Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 11-20-2003, 10:03 PM   #1
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
Default Tubes on the bottom of airbox in EJ22
I'm just trying to learn about my engine more. I took apart the intake system. I removed the filter and the MAF and attempted to remove the airbox attached to the intake itself, but it has a few hoses attached to it, one in the front corner and one off the "arm" on the back. There is also a 2-to-1 junction strapped to the bottom of the box.
Are these vacuum hoses? Or what are they? What do they do and what is the effect if they're disconnected from the airbox (or clogged/closed)?
Just curious.
Thanks,
Eric
StewedSquirrel is offline   Reply With Quote
Old 11-20-2003, 11:53 PM   #2
koolaid
Member#: 43491
1997 Impreza Outback
Red
Alright, I just made an intake.. So i think i know these hoses. The 2 -> 1 is a splitter, its for the valve breathers, the big and one next to it are for the crank case (i believe). If the big one is disconneted the car will not run. Yeah, any further Questions, dont be afraid to e-mail me...
Best regards,
Ben
phs_champs@hotmail.com
koolaid is offline   Reply With Quote
Old 11-21-2003, 01:24 AM   #3
StewedSquirrel
Member#: 48509
1998 Impreza OBS
Red/Grey
that's a little less technical than I was hoping... and the (I believe) part doesn't inspire confidence. Anyone else want to chime in?
There appear to be 3 of them, one to each of the last 3 cylinders, but I can't see a 4th one, which made me wonder...
They smell like oil and were damp with oil when I disconnected them, but they don't flow oil, since they empty into the airbox.
Anyway, I've done a little investigating and I think that I will be able to leave all of those connected to the airbox.
I want to shift it back toward the firewall about 4 inches (all the way back) and tip it upward about 30 degrees, so that there is a flexible hose connecting it to the actual intake manifold. From that position, I will be able to connect the MAF directly to the input on the box and then route a stretch of 3" ABS pipe with two 90" turns and a cone-shaped hi-flow filter resting slightly above and to the passenger side of the throttle assembly.
I'll have to investigate how to insulate the intake from the hot metal just below it, but that will only be an issue at idle. At speed, the scoop, directly above it, will provide an ample supply of cold air.
The only trick beyond that will be to fashion an airguide that attaches to the scoop itself and funnels the air down into the intake. Ideally, I'd like to make something nearly sealed, with some rubber weather stripping around it that closes tight when the hood is closed. Practically, I'll be happy if I have less than 1" gap all around, since when it counts, at speed, the pressure will push cold air out into the engine, rather than drawing hot air in from the engine.
I designed this very carefully to make sure that I am able to restore it to stock if I have any problems, such as issues with MAF airflow.
I'll let you know how it goes. I purchased some 3" ABS plumbing today, but that's a 3" inner diameter and 3 1/2" outer diameter. The pipes in the engine are 3" inner diameter and 3 1/16" outer diameter, so the fittings I have don't work on the places I need to attach them. Besides, I don't have the high-flow filter in there yet. :-D
Oh yeah, for the idle control vacuum hose, I got a 1" screw threaded PVC nipple. I will drill into one of the 90" elbows, trim off the bottom half of the threading, screw it into the hole and use some ABS cement to secure it. That's considered good enough for sewage, I hope it's good enough for cold air. :-)
Eric
Old 11-21-2003, 10:04 AM   #4
koolaid
Member#: 43491
Red
I was wondering what this big hose that was a PITFA was for..
Old 11-21-2003, 10:14 AM   #5
Mapplex
Member#: 20315
1997 Impreza L
hunter green
I think one of them might be a drain hose for any water that might make its way into the air box.
Mapplex is offline   Reply With Quote
Old 11-21-2003, 10:57 AM   #6
koolaid
Member#: 43491
Red
No, there is technically no way for water to get there.. there are breathers.. thats it, and the idle air control
How Important Is That Little Cover on the Bottom of the Bellhousing? williaty Transmission (AT/MT) & Driveline 4 06-02-2010 08:45 AM
oil line on the bottom of the turbo is killing me mesa50w Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-01-2005 11:10 AM
What is the "knob" on the bottom of the clutch master cylinder? rallynutdon Motorsports 0 08-25-2004 08:27 AM
Thermo-Tec on the bottom of the IC? Narcisse91 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-19-2002 09:47 AM
