' 16900 milez, mods are as followed: txs tbe, ic hoses, hacked intake, sti shifter bushing, blitz dtt. When im at a stop, and I put in first and let go of clutch, it makes this pretty loud click from the lower right engine bay. I need help ASAP. Thanks for any replies.
-Ryan
m u f a s i s is offline   Reply With Quote
Old 11-20-2003, 02:50 PM   #2
m u f a s i s
Member#: 39817
2008 Evo X GSR
Rally Red
PWN3D
w00t w00t, figured out the problem, oh yah and by the way, thanks for all the replies, you guys really helped me!
-Ryan
Old 11-20-2003, 03:51 PM   #3
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
*crickets*
What was it?
Old 01-07-2004, 04:41 PM   #4
Shikamaru
Member#: 49238
2004 WRX
WR Blue
I've sorta got the same problem, would mind explaining what you found?
Shikamaru is offline   Reply With Quote
Old 01-08-2004, 05:10 PM   #5
Shikamaru
Member#: 49238
2004 WRX
WR Blue
*bump* any ideas from anybody
It only seems to happen when I initially leave in first gear, sounds like someone flipped a light switch or something. The sound doesn't happen the rest of the time I'm driving around at all.
It's weirding me out.
Old 01-09-2004, 12:22 PM   #6
mugsy
Member#: 35301
2002 Impreza WRX
What was the fix. I have the same problem.
mugsy is offline   Reply With Quote
Old 01-09-2004, 01:25 PM   #7
cjm04WRX
Member#: 37101
2008 WRX
-Ryan
Wow thanks for getting back to everyone on what the problem was.
Chris
cjm04WRX is offline   Reply With Quote
Old 01-10-2004, 11:24 PM   #8
JayByRd724
Member#: 35183
02 WRX
Blackish Blue on 57pros
i also have the same problem...would like to know what you did
JayByRd724 is offline   Reply With Quote
Old 01-11-2004, 09:37 PM   #9
JayByRd724
Member#: 35183
02 WRX
would really like to know
Old 01-12-2004, 10:53 PM   #10
m u f a s i s
Member#: 39817
2008 Evo X GSR
Rally Red
Sorry I have no been up-to-date on this thread. I thought I figured it out but the fact is I havent. This sound really worries me so if anyone has any info please let us know. Thank you.
-Ryan
Old 01-15-2004, 01:28 PM   #11
mugsy
Member#: 35301
2002 Impreza WRX
Anything yet?
Old 01-15-2004, 01:53 PM   #12
Shikamaru
Member#: 49238
2004 WRX
WR Blue
Well let me ask this question, did anyone else notice this problem before it started getting real cold outside?
Old 01-15-2004, 06:52 PM   #13
that1guy
Member#: 26169
98 BLI
RBP
just noticed mines like a month ago...but you have to remember i live in cali...and it doesnt get that cold out here
that1guy is offline   Reply With Quote
Old 01-15-2004, 07:36 PM   #14
Imprezzed22
Member#: 38297
2003 wrx
midnight black pearl
i have the same noise . it started when it was cold outside . if i let the care warm after a few blocks of driving it will go away??? i dont know what it is but it does sound like a switch
Imprezzed22 is offline   Reply With Quote
Old 01-15-2004, 09:49 PM   #15
Shikamaru
Member#: 49238
2004 WRX
WR Blue
I posted this over at wrxforum.com also
here is my post
http://www.wrxforum.com/cgi-bin/ulti...c;f=3;t=005081
one of the guys seems to think it's the ABS doing it's self check once the car gets moving.
Old 01-16-2004, 03:52 AM   #16
m u f a s i s
Member#: 39817
2008 Evo X GSR
Rally Red
Default ....
Well first off some of the people on that threat are not describing the same sounds I'm hearing. The sound most occur's then it's cold outside, although it's done it when it wasn't cold out. Happens in first only from a stand-still, it's a loud click sound sorta metaly(is that even a word!?), lol. Get back please.
--Ryan
Old 01-16-2004, 12:17 PM   #17
JayByRd724
Member#: 35183
02 WRX
Mines doesnt no matter if its cold or not...does it sometimes in first...and most of the time in reverse...i will be taking my car to subaru on monday hopefully...will let you guys know whats up
Old 01-16-2004, 12:26 PM   #18
Merdock777
Member#: 21256
2002 Impreza 2.5RS
BlindYoAssPlatinumSilver
maybe??
here
DanO
Merdock777 is offline   Reply With Quote
Old 01-16-2004, 03:03 PM   #19
Shikamaru
Member#: 49238
2004 WRX
WR Blue
I wonder if I can find some sort of diagram of the engine compartment telling me what everything is and where. Anybody have anything like that? I'd like to know what components are in the general area of the sound I'm hearing.
Old 01-16-2004, 06:17 PM   #20
m u f a s i s
Member#: 39817
2008 Evo X GSR
Rally Red
Default ?
The sound really sounds like its comming from where the uppipe is, im not shure if this helps but the sound is very metal sounding.
Old 01-16-2004, 08:50 PM   #21
Unsung Boxer
Member#: 37196
does it only happen when you start moving? or when its in gear? or when its in gear but clutch in? we need this kinda info.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 01-16-2004, 09:23 PM   #22
Flat420
Member#: 35455
07 LGT Spec.B Stg2
Well, I'm trying to search for something similar to this, but here's what I've been getting...
When in any gear, but it's most pronounced in first, I get a solid metalic 'click' when I initially accelerate, if, and only if, the car has been sitting for a while or I've allowed the car to compression brake. In addition, I get the same click when compression braking in basically any gear. If I accelerate in first, then shift to 2nd, I don't get it, but if I'm in first up to 3k rpm or so, then let off the gas, I get it at the point of initial deceleration, then get it again when I give it any gas. I'm thinking it sounds like something's loose - I had thought a tranny mount, but the shifter has no play and doesn't move or give any vibration that's consistent with the click. It's definitely in the drivetrain though in my case.
Sound like what anyone else has?
Flat420 is offline   Reply With Quote
Old 02-20-2004, 01:06 PM   #23
Shikamaru
Member#: 49238
2004 WRX
WR Blue
Ok I was at the Dealer today getting the usual oil change and fluid fillings. Had them listen to the sound.
For those of you like me that want to know what it is
Again it's a Clicking Sound that only happens when you first turn on the car and go anywhere, but never happens again while you are driving.
The Mechanic who seems to be quite knowledgable told me it was:
The ABS System doing a self-test to make sure they are working properly, completely normal in my case.
Clicking noise when letting out clutch Cababah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 10-03-2009 11:15 AM
Weird bubbling noise when clutch pedal is pressed in? tobylazur Transmission (AT/MT) & Driveline 1 07-28-2007 12:58 AM
I have grinding when i put in first vvafivv Transmission (AT/MT) & Driveline 7 10-22-2006 06:05 PM
strange noise when let go of clutch in 1st gear pico Transmission (AT/MT) & Driveline 2 01-16-2004 04:35 PM
Weird winding noise when I let off the gas... Siper2 General Forum Archive 12 12-09-2000 09:15 AM
