![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 48598
Vehicle:2003 Subaru WRX Black |
Does anyone know anyhting about painting rims and tires..what paints to use and how to do it..i'd like to see picks if you have any...thanks
#2 |
Member#: 17861
Vehicle:2002 WRX |
i used duplicolor wheel paint, they give some instructions on painting the wheels, but why would you paint the tires?
heres the duplicolor website... http://www.duplicolor.com/products/wheel.html and here are some pics of my car... http://f1.pg.photos.yahoo.com/ph/csl...My+Car&.view=t |
#3 |
Member#: 5851
VIC
Vehicle:09 Forester XT + NA Miata |
I've painted about 5 sets now and they've all turned out pretty well. Here is my process:
- Wash and clean wheel. - I then clean with some wire brush as well as sandpaper to both scuff the surface and to clean any hard to get off gunk. - Wash and clean wheels again and then let dry fully. Make sure there is no water anywhere. I also let them airdry over night now just to make sure. - I use two or three coats of primer letting it dry each time. - I then use 2-4 coats of paint depending on the color, again letting it dry each time. - Finally I spray 2-3 coats of clearcoat on them, again letting it dry after each coat. - Leave it overnight to dry....good to go. Also make sure you get wheels weights off. I paint the full wheel suface, front and back with the tire off. Good luck with your paint job! |
#4 |
Member#: 38120
South East
Vehicle:1991 Rio Red Legacy Turbo |
I may have to try that, tora. I was going to paint mine as well.
Kingronaldo - I hate to sound rude, but do a search. There have been many threads about this. If you have tried a search, then fine. If you haven't try that next time before posting a new thread. ~Iron L255 |
#5 |
Member#: 14238
Vehicle:2002 WRX Wagon - PSM Alfas: 89 Milano | 72 GTV |
The advice posted above is good.
The one thing I haven't seen mentiones is to buy a good quality tack cloth and wipe the wheel down with it between coats. This $5 investment will make sure that any dust or particulate that may fall on the wheel while drying doesn't get painted over and ruin the finish. |
#6 |
Member#: 37868
Vehicle:2006 Corvette LeMans Blue |
All this effort -
I had a quote to powder coat the rim for less than 50 each - powder coating is tougher. Any thoughts? |
#7 |
Member#: 41754
Vehicle:03 wrx gt35r, 2.5L, meth |
wait why do you have to get the wheel weights off? (Is that what you are saying?)
Thanks! |
#8 | |
Member#: 37868
| Thread Tools | |
| Display Modes | |
| Not undersanding how to select rims and tires. | BLCNBLU | Tire & Wheel | 5 | 11-30-2009 09:30 AM |
| How to paint rims? | omega force | Interior & Exterior Modification | 3 | 08-08-2007 01:02 AM |
| where and or how to paint rims | ineedparts | Tri-State Area Forum | 11 | 03-29-2007 11:46 PM |
| Question: How to store rims and tires? | Edvig | Brakes, Steering & Suspension | 4 | 08-08-2002 02:46 PM |
| Help: Does anyone know how to paint rims? | byam52 | Technical Forum Archive | 6 | 08-11-2000 12:28 AM |
