Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-04-2000, 09:10 AM   #1
Member#: 60
Post New Age Impreza Specifications
SPEC
Model TA-GDA TA-GD9
Grade NB NA
Engine 2.0
DOHC 16valves Turbo
2.0
DOHC 16valves
Gear
Box
Sports
Shift 4-AT
5MT Sports
Shift 4-AT
5MT
GEAR
BOX
4WD
Weight*Dimensions*Others
Dimensions
(LxWxH)
4405mm
x 1730mm x 1435mm
4405mm
x 1730mm x 1440mm
Wheelbase
2525mm
Track
front/rear
1485mm/1475mm
Ground
Clearance
150mm 155mm
Cabin
(LxWxH)
1890mm
x 1380mm x 1180mm
Curb
Weight
1370kg 1340kg 1310kg 1290kg
Seating
Capacity
5
passengers
Min.
Turning Radius
5.4m
Fuel
Consumption
11.4km 11.8km 12.0km 12.6km
Engine
Engine
type
EJ20
Cylinders/valves BOXER
2000cc
DOHC 16valve
AVCS
(Active Valve Control System) Turbo
2000cc
DOHC 16valve
AVCS
Bore
x Stroke
92.0
x 75.0
Piston
displacement
1994cc
Compression
ratio
9.0 10.8
Max
power<NET> (ps)
184(250)/6000 114(155)/6400
Max
torque<NET>(kg-m)
333(34.0)/3600 196(20.0)/3200
Fuel
system
EGI
(Electronically Controlled Multi-point Fuel Injection)
Fuel
type
Unleaded
Premium Gasoline
Tank
capacity
60
litres
50
litres
Gear
ratio
@ Sports
Shift 4-AT
5MT Sports
Shift 4-AT
5MT
Gear
ratio 1st
2.785 3.166 2.785 3.454
2nd
1.545 1.882 1.545 2.062
3rd
1.000 1.296 1.000 1.448
4th
0.694 0.972 0.694 1.088
5th
--- 0.738 --- 0.825
rear
2.272 3.333 2.272 3.333
Final
gear ratio
4.111 4.444 4.111 3.900
Steering*Braking
Steering Rack
and Pinion
Braking
system  (F/R)
Ventilated
discs
Discs
Suspension
(F/R)
Struts
Independent
Struts
Independent
[This message has been edited by [email protected] (edited October 04, 2000).]
ggiles@clarionnet.com is offline
Old 10-04-2000, 09:26 AM   #2
Gambit
Member#: 102
Post
Does that mean we get that AVCS WRX as well?
Gambit is offline
Old 10-04-2000, 09:31 AM   #3
Member#: 60
Post
To my knowledge all the WRX engine will carry the active valve timing, which I believe is Subaru's version of VTEC or VTT-i.
The track of this car is actuall more of the 22b track than the old WRX. I would say that this is looking more to be a detuned and revised 22b rather than a new WRX.
Also, if anyone knows how to make the table not have that huge space at the top please let me know. For some reason I can't figure it out for UBB table posting. Sorry for the size.
George
gg
Old 10-04-2000, 10:52 AM   #4
Mel 22B
Member#: 621
Silver with Black Tires
Post
I am not 100% sure but I don't believe the MY 02 WRX has the variable timing. Probably the STi version or the next year.
-Mel
Mel 22B is offline
Old 10-04-2000, 11:23 AM   #5
Member#: 60
Post
What's
AVCS
then?
It sounds like a Variable Valve system to me.
George
gg
Old 10-04-2000, 01:04 PM   #6
Chaincat
Member#: 650
2010 STi SE
Dark Grey
Post
Ok, so can someone run some numbers to see what the max mph for each gear is? What should we assume the fuel cut is at? I pray to god that at least the lower gears are a bit longer than the RS.
-Brian
Wishing for 6 spd.
Chaincat is offline
Old 10-04-2000, 01:09 PM   #7
Gambit
Member#: 102
Post
6spd will only be available for the STi versions.
Gambit is offline
Old 10-04-2000, 02:02 PM   #8
Buttsy
Member#: 2043
2002 Impreza WRX
WR Blue Pearl
Post
Will we get the 6-speed in the '03 model? All of the literature I've read says it'll be coming over a year after the North American release.
Buttsy is offline
Old 10-04-2000, 02:07 PM   #9
Buttsy
Member#: 2043
2002 Impreza WRX
WR Blue Pearl
Post
Hmm... the turbo has an extra 10 Liters of fuel capacity. Did they do that to keep the range the same, since the fuel economy for the turbo is lower?
10 liters = ??? gallons
Buttsy is offline
Old 10-04-2000, 03:05 PM   #10
gumball
Member#: 1209
Post
Might be easier to just hit this link-
http://www.lares.dti.ne.jp/~tact/pri...s/data015.html
gumball is offline
Old 10-04-2000, 03:13 PM   #11
Black98RS
Member#: 786
Post
10 Liters is 2.642 gallons.
Black98RS is offline
Old 10-04-2000, 03:15 PM   #12
KC
Member#: 442
16 SS
00 S2000
Post
I believe 10 Liters is aabout 2.7 Gallons...Not much.
--KC
KC is online now
Old 10-04-2000, 03:23 PM   #13
Mel 22B
Member#: 621
Post
I pray the tach goes in the middle...
-Mel
Mel 22B is offline
Old 10-05-2000, 12:59 AM   #14
matt7184
Member#: 1797
2003 MazdaSpeed
Protege
Post
Im almost + it is subies version of VVT-i
matt7184 is offline
HTML code is On
Old Impreza, New Age Impreza, Dream Car 04SubiSTi Member's Car Gallery 35 11-10-2006 05:33 PM
Zerosports 60mm gauge pod for 02+ new age Impreza brand new in the box, prepainted JDM addict Private 'For Sale' Classifieds 23 12-09-2004 01:12 PM
New New Age Impreza parts!! wrxtuner02 Interior & Exterior Modification 0 12-11-2002 06:16 PM
whos selling their impreza away for new age impreza? DarkImpreza Vancouver Impreza Club Forum -- VIC 2 02-04-2001 12:14 AM
3 New age Imprezas sighted craigc Bay Area Impreza Club Forum -- BAIC 5 10-31-2000 12:08 AM
