![]() Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
#1 |
Member#: 29019
Vehicle:2012 Impreza WRX STi DGM |
Folks:
Just went to Walmart to have some tires mounted to my new Rota SDR wheels. I know...shoot me. Anyways, they f'd up one rim and couldn't mount the tires. Yeah yeah, shoot me again. Can anyone recommend a good shop in the DC Metro area that can mount my tires on to my rims and balance them? (without scratching them) Thanks in advance. Anonymouse20910 (A lil bit pissed)
#2 |
Street's closed, pizza boy
Member#: 17301
Vehicle:is the "dark side" 06 Evo #7 STU, 05 Saabaru |
Ye Olde Wheel Shop.
6363 Washington Blvd. Elkridge, MD They refinished my V7 wheels after they got scratched shipping, and then fixed one of them after NTB scratched it mounting a tire. They will not eff up your wheels. The only downside is that they're expensive and that they are in Elkridge (dunno where you live) Walmart should pay for the refinishing if they scratched it. NTB did. If Silver Spring is closer, take it to Radial Tire. They too have proven they can mount a tire without f'ing up the finish ![]() -john |
#3 | |
Member#: 29019
ButtDyno,
Thanks for the helpful info! I'm out in Germantown, but work in College Park. I might check out Radial Tire tomorrow. Quote:
#4 |
Member#: 8257
Vehicle:2004 STI Silver\Silver |
Curry's in ashburn, it may be a hike but the quality of work is worth it.
#5 |
Member#: 44935
Anonymouse20910,
Regardless of where you go to get tire/wheel work done in the future, ask about the equipment. Older shops, for instance, do not have the equipment to work on 17" or 18" rims. Other shops have equipment that can handles these wheel dimensions, but the machine might have a steel jaw mechanism that can scratch the wheels...instead of a rubber clamping system and polymer mount/demount heads. Also, after the wheel is repaired by a reputable shop, I would suggest taking the receipt to the store manager at Walmart (along with any documentation you might have from when the damage occured) and very politely explain what happend. I think you'll be amazed at what they will do to make you a satisfied customer. Good luck and I hope this helps. Regards, Bill Shaw |
#6 |
Member#: 14987
Vehicle:Gods Speed #57 Lemons/Chump #77 |
I have used Radial Tire for years. Never had a problem, they have a large selection of tires in stock (including R compounds) and they shave tires if you race. Highly recommended. There is a small shop nearby (Allen Automotive) that will do alignment (including custom specs if desired) for $75. They have experience with WRX and do a great job and have the latest and greatest Hunter (?) alignment rack. You may want to get an alignment if it has been a while and since you are putting new tires on. BTW, I have never used either but have heard good things about Ye Old Tire Shop and bad things about Currys.
#7 |
Member#: 17301
Just to be clear - when I said YOWS was expensive I meant for refinishing stuff (around $85 a wheel to do em from scratch). Mounting/balancing is the standard $15 a wheel I think.
-john |
#8 |
Member#: 44935
TubeDriver,
We obviously have at least one satisfied customer as evidenced by Poppa smurf's recommendation two posts ahead of yours. But before writing any further negative comments about Curry's, however, I would ask that you first come to one of our shops to see for yourself. I think you'll be pleasantly surprised at the level of customer service we provide to everyone who comes in and the quality of our work. I think that's only fair.Regards, Bill Shaw |
#9 |
Member#: 15528
Vehicle:2006 Aspen White 20G'd STi - Long Gone :^( |
I have had wheels(with cheap painted finishes) and tires mounted and balanced at Curry's and they did a very good job. They even asked me if the wheels would see track use, and used aluminum tape to re-inforce the weights...
#10 |
Member#: 29019
Thanks for all the responses fellas!
- TubeDriver Thanks for informing me about Radial Tire, I just dropped my tires and wheels with them - theyre only 10 minutes away. - Bill Thanks for the advise - very good to know. I started asking Radial Tire about steel jaw mechanisms etc and the guy smiled and said don't worry we wont scratch em. We'll see when I pick em up after work. I'm so glad these are only Rota's and not more expensive rims. I'm only using these for winter abuse so I'm not so concerned about the scratches, but it does piss me off that something new of mines was effed up by a so-called "professional." |
#11 | |
Member#: 14987
I have been to both your shops (dropping off a friend who needed to pick up a car). I know of several cases involving expensive engine damage were the owners felt it was Curry's fault. I know of one case were a dyno day was badly mishandled and a bunch of WRXs were detonating left and right due to inadequate airflow (fans). I know of a WRX that had it's fenders rolled by Curry's with significant paint damage to the fenders. There are at least two cases on this site were badly botched UTEC/Unichip tuning was done (running much too lean). These are all public knowledge, you can do a search here on NASIOC and find out about the complaints for yourself. Lastly, I understand that mistakes happen but a large measure of how I judge a shop is it's response in those situations. Curry's did not own up and fix the problem. Instead they sidestepped and denied any responsibility (while charging what might euphemistically be described as "premium fees"). Actually, I did have minimal contact when I was quoted $700 to install a set of Prodrive spring in a WRX. An e-mail to Curry's to confirm that silly price was not answered. Glad I just did it myself. Nothing personal but you mentioned one satisfied customer, do a search and you will find several dissatisfied customers.
#12 |
Member#: 17301
Please let's keep the Curry-bashing out of this thread...
Anyone who wants to learn about Curry's can do a search. -john |
#13 | |
Member#: 15528
Bad news travels fast, good news doesn't travel at all. So let me get this straight, the only dealing with Curry's you have had was that they quoted you a bad price? You are def. qualified to discuss their merits! ![]() |
#14 | |
Member#: 14987
I have MUCH MORE detailed information about the problems I mentioned. And as you so adroitly noticed, I clearly stated that my only personal dealing with Curry's is them quoting $700 to install a set of prodrive springs. On the other hand I mentioned a bunch of other cases, some of which were good friends of mine. So since you seem a big fan of Currys let me ask you a question. What kind of people ask $700 for a spring swap? What’s that work out to (7 hours of labor at $100/hour or 2 hours of labor at $350/hour?). This is pretty simple, a member asked opinions about a shop to do installs. Buttdyno posted a favorable opinion of Currys, I did not. I did not post until Curry’s (an NASIOC vendor?) chimed in. Your right about one thing, bad news travels fast.
#15 | |
Member#: 17301
the Curry's experiences that people on the board have had are well documented and easy enough to search on.-john |
#16 | |
Member#: 14987
Sorry John, your right. It was Papa smurf who posted the positive review not Buttdyno. Well, I just added another opinion but like you said: people do a search before taking your pride and joy in for work.
#17 |
Member#: 29019
Anyways
![]() Radial Tires did a great job with em. No dings on the SDR's, no dings on the stockers, no dings on the car. Not sure if I like the bronze SDR's on my wrb, but we'll see if I do in the daylight tomorrow.Sorry my post brought up some hot issues. |
#18 | |
Member#: 14987
Glad to hear it went well. Bronze/gold on WRB is a standard combo, should look great.
| Thread Tools | |
| Display Modes | |
| Good STI shops in DC metro area | Komma | Newbies & FAQs | 1 | 05-15-2008 12:47 PM |
| Looking for good body shop in DC Metro area | zoltan | Mid Atlantic Impreza Club -- MAIC | 4 | 04-30-2008 12:54 PM |
| Good tire / wheel mounting shop - S. NH | Gator GT | New England Impreza Club Forum -- NESIC | 17 | 05-21-2005 04:56 PM |
| Machine shop help in DC metro area. | Mud Pig | Mid Atlantic Impreza Club -- MAIC | 12 | 06-11-2003 12:37 AM |
| Good dealerships in DC metro area? | KTB | Warranty Issues & SOA Problems | 2 | 04-17-2002 10:49 PM |
