Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 10-04-2000, 02:04 PM   #1
N/A
Member#: 133
TBA TBA
TBA
Post Timing belt instructions with pics (Attn: Alex)
I wanted to know if anybody was interested in a step by step instruction of how to change the timing belt that inculdes pictures and reference points? I was thinking of sending the instructions to Alex to use in the future tech section.
Alex if you want me to mail you a copy can you send me the address?
N/A is offline
Old 10-04-2000, 02:06 PM   #2
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
Sure. Imprezer@home.com.
Imprezer is offline
Old 10-04-2000, 02:13 PM   #3
N/A
Member#: 133
TBA TBA
TBA
Post
Um I meant mailing address for regular mail. I can't scan the copy in and email it. Its also for the DOHC version. I will try to find the SOHC version later in the week.
N/A is offline
Old 10-04-2000, 03:27 PM   #4
OBSS
Member#: 1421
1997 OBSuperSport
Arcadia Green
Post
Definatley interested. Confidence inspiring photos and instructions. Cool.
Adam
MY97OBSS
OBSS is offline
Old 10-04-2000, 04:14 PM   #5
Big Tee
Member#: 1802
1998 Impreza RS2.5
Post
N/A I've attempted to PM you with a request for a copy but I'm getting CGI errors (?)
However I would gladly reimburse you the costs involved in providing me with pics/info. My MY98 (w/DOHC natch) has 61k miles and is due for a T-Belt change.
Let me know if you're willing and I'll get my address to you.
Thanks
Tony-
Big Tee is offline
Old 10-04-2000, 05:04 PM   #6
N/A
Member#: 133
TBA TBA
TBA
Post
At lunch today (I'm 13hrs ahead of NY) I am mailing a copy to Alex. Hopefully he can post it in a section for everybody. Its pretty detailed. I did notice that it can also be used for the EJ20 timing belt since its also a DOHC. When doing the EJ20 timing belt you need to make sure your using the correct marks when lining up the timing. ON the crank pulley there are actually 2 different marks. There is one of the very front of the crank that you SHOULD NOT use. The one you are to actually use is much smaller and more towards the rear of the pulley. If the engine is dirty enough the rear mark may not be visible. IF you line it up using the front mark then you will never get it to start and you can potentially damage the engine. If I mail it today it should take about 3 days to get to Alex. Hopefully he can get it scanned in an online soon after that. If he can't get it online I will make some other copies.
N/A is offline
Old 10-05-2000, 03:41 PM   #7
N/A
Member#: 133
TBA TBA
TBA
Post
I sent out the instructions to Alex yesterday at lunch. Two of the numbers on the diagram were written on the paper by hand since it was cut off by the copier. Everything you should need to know is on it. Alex can you let me know when you get it?
N/A is offline
HTML code is On
Compression test instructions with pics. Impr3zy0u Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 123 03-27-2013 06:04 PM
Time for timing belt Blitzkrieg Service & Maintenance 6 06-01-2010 07:45 PM
Are marks for timing belt close enough. pics inside breathinez Service & Maintenance 15 06-28-2009 02:37 PM
Timing belt change with seal change? file_id Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-09-2007 01:59 PM
WRX timing belt tensioner with warranty IA Performance Private 'For Sale' Classifieds 4 12-03-2003 03:42 PM
