Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 06-29-2000, 08:25 PM   #1
bdoboy
Member#: 1772
Post What is detonation?
Hey all,
I'm trying to learn about turbos/superchargers and everything. I hear the term detonation associated with them. Is this something you hear? What is it from? What does it sound like? Is it bad for the car?
Thanks
bdoboy is offline
Old 06-29-2000, 09:30 PM   #2
inzomniac
Member#: 1710
1998 2.5RS/2002 WRX
RS: RBP/ WRX: PSM
Post
when the fuel explodes before the piston reaches TDS (top dead centre) and creates a rough sound in the engine...If you have it, I suggest you take you're car in before the engine blows (cylinders will overheat)
inzomniac is offline
Old 06-29-2000, 09:33 PM   #3
RotrPwr
Member#: 1506
1993 RX-7
Competition Yellow Mica
Post
detonation: lean mixture caused by too much air and not enough fuel mixed in the combustion chamber. The air/fuel mixture becomes very hot when combusted, the piston swells from the heat and rubs against the cylinder walls possibly scoring or scratching it. Sometimes makes a high pitched whining noise, or pings.
*edit for spelling*
[This message has been edited by RotrPwr (edited June 29, 2000).]
RotrPwr is offline
Old 06-29-2000, 10:45 PM   #4
shiv
Member#: 607
Post
Detonation is another term for pre-ignition or ping or knock. It's occurs when the air/fuel mixture ignites before you want it to (i.e. while the piston is on the way up). The effects of serious detonation can be quite unsightly. Instead of a clean, smooth burn (normal combustion), detonation is an uncontrolled explosion. Cylinder temps and pressures rise to high heaven almost intantaneously, taking out pistons, valves, rings, and even rods! Detonation can be caused by a lean air fuel mixture (lean mixtures burn faster and are easier to ignite than rich mixture) or an overy agressive ignition advance.
Minor detonation sounds like little marbles ticking around under your hood. More serious detonation sounds like big marbles banging around under your hood. With the windowns down and radio up, detonation is hard to hear. Windows up and radio off. Listen carefully for it during the tuning process. If you hear it, get your foot off the gas and figure out what is wrong. Hope that helps...
Shiv
shiv is offline
HTML code is On
What is that noise? tirkish Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 07-08-2010 03:44 PM
New to stage.. 2 What I'm hearing is detonations?? BBBsti LTD AccessPort 13 04-03-2006 10:30 AM
Not sure what it is??? Detonation, sensor? Help! Silver_04_WRX_SC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-22-2005 12:31 AM
Q. What is Detonation?Q? Answer!!! Primm Motorsports Normally Aspirated Powertrain 2 02-09-2001 04:12 PM
What is the sound of detonation? Tim Prudence Technical Forum Archive 17 05-10-2000 06:19 PM
