Vancouver Impreza Club
Old 11-20-2003, 11:52 PM   #1
DEVO-2nd GEN
Member#: 3869
Default wheel shops
Hi peeps,
I'm planning to buy this set of wheels, pretty decent price for what they are, but the offset is slightly off for subies.
I've been told that if i have the inside shaved a few mm's then it'll be fine.
has anybody got experience doing this ?
or any shops to recommand ?
thanks.
DEVO-2nd GEN is offline   Reply With Quote
Old 11-21-2003, 12:24 AM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
I think you're missing the pic, as well as the name of the wheel!
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 11-21-2003, 12:38 AM   #3
stisp33d
Member#: 45122
5xtra hp for sti in name!
I think shaving should be left for the girls.....
just get the wheels that fit properly...
I've just been through the same deal, you find a wheel that you like, then it doesn't come in you offset or won't clear the brakes...
Try to find some OZ superleggrea's. The cheapest I found was $370 each 17x7 (quoted by some dude at garage five)
$ 390 at this tire place on hastings and commercial drive.
I ended up getting a set of 17x7.5 SSR Comps on Ebay for $1300 cdn. (after x-change and duty and taxes) reg. 359 USD each.
heheheeh
good luck!
stisp33d is offline   Reply With Quote
Old 11-21-2003, 01:41 PM   #4
Koyo
Member#: 19332
Shave the wheels or shave the brake caliper? I don't think it's a good idea to even touch the wheels since it may screw up it's balance.
Koyo is offline   Reply With Quote
Old 11-21-2003, 01:54 PM   #5
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Wheels aren't perfectly balanced anyhow Neither are tires, that's why you use weights.
My concern with shaving wheels would be weakening them. There's usually not that much material between the hub and the lugs. Shaving a significant amount may not be possible and could cause a safety risk.
AllWheelDrift is offline   Reply With Quote
Old 11-21-2003, 02:01 PM   #6
tora
Member#: 5851
09 Forester XT
+ NA Miata
What size wheel and what car is it going on?
I would recommend against shaving the wheel, it would be much better to find a wheel that fits properly. Ask the shop that is willing to shave the wheel if they will warranty the wheel once it is shaved. My guess is no, so I would not take the risk.
tora is offline   Reply With Quote
Old 11-21-2003, 06:30 PM   #7
4wheelflyer
Member#: 18247
90 R32 Skyline
GTS-T Type M
there is a place called greens automotive that can shave your hub down a bit , I was looking into it for a set of wheels ,but I decieded to just find a wheel with the proper offset
4wheelflyer is offline   Reply With Quote
Old 11-21-2003, 08:34 PM   #8
Penphoe
Member#: 269
I'd be weary of shaving down the bolt area of a wheel. You're thinning down the part of the wheel that you secure to your car. If you thin out too much, your wheel might break. Also, you'd loose any warranty you have on the wheels. Another problem is that if you take off too much, you'd have a difficult time "putting it back".
Just get a wheel with the proper offset and you won't have anything to worry about.
LaterZ!
Darren!!
Old 11-22-2003, 07:03 AM   #9
DEVO-2nd GEN
Member#: 3869
thanks guys for the input
i'll talk to the seller
bent wheel need wheel shop name up in seattle to fix it David Glasscock North West Impreza Club Forum -- NWIC 9 02-13-2009 02:03 PM
Will Mackin Ind. or any wheel shop swap new wheels for different color? GoRacerXGo Southern California Impreza Club Forum -- SCIC 7 02-03-2005 02:07 PM
wheel shop / wheel repair? Rebellion South East Region Forum 3 05-16-2003 01:58 PM
Houston Wheel Shop? Norb Texas Impreza Club Forum -- TXIC 1 04-19-2001 01:37 AM
Boston/Southern NH area wheel shop 63Alpine New England Impreza Club Forum -- NESIC 11 03-09-2001 04:51 AM
