Old 11-23-2003, 01:46 PM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Unhappy SAFC help needed - CEL + AT temp + stalls
damnit
I installed it yesterday, was fine
today when started it, had to set up parameters, put
hot: 4:4
flap: 4:4 (did auto because of hot)
pressure : 5:5
throttle settings were 20/75
car dies on start....as soon as press gas can feel how rich it runs and a/f gauge goes rich, not enough air = stalls
ok, changed flap/hot/pressure to 1:1 - > hello CEL and AT oil temp started blinking
stalls
Help!
I quess my first step is take off neg. from battery for hour, what then what??
edit
waited for hour, put back, cel still there
set it to 5:5, 4 cyl, up arrow
car dies....runs rich
only thing I can think of is remove safc for the car actually to be able to move!
Cmon guys, help me out on this, I really don't know what to do
Went through search 2 times already, through tons of stuff
Hyper is online now   Reply With Quote
Old 11-23-2003, 03:50 PM   #2
incorporeal
Guest
Member#:
I had the same problem back in 99 on my RS, most likely you hooked it up wrong because that is what I did. I ended up taking it to a shop and the tech and I worked on it for like 5 hours. I cant remember the final fix though. If it is hooked up wrong though, you can disconnect it and still drive.
FTW
Old 11-23-2003, 03:54 PM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I'm pretty sure I hooked it up right
followed instructions for yellow/white wires
it also shows -750 mmHg on idle
also, if disconnecting, I would have to wire back map wire, since if I just disconnect power from safc, map signal won't go into ecu
Old 11-23-2003, 08:14 PM   #4
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
ok, for the basic question
I am MAP
what sensor do I use and what do I set it to?
I tried 5:5 in pressure now again, once I reflashed ECU and checked connections,
and CEL and AT Oil Temp poped out on me
Need help, boost drop at 6k rpm. Ecu reset temp fixes it. elitescouter Open Source Reflashes 4 06-07-2009 06:22 PM
Some help needed - Looking at 06 Impreza 2.5i.. Damn Dirty Ape Newbies & FAQs 19 10-29-2006 08:38 AM
Help Needed Reading AT Error Code arcsound Transmission (AT/MT) & Driveline 9 03-19-2005 02:40 PM
Need Help ... 7 CEl codes all at once Xtremewrx Engine Management & Tuning 9 08-31-2004 06:13 PM
Can anyone help - need CEL pulled. AVATAR-X Bay Area Impreza Club Forum -- BAIC 2 01-26-2003 06:15 PM
