Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 11-23-2003, 01:02 PM   #1
Member#: 31418
1999 2.5RS
OMGHi2U help wiring A/F gauge pleeeease?
ok all i need some help getting my A/F gague wired up corectly. i have a high flow cat that was throwing a P0420. i bought a mil elliminator to get rid of it. i went to wire up my A/F gauge and realized that i cant pull it from the ECU because the mil elliminator is changing the signal going to it. so i tried hooking it up to the O2 sensor before the elliminator. i have tried both white wires and the grey wire. none of them have worked. i didnt try the black as i am assuming that is the ground.
does anyone have any idea as to why it isnt working. i have power to it and the ground is good. one of the white wires gives me a constant signal that starts out mid stoich and falls to low stoich/lean and then just sits there.
is my mil elliminator causing this?
do you all think i should go buy another O2 sensor for the gauge (i have another bung allready set in my exhaust just before the cat i could use but i dont know how i would wire it up).
thanks for any help you all can provide
(sorry for the long post)
Monas is offline   Reply With Quote
Help wiring electric boost gauge AlxSti Electrical & Lighting 2 04-06-2007 02:02 PM
help wiring up gauges where the clock use to be civichunter2 Electrical & Lighting 13 10-02-2006 05:32 PM
help sti and rs gauges/ wiring 98skuby Electrical & Lighting 2 12-30-2005 12:07 AM
help...wiring autometer lunar series boost and egt gauge for lighting Jon Cox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-21-2002 02:51 PM
Help wiring air/fuel gauge Joe Garcia Southern California Impreza Club Forum -- SCIC 1 08-08-2002 07:03 PM
