Old 11-21-2003, 01:45 PM   #1
trustz
Member#: 15883
2006 EVO 9
White RS
Question Can I put a turbo timer on a STi ??
Hi,
Do you know if you can control the power door lock open and close when you are idleing the car in a STi ? I heard that you CAN NOT control the power door lock by the remote control(key less entry system) when you are car is running?? So how can I put a turbo timer in a STi ? you can't lock up the door by remote control while the engine is still running ??
thanks
trustz is offline   Reply With Quote
Old 11-21-2003, 01:48 PM   #2
AMG Eater
Member#: 44821
Blue/Gold
I don't think you need one in the first place.
AMG Eater is offline   Reply With Quote
Old 11-21-2003, 02:00 PM   #3
Syck_Driven_STi
Member#: 46274
2004 German
Blue Pearl
you can manually lock the door by turning it with the key.
i know it takes a lot. but try it.
Syck_Driven_STi is offline   Reply With Quote
Old 11-21-2003, 11:34 PM   #4
qbbraveheart
Member#: 49043
a turbo timer is a good idea in any turbocharged vehicle
qbbraveheart is offline   Reply With Quote
Old 11-22-2003, 01:49 AM   #5
sc00by71
Member#: 5362
2004 OBS
Green
Just go to scoobymods. I researched this and found a fix when I first got my 02 wrx in april 01. Scoobymods has a good write up on how to make it play nice with the factory keyless entry and add on security system.
Shawn
sc00by71 is offline   Reply With Quote
Old 11-22-2003, 01:57 AM   #6
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
you just cut the wire that tells the door locks that the car is on.
afpdl is offline   Reply With Quote
Old 11-30-2003, 05:05 AM   #7
DangerousWRX
Member#: 8459
2004 STi
Smile YES!
I had the HKS and it said i was not going to be able to use the door locks or alarm, but my friend hooked it up in about and hour and bypassed what ever was needed to be bypassed with no extra parts. Its worked great, SO YES I KNOW IT CAN BE DONE AND ITS NOT THAT HARD.
However i just watched, he did it!
DangerousWRX is offline   Reply With Quote
Old 11-30-2003, 07:54 PM   #8
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
qbbraveheart- the way subaru turbos are designed they DO NOT have a use for a turbo timer. water and oil keep moving through the turbo when the motor is off on any turbo EJXX. i just dont understand why someone would want to spend $100 on a TT, and all the time to install it. it just wastes gas and adds weight to your car. spend your money and time on other things like school, girl friends, and drinking.
but if you HAVE TO have it, knock your self out
RS_to_WRX_swap is offline   Reply With Quote
Old 11-30-2003, 08:00 PM   #9
Syck_Driven_STi
Member#: 46274
2004 German
Blue Pearl
lmbao. just let the car run for 2 minutes. you know, be on time meaning early. and you can have more seat time in your baby!
Old 12-01-2003, 10:53 PM   #10
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Peaty is offline   Reply With Quote
Can you put stock 350z wheels on an sti? sartre311 Interior & Exterior Modification 11 02-18-2009 06:13 PM
can i use sti Harness for greddy turbo timer on o4 wrx? pengmao Electrical & Lighting 0 02-03-2008 01:35 AM
Do I need a turbo timer on 04 STi? 0BlueSTi4 Newbies & FAQs 10 01-24-2006 11:27 PM
can i put 235/45/17 on my sti malibuda Tire & Wheel 21 12-27-2005 10:40 AM
Who has installed an APEX turbo timer on an STI ? The Donnn Electrical & Lighting 8 11-23-2003 10:55 AM
